Unofficial File parts/s/65084s03.dat
~Duplo Plate  2 x  2 with Hinge Extended on Side and Red Gaskets - Half Hinge
0 ~Duplo Plate  2 x  2 with Hinge Extended on Side and Red Gaskets - Half Hinge
0 Name: s\65084s03.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\13355s03.dat
0 // gasket
2 24 20.5 28 1.5 20.5 28 -1.5
2 24 20.5 28 1.5 22.5 28 1.5
2 24 20.5 28 -1.5 22.5 28 -1.5
2 24 20.5 21 1.5 20.5 21 -1.5
2 24 20.5 21 1.5 20.5 28 1.5
2 24 20.5 21 -1.5 20.5 28 -1.5
2 24 22.5 19 1.5 20.5 21 1.5
2 24 22.5 19 -1.5 20.5 21 -1.5
4 324 22.5 28 1.5 22.5 28 -1.5 20.5 28 -1.5 20.5 28 1.5
4 324 20.5 28 1.5 20.5 28 -1.5 20.5 21 -1.5 20.5 21 1.5
4 324 20.5 21 1.5 20.5 21 -1.5 22.5 19 -1.5 22.5 19 1.5
4 324 22.5 28 -1.5 22.5 19 -1.5 20.5 21 -1.5 20.5 28 -1.5
4 324 20.5 21 1.5 22.5 19 1.5 22.5 28 1.5 20.5 28 1.5
1 324 37 19 0 0 -1 0 3 0 0 0 0 3 4-4disc.dat
1 324 31.25 28 0 1.5 0 0 0 -1 0 0 0 1.5 4-4disc.dat
0 // inner cyl
1 16 33.25 10.74792 0 6.75 0 0 0 1 0 0 0 10.74792 rect.dat
0 // front side of down peg
1 16 22.5 25 3.2713 0 17.5 0 4 0 0 0 0 4 1-4cylo.dat
4 16 40 25 7.2713 22.5 25 7.2713 22.5 17.5541 7.2713 40 17.5541 7.2713
0 // back side of down peg
1 16 22.5 25 -3.2713 0 13.5 0 4 0 0 0 0 -4 1-4cylo.dat
4 16 22.5 17.5541 -7.2713 22.5 25 -7.2713 36 25 -7.2713 26.5 17.5541 -7.2713
3 16 26.5 17.5541 -7.2713 36 25 -7.2713 36 17.5541 -7.2713
2 24 26.5 17.5541 -7.2713 36 17.5541 -7.2713
0 // bottom
1 16 31.25 29 0 1.5 0 0 0 -1 0 0 0 1.5 4-4cylo.dat
1 16 31.25 29 0 1.5 0 0 0 -1 0 0 0 1.5 4-4ndis.dat
4 16 22.5 29 -3.2713 22.5 29 3.2713 29.75 29 0 29.75 29 -1.5
3 16 29.75 29 1.5 29.75 29 0 22.5 29 3.2713
4 16 31.25 29 1.5 29.75 29 1.5 22.5 29 3.2713 40 29 3.2713
3 16 32.75 29 1.5 31.25 29 1.5 40 29 3.2713
4 16 22.5 29 -3.2713 29.75 29 -1.5 31.25 29 -1.5 36 29 -3.2713
4 16 36 29 -3.2713 32.75 29 0 32.75 29 1.5 40 29 3.2713
3 16 32.75 29 0 36 29 -3.2713 32.75 29 -1.5
3 16 32.75 29 -1.5 36 29 -3.2713 31.25 29 -1.5
3 16 36 29 -7.2713 36 29 -3.2713 40 29 3.2713
0 // corner box inner surface
4 16 36 29 -40 36 13.4349 -13.4349 36 17.5541 -7.2713 36 25 -7.2713
1 16 36 25 -3.2713 0 1 0 4 0 0 0 0 -4 1-4ndis.dat
3 16 36 29 -40 36 25 -7.2713 36 29 -7.2713
2 24 36 17.5541 -7.2713 36 25 -7.2713
2 24 36 29 -40 36 29 -7.2713
2 24 36 29 -7.2713 36 29 -3.2713
0 // outer surfaces
1 16 37 19 0 0 -3 0 3 0 0 0 0 3 4-4edge.dat
1 16 40 19 0 0 -3 0 3 0 0 0 0 3 2-4edge.dat
1 16 40 19 0 0 -3 0 3 0 0 0 0 3 4-4cyli.dat
1 16 40 19 0 0 -1 0 3 0 0 0 0 3 2-4ndis.dat
1 16 40 25 3.2713 0 -1 0 4 0 0 0 0 4 1-4chrd.dat
4 16 40 22 3 40 22 0 40 29 3.2713 40 25 7.2713
4 16 40 22 3 40 25 7.2713 40 17.5541 7.2713 40 19 3
4 16 40 16 3 40 19 3 40 17.5541 7.2713 40 13.4349 13.4349
2 24 40 25 7.2713 40 17.5541 7.2713
2 24 22.5 17.5541 7.2713 40 17.5541 7.2713
0 // 5 decimals needed
4 16 40 16 0 40 16 3 40 13.4349 13.4349 40 10.74792 10.74792
Certify
Peter Blomberg [WUIt]
2025-07-18 22:30:41
Adapted earlier subfiles for 13355 and 25548 to also fit 65084 and 65085. Small adjustments required to all subparts to prevent overlap. Please consider 13355, 65084, 25548, and 65085 for any modifications. The red gaskets are in 65084s03 with the color of rubber red.
Added help lines for secondary hinge position. Kept origin as concluded in forum thread https://forums.ldraw.org/thread-28836.html
posted a vote of Certify
2025-07-22 13:18:37
Willy Tschager [Holly-Wood]
made the following comment.
2025-07-23 09:51:39
* Rect
