Unofficial File parts/65084.dat
Duplo Plate  2 x  2 with Hinge Extended on Side and Red Gaskets
0 Duplo Plate  2 x  2 with Hinge Extended on Side and Red Gaskets
0 Name: 65084.dat
0 !HELP Secondary hinge position at 0 -5 120
0 !CATEGORY Duplo
1 16 0 0 0 1 0 0 0 2.75 0 0 0 1 stug7-2x2.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\65084s01.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\65084s01.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\65084s02.dat
0 // bottom reinforcements
1 16 0 4 -26 0 0 -1.5 0 4 0 10 0 0 box3u5p.dat
1 16 0 4 -16 0 0 1.5 0 4 0 1.5 0 0 boxjcyl4.dat
1 16 0 4 20 0 0 1.5 0 4 0 -4 0 0 box3u8p.dat
1 16 0 4 16 0 0 1.5 0 4 0 -1.5 0 0 boxjcyl4.dat
1 16 0 4 24 0 0 1.5 0 4 0 1.5 0 0 boxjcyl4.dat
0 // bottom helm
4 16 -40 24 -40 -36 24 -36 36 24 -36 40 24 -40
0 // large box inner surface
1 16 0 14 76 0 0 36 10 0 0 0 -112 0 box3u2p.dat
3 16 36 4 -36 -36 4 -36 0 4 -16
3 16 0 4 16 -18.5 4 71 18.5 4 71
0 // outer surfaces
1 16 0 12 -40 0 0 -40 -12 0 0 0 1 0 rect.dat
3 16 -16.5 0 74 0 0 14 16.5 0 74
3 16 -40 0 -40 40 0 -40 0 0 -14
0 // understud with snap ring
1 16 0 4 0 1 0 0 0 -4 0 0 0 1 stud8a.dat
1 16 0 4 0 16 0 0 0 -1 0 0 0 16 4-4edge.dat
1 16 0 4 0 16 0 0 0 -1 0 0 0 16 4-4ndis.dat
1 16 0 0 0 14 0 0 0 -1 0 0 0 14 4-4edge.dat
1 16 0 0 0 14 0 0 0 1 0 0 0 14 4-4ndis.dat
1 16 0 0 0 14 0 0 0 4 0 0 0 14 4-4cyli.dat
1 16 0 24 0 1 0 0 0 1 0 0 0 1 dsnapridge.dat
0 // fittings
2 24 40 24 80 40 24 123.2713
4 16 40 24 80 36 24 80 36 24 112.7287 40 24 123.2713
1 16 40 14 120 0 -1 0 3 0 0 0 0 -3 2-4ndis.dat
1 16 40 14 120 0 1 0 3 0 0 0 0 -3 2-4edge.dat
4 16 40 5.7479 109.2521 40 11 117 40 11 120 40 5.7479 130.7479
4 16 40 17 120 40 17 117 40 24 80 40 24 123.2713
4 16 40 24 80 40 17 117 40 14 117 40 5.7479 109.2521
3 16 40 5.7479 109.2521 40 14 117 40 11 117
2 24 -40 24 123.2713 -40 24 80
4 16 -36 24 112.7287 -36 24 80 -40 24 80 -40 24 123.2713
1 16 -40 14 120 0 1 0 3 0 0 0 0 -3 2-4ndis.dat
1 16 -40 14 120 0 -1 0 3 0 0 0 0 -3 2-4edge.dat
4 16 -40 11 120 -40 11 117 -40 5.7479 109.2521 -40 5.7479 130.7479
4 16 -40 24 80 -40 17 117 -40 17 120 -40 24 123.2713
4 16 -40 14 117 -40 17 117 -40 24 80 -40 5.7479 109.2521
3 16 -40 14 117 -40 5.7479 109.2521 -40 11 117
Certify
Peter Blomberg [WUIt]
2025-07-18 22:30:41
Adapted earlier subfiles for 13355 and 25548 to also fit 65084 and 65085. Small adjustments required to all subparts to prevent overlap. Please consider 13355, 65084, 25548, and 65085 for any modifications. The red gaskets are in 65084s03 with the color of rubber red.
Added help lines for secondary hinge position. Kept origin as concluded in forum thread https://forums.ldraw.org/thread-28836.html
posted a vote of Certify
2025-07-22 13:19:25
Willy Tschager [Holly-Wood]
made the following comment.
2025-07-23 09:56:19
* Apparently 13355 and 65084 share geometry in common:
1 25 0 0 0 1 0 0 0 2.75 0 0 0 1 stug7-2x2.dat
4 25 -40 24 -40 -36 24 -36 36 24 -36 40 24 -40
3 25 36 4 -36 -36 4 -36 0 4 -16
3 25 0 4 16 -18.5 4 71 18.5 4 71
4 25 -40 24 -40 40 24 -40 40 0 -40 -40 0 -40
3 25 -16.5 0 74 0 0 14 16.5 0 74
3 25 -40 0 -40 40 0 -40 0 0 -14
1 25 0 4 0 1 0 0 0 -4 0 0 0 1 stud8a.dat
1 25 0 0 0 14 0 0 0 1 0 0 0 14 4-4ndis.dat
Question is why you didn't sub it as well?
2025-07-24 07:59:53
These are common, but not part of the halves that were subbed. One would therefore need to make a separate subpart either for this common geometry alone or the whole that includes two references to the previously subbed half. Either works for me. However, I originally decided not to add another file to be reviewed separately. I wagered that copying 8 lines was less trouble.
Parts 13355, 65084, 65095, and 25548 shares a common snapping hole geometry that is larger than the snapping ridge (dsnapridge.dat). Here, I figured that it already would have been made into a primitive should such a subpart be desired. I chose not to create it. For what it's worth, I'd prefer having a primitive for the snapping whole.
2025-07-24 09:26:35
* I'm fine with the symmetrical 65084s01 and would just sub the common geometry in "yet" another sub. But your choice.
