Unofficial File parts/s/76797s03.dat
~Brick  3 x  3 x  1 Quarter Circle with Curved Top wihtout Patternable Surfaces- Half, Common Geomtry
0 ~Brick  3 x  3 x  1 Quarter Circle with Curved Top wihtout Patternable Surfaces- Half, Common Geomtry
0 Name: s\76797s03.dat
0 !HISTORY 2025-04-09 [GeraldLasser] Subfiled for use also in 6957
0 !HISTORY 2025-04-27 [OrionP] Official Update 2025-04
0 !HISTORY 2025-06-08 [GeraldLasser] Adapted to use common Geometry of the Brick Family, 7426, 76797, 6957
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\7426s03.dat
0 // Bottom, Outside Rim
3 16 56 24 -4 60 24 0 56 24 -10
1 16 56 21.75 -7 0 1 0 0 0 -2.25 3 0 0 rect2p.dat
4 16 56 19.5 -10 52.7425 19.5 -6.9426 52.9363 19.5 -4 56 19.5 -4
2 24 52.7425 19.5 -6.9426 52.9363 19.5 -4
0 // Bottom, Centre, Common Area
4 16 24 24 -24 20 24 -20 20 24 0 24 24 -4
2 24 20 24 -20 20 24 0
2 24 24 24 -4 24 24 -24
3 16 24 7.443 -9.9411 24 10.1426 -24 24 24 -24
4 16 24 24 -24 24 24 -4 24 7.1945 -4 24 7.443 -9.9411
4 16 26.8181 23.5 -24.6967 24 23.5 -21.8787 24 9.7353 -21.8787 26.8181 11.0862 -24.6967
3 16 24 23.5 -21.8787 26.8181 23.5 -24.6967 24 23.5 -24
3 16 26.8181 11.0862 -24.6967 25.7574 10.9851 -25.7574 26.8181 23.5 -24.6967
2 24 24 23.5 -21.8787 24 9.7353 -21.8787
2 24 24 23.5 -21.8787 24 23.5 -24
2 24 25.7574 10.9851 -25.7574 26.8181 11.0862 -24.6967
2 24 24 23.5 -21.8787 26.8181 23.5 -24.6967
2 24 24 9.7353 -21.8787 26.8181 11.0862 -24.6967
2 24 26.8181 11.0862 -24.6967 26.8181 23.5 -24.6967
2 24 24 7.443 -9.9411 24 7.1945 -4
2 24 24 10.1426 -24 24 7.443 -9.9411
2 24 20 6.4028 -4 20 8.225 -20
0 // Bottom Innter Face
4 16 46.194 17.4 -19.1342 35.3569 11.61 -14.6453 37.4744 11.61 -4 49.2044 17.4 -4
3 16 24 7.443 -9.9411 24 7.1945 -4 37.4744 11.61 -4
3 16 37.4744 11.61 -4 35.3569 11.61 -14.6453 24 7.443 -9.9411
3 16 49.2044 17.4 -4 52.9363 19.5 -4 52.7425 19.5 -6.9426
4 16 49.2044 17.4 -4 52.7425 19.5 -6.9426 51.3859 19.5 -13.7682 46.194 17.4 -19.1342
4 16 35.3569 11.61 -14.6453 27.061 11.61 -27.061 24 10.1426 -24 24 7.443 -9.9411
3 16 20 6.4028 -4 20 8.225 -20 4 4.3728 -4
5 24 35.3569 11.61 -14.6453 46.194 17.4 -19.1342 37.4744 11.61 -4 35.3553 17.4 -35.3553
5 24 46.194 17.4 -19.1342 51.3859 19.5 -13.7682 49.1515 19.5 -20.3596 49.2044 17.4 -4
5 24 37.4744 11.61 -4 35.3569 11.61 -14.6453 49.2044 17.4 -4 24 7.443 -9.9411
5 24 37.4744 11.61 -4 24 7.443 -9.9411 35.3569 11.61 -14.6453 24 7.1945 -4
5 24 35.3569 11.61 -14.6453 27.061 11.61 -27.061 24 10.1426 -24 46.194 17.4 -19.1342
5 24 35.3569 11.61 -14.6453 24 7.443 -9.9411 27.061 11.61 -27.061 37.4744 11.61 -4
5 24 52.7425 19.5 -6.9426 49.2044 17.4 -4 51.3859 19.5 -13.7682 52.9363 19.5 -4
5 24 49.2044 17.4 -4 46.194 17.4 -19.1342 35.3569 11.61 -14.6453 52.7425 19.5 -6.9426
0 // Bottom, Stud Half
0 // Bottom Stud
1 16 40 18.5 -20 1 0 0 0 -1.375 0 0 0 1 stud4a.dat
1 16 40 18.5 -20 .92388 0 .38268 0 4 0 -.38268 0 .92388 stud4s.dat
2 24 35.5816 11.61 -13.5155 34.4517 11.2779 -14.2704
2 24 47.3912 19.2485 -23.0616 46.0976 19.0492 -24.9973
2 24 47.3912 19.2485 -23.0616 48 18.7166 -20
2 24 47.9745 18.6643 -19.8719 48 18.7166 -20
2 24 47.5492 17.9481 -17.7336 47.9745 18.6643 -19.8719
2 24 46.0976 19.0492 -24.9973 45.6568 19.0493 -25.6568
2 24 34.343 14.2647 -25.657 32.6091 12.8134 -23.0615
2 24 32 11.7024 -20 32.6091 12.8134 -23.0615
2 24 36.9386 15.8357 -27.391 40 17.2871 -28
2 24 36.9386 15.8357 -27.391 34.343 14.2647 -25.657
2 24 45.6568 19.0493 -25.6568 43.0615 18.4299 -27.391
2 24 44.2428 16.1053 -15.7573 45.5432 16.9383 -17.7039
2 24 45.5432 16.9383 -17.7039 45.795 17.1868 -18.9689
2 24 40 13.8385 -14 42.2961 15.0167 -14.4567
2 24 44.2428 16.1053 -15.7573 42.2961 15.0167 -14.4567
2 24 36.6315 12.291 -15.1732 37.7039 12.75 -14.4568
2 24 37.7039 12.75 -14.4568 40 13.8385 -14
2 24 45.657 16.6645 -14.343 46.8052 17.4 -16.0617
2 24 40 13.6421 -12 43.0614 15.2131 -12.609
2 24 43.0614 15.2131 -12.609 45.657 16.6645 -14.343
2 24 35.5816 11.61 -13.5155 36.9385 12.1908 -12.6091
2 24 40 13.6421 -12 36.9385 12.1908 -12.6091
2 24 34.343 11.2606 -14.343 34.4517 11.2779 -14.2704
2 24 32.609 11.2607 -16.9386 32.0935 11.61 -19.5294
2 24 32.609 11.2607 -16.9386 34.343 11.2606 -14.343
2 24 46.8052 17.4 -16.0617 47.391 17.7871 -16.9385
2 24 47.5492 17.9481 -17.7336 47.391 17.7871 -16.9385
2 24 45.9119 17.4 -19.5564 46 17.5661 -20
2 24 46 17.5661 -20 45.5433 18.0313 -22.2961
2 24 41.8526 17.4 -25.6315 42.2961 17.5661 -25.5432
2 24 44.2427 18.0316 -24.2428 45.5433 18.0313 -22.2961
2 24 44.2427 18.0316 -24.2428 42.2961 17.5661 -25.5432
2 24 43.0615 18.4299 -27.391 40.3113 17.4 -27.9383
2 24 36.6315 12.291 -15.1732 35.7573 12.0885 -15.7572
2 24 34 12.5394 -20 34.4567 12.0885 -17.7039
2 24 35.7573 12.0885 -15.7572 34.4567 12.0885 -17.7039
2 24 34.4568 13.3726 -22.2961 35.7572 14.461 -24.2427
2 24 34 12.5394 -20 34.4568 13.3726 -22.2961
2 24 37.7039 15.6393 -25.5433 40 16.7279 -26
2 24 35.7572 14.461 -24.2427 37.7039 15.6393 -25.5433
2 24 41.8526 17.4 -25.6315 40 16.7279 -26
2 24 45.795 17.1868 -18.9689 45.9119 17.4 -19.5564
2 24 40 17.2871 -28 40.3113 17.4 -27.9383
2 24 32 11.7024 -20 32.0935 11.61 -19.5294
0 // Seams
5 24 20 8.22501 -20 4 4.3728 -4 20 7.41985 -15.80687 15.80687 7.41985 -20
5 24 27.06097 11.61 -27.06098 24 10.14259 -24 35.35687 11.61 -14.64529 14.64529 11.61 -35.35687
Gerald Lasser [GeraldLasser]
2025-06-08 16:35:22
adapted to new common geometry
2025-06-08 16:36:05
de-coloured
Rene Rechthaler [Blechtaler]
made the following comment.
2025-06-08 19:57:58
two typos in the title:
wihtout
Geomtry
edited the part header.
2025-06-08 20:21:24
Header Edits
description:
to
~Brick 3 x 3 x 1 Quarter Circle with Curved Top without Patternable Surfaces- Half, Common Geometry
Comment:
corrected.
You can correct it as well
2025-06-08 21:11:17
i know I could, but it is your part
Mark Kennedy [mkennedy]
Part Reviewer
posted a vote of Certify
2025-07-04 12:35:31
2025-10-23 22:54:52
why the double edgelines of the inner antistud? is the stud4s correct here?
Part Reviewer
2025-10-24 03:30:02
This is a valid point. Perhaps some discussion on the topic to see what people think?
Part Reviewer
cancelled their vote.
2025-10-24 03:30:24
2025-10-24 07:36:32
stud4s is the sloped version, it only comes with edge lines.
The other edgelines are hidden in the part, so not visible.
other way would be to either make a stud4sa without an edge line(s) or break down into a stud4 plus cyls.
IMHO the stud4s is fine where it is
Orion Pobursky [OrionP]
2025-10-24 08:06:22
Not seen. Doesn't matter
2026-05-17 11:13:54
