Unofficial File parts/48933ps2.dat
Wedge  4 x  4 Triple with Stud Notches and SW Sand Green and Light Yellow Pattern
0 Wedge  4 x  4 Triple with Stud Notches and SW Sand Green and Light Yellow Pattern
0 Name: 48933ps2.dat
0 Author: Jeff Jones [notmaster]
0 !CATEGORY Wedge
0 !KEYWORDS Bricklink 48933pb035, Episode 2, Episode II, Jango Fett's Slave 1
0 !KEYWORDS Rebrickable 48933pr0008, Set 4487, Star Wars
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\48933s01.dat
1 18 0 0 0 1 0 0 0 1 0 0 0 1 s\6069ps2a.dat
1 378 0 0 0 1 0 0 0 1 0 0 0 1 s\6069ps2b.dat
4 16 20 0 -10 -20 0 -10 -18 2 -16 18 2 -16
3 16 18 2 -16 20 2 -16 20 0 -10
3 16 -20 2 -16 -18 2 -16 -20 0 -10
4 16 -20 0 -10 -20 0 10 -40 20 10 -40 20 -10
4 16 -20 2 -16 -20 0 -10 -40 20 -10 -27 8.667 -15.001
4 16 -40 20 -10 -37.98 20 -16.07 -25 9 -22.001 -27 8.667 -15.001
3 16 -25 9 -22.001 -37.98 20 -16.07 -34.02 20 -27.93
4 16 -31.98 20 -34.07 -25.668 13 -31.999 -25 9 -22.001 -34.02 20 -27.93
3 16 -25.668 13 -31.999 -31.98 20 -34.07 -28.334 19.333 -43.001
3 16 -28.334 19.333 -43.001 -31.98 20 -34.07 -28.02 20 -45.93
4 16 -28.334 19.333 -43.001 -28.02 20 -45.93 -20 20 -70 -20 19.333 -68
4 16 20 19.333 -68 -20 19.333 -68 -20 20 -70 20 20 -70
3 16 31.98 20 -34.07 28.334 19.333 -43.001 28.02 20 -45.93
3 16 31.98 20 -34.07 25.668 13 -31.999 28.334 19.333 -43.001
3 16 37.98 20 -16.07 25 9 -22.001 34.02 20 -27.93
4 16 20 20 -70 28.02 20 -45.93 28.334 19.333 -43.001 20 19.333 -68
4 16 25 9 -22.001 25.668 13 -31.999 31.98 20 -34.07 34.02 20 -27.93
4 16 25 9 -22.001 37.98 20 -16.07 40 20 -10 27 8.667 -15.001
4 16 40 20 10 20 0 10 20 0 -10 40 20 -10
4 16 40 20 -10 20 0 -10 20 2 -16 27 8.667 -15.001
2 24 -20 0 -10 -40 20 -10
2 24 -20 0 -10 -20 2 -16
2 24 -20 19.333 -68 -20 20 -70
2 24 20 19.333 -68 20 20 -70
2 24 20 0 -10 20 2 -16
2 24 20 0 -10 40 20 -10
Not releaseable Errors Found (HN) Errors Found (HN)
Hold
Orion Pobursky [OrionP]
2025-08-05 18:24:40
made the following comment.
2025-08-05 19:51:50
Somewhat sceptical this is Light Yellow (same goes for the older part).
On the real part it looks more like poorly matched regular yellow. This would correspond to the matching area on on the minifig scale Slave I from 2002, where it's also regular Yellow.
2025-08-05 20:07:04
your right also the pattern should be centered instead of the front and the sides should be more rounded
2026-03-10 17:54:27
bump
2026-03-10 18:01:28
This is a good example of how to not vote.
The file has errors, which leads to no one wanting to vote on it, and since there is no Hold vote no one is allowed to fix it, and every one is waiting for you to fix it. Sad.
2026-03-10 18:26:09
you got top view???? of part
posted a vote of Hold
2026-03-10 21:12:57
Hold for the reason stated above.
