Unofficial File parts/s/38458s05.dat
0 ~Minifig Head with Exaggerated Chimpanzee Features - Head - Half (needs work)
0 Name: s\38458s05.dat
0 Author: Jeff Jones [notmaster]
0 !HISTORY 2025-06-07 [notmaster] subparted from s\38458s01.dat
0 !HISTORY 2025-08-27 [GeraldLasser] corrected origin
0 // NEEDS WORK CHEEK FUR NOT MODELED
1 16 0 0 0 20.2 0 0 0 18 0 0 0 20.2 1-4cyli.dat
1 16 0 0 0 20.2 0 0 0 1 0 0 0 20.2 1-4chrd.dat
1 16 0 18 0 13.46667 0 0 0 12 0 0 0 13.46667 t04o5000.dat
0 // WHERE CHEEK FUR SHOULD BE
1 16 0 18 0 13.46667 0 0 0 12 0 0 0 -13.46667 t04o5000.dat
1 16 0 24 0 11.5 0 0 0 -1 0 0 0 11.5 1-4tang.dat
1 16 0 24 0 13.46667 0 0 0 -1 0 0 0 13.46667 1-8chrd.dat
1 16 0 24 0 0 0 13.46667 0 -1 0 13.46667 0 0 1-8chrd.dat
3 16 0 24 11.5 0 24 13.4667 2.2874 24 11.5
3 16 2.2874 24 11.5 0 24 13.4667 4.4011 24 10.6249
3 16 4.4011 24 10.6249 0 24 13.4667 9.5223 24 9.5223
3 16 6.5148 24 9.7497 4.4011 24 10.6249 9.5223 24 9.5223
3 16 8.1317 24 8.1317 6.5148 24 9.7497 9.5223 24 9.5223
3 16 8.1317 24 8.1317 9.5223 24 9.5223 9.7497 24 6.5148
3 16 10.6249 24 4.4011 9.7497 24 6.5148 9.5223 24 9.5223
3 16 10.6249 24 4.4011 9.5223 24 9.5223 13.4667 24 0
3 16 10.6249 24 4.4011 13.4667 24 0 11.5 24 2.2874
3 16 11.5 24 0 11.5 24 2.2874 13.4667 24 0
1 16 0 24 0 0 0 11.5 0 -1 0 -11.5 0 0 1-4tang.dat
1 16 0 24 0 0 0 13.46667 0 -1 0 -13.46667 0 0 1-8chrd.dat
1 16 0 24 0 13.46667 0 0 0 -1 0 0 0 -13.46667 1-8chrd.dat
3 16 11.5 24 0 13.4667 24 0 11.5 24 -2.2874
3 16 11.5 24 -2.2874 13.4667 24 0 10.6249 24 -4.4011
3 16 10.6249 24 -4.4011 13.4667 24 0 9.5223 24 -9.5223
3 16 9.7497 24 -6.5148 10.6249 24 -4.4011 9.5223 24 -9.5223
3 16 8.1317 24 -8.1317 9.7497 24 -6.5148 9.5223 24 -9.5223
3 16 8.1317 24 -8.1317 9.5223 24 -9.5223 6.5148 24 -9.7497
3 16 4.4011 24 -10.6249 6.5148 24 -9.7497 9.5223 24 -9.5223
3 16 4.4011 24 -10.6249 9.5223 24 -9.5223 0 24 -13.4667
3 16 4.4011 24 -10.6249 0 24 -13.4667 2.2874 24 -11.5
3 16 0 24 -11.5 2.2874 24 -11.5 0 24 -13.4667
4 16 18.6628 0 -7.7305 18.6628 6.1545 -7.7305 18.8538 7.97 -6.77 20.2 0 0
3 16 20.2 0 0 18.8538 7.97 -6.77 19.0964 10.91 -5.55
4 16 20.2 18 0 20.2 0 0 19.0964 10.91 -5.55 19.0964 12.19 -5.55
3 16 20.2 18 0 19.0964 12.19 -5.55 18.9492 13.09 -6.29
4 16 18.6635 18 -7.7312 20.2 18 0 18.9492 13.09 -6.29 18.6628 14.0747 -7.7305
3 16 18.6635 18 -7.7312 18.6628 14.0747 -7.7305 16.1102 15.87 -11.55
4 16 14.2834 16.7167 -14.2834 14.2841 18 -14.2841 18.6635 18 -7.7312 16.1102 15.87 -11.55
3 16 14.2841 18 -14.2841 14.2834 16.7167 -14.2834 12.8072 16.89 -15.27
3 16 18.6628 0 -7.7305 18.0884 4.53 -8.59 18.6628 6.1545 -7.7305
3 16 17.4334 2.99 -9.57 18.0884 4.53 -8.59 18.6628 0 -7.7305
4 16 17.4334 2.99 -9.57 18.6628 0 -7.7305 14.2834 0 -14.2834 16.9255 2.57 -10.33
3 16 14.2834 0 -14.2834 14.2834 3.3987 -14.2834 16.2572 2.59 -11.33
3 16 14.2834 0 -14.2834 16.2572 2.59 -11.33 16.9255 2.57 -10.33
4 16 7.7305 0 -18.6628 7.7305 5.4539 -18.6628 14.2834 3.3987 -14.2834 14.2834 0 -14.2834
4 16 0 0 -20.2 0 7.8785 -20.2 7.7305 5.4539 -18.6628 7.7305 0 -18.6628
3 16 10.8919 16.71 -16.55 14.2841 18 -14.2841 12.8072 16.89 -15.27
4 16 7.7312 18 -18.6635 14.2841 18 -14.2841 10.8919 16.71 -16.55 7.7305 15.9387 -18.6628
4 16 0 0 20.2 0 0 -20.2 7.7305 0 -18.6628 20.2 0 0
4 16 18.6628 0 -7.7305 20.2 0 0 7.7305 0 -18.6628 14.2834 0 -14.2834
2 24 14.2834 0 -14.2834 18.6628 0 -7.7305
2 24 20.2 0 0 18.6628 0 -7.7305
2 24 14.2834 0 -14.2834 7.7305 0 -18.6628
2 24 7.7305 0 -18.6628 0 0 -20.2
3 16 7.7312 18 -18.6635 7.7305 15.9387 -18.6628 7.5031 15.9222 -18.708
0 // Condlines
5 24 7.7305 5.4539 -18.6628 7.7305 0 -18.6628 14.2834 3.3987 -14.2834 0 0 -20.2
5 24 18.66346 18 -7.73122 18.6628 14.0747 -7.7305 20.2 18 0 16.1102 15.87 -11.55
5 24 14.2834 0 -14.2834 14.2834 3.3987 -14.2834 7.7305 0 -18.6628 16.2572 2.59 -11.33
5 24 7.7312 18 -18.6635 7.7305 15.9387 -18.6628 7.5031 15.9222 -18.708 14.2841 18 -14.2841
5 24 14.2841 18 -14.2841 14.2834 16.7167 -14.2834 18.6635 18 -7.7312 12.8072 16.89 -15.27
5 24 18.6628 6.1545 -7.7305 18.6628 0 -7.7305 18.8538 7.97 -6.77 18.0884 4.53 -8.59
Needs 2 More Votes (N)
2025-06-07 09:33:06
Willy Tschager [Holly-Wood]
posted a vote of Hold
2025-06-07 17:42:36
Rene Rechthaler [Blechtaler]
2025-06-07 17:46:41
the torus under the face should be inlined and cut along the seam to 38458s04
the other end of the "ring" is also made of not needed prims, so maybe just use ering+quads to the border
the rear cyli should be exactly R20
1 16 0 -24 0 20.2 0 0 0 18 0 0 0 20.2 1-4cyli.dat
(and add the edge here)
Gerald Lasser [GeraldLasser]
2025-08-27 22:20:25
moved orin and corrected some geometry
1 16 0 -32 0 1 0 0 0 1 0 0 0 1 4032.dat
so, 1 16 0 -24 0 20.2 0 0 0 18 0 0 0 20.2 1-4cyli.dat is out of system.
* Misses edges:
1 16 0 -24 0 20 0 0 0 1 0 0 0 20 1-4edge.dat
Edge should be added to a new 1-4chrde prim
* Rounding:
5 24 14.284096869 -6 -14.284096869 14.2834 -7.2833 -14.2834 18.6635 -6 -7.7312 12.8072 -7.11 -15.27
