Unofficial File parts/s/18849s01.dat
0 ~Keychain Minifig Hips without Patternable Areas
0 Name: s\18849s01.dat
0 // neck
1 16 0 -46.5 0 2 0 0 0 1 0 0 0 2 4-4ring1.dat
1 16 0 -46.5 0 2 0 0 0 1 0 0 0 2 4-4ring2.dat
1 16 0 -46.5 0 6 0 0 0 1 0 0 0 6 4-4edge.dat
1 16 0 -46.5 0 6 0 0 0 19 0 0 0 6 4-4cyli.dat
1 16 0 -6.5 0 2 0 0 0 -40 0 0 0 2 4-4cylc.dat
0 // connector
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\18849s02.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 -1 s\18849s02.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 -1 s\18849s02.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\18849s02.dat
1 16 4.2426 -14.1213 0 0 -1 0 0 0 .8787 4.2426 0 0 rect3.dat
1 16 4.2426 -21.25 0 0 -1 0 0 0 -6.25 4.2426 0 0 rect3.dat
1 16 -4.2426 -21.25 0 0 1 0 0 0 -6.25 4.2426 0 0 rect3.dat
1 16 -4.2426 -14.1213 0 0 1 0 0 0 .8787 4.2426 0 0 rect3.dat
3 16 6 -27.5 0 4.2426 -27.5 -4.2426 4.2426 -27.5 4.2426
3 16 -6 -27.5 0 -4.2426 -27.5 4.2426 -4.2426 -27.5 -4.2426
4 16 -4.2426 -13.2426 4.2426 -5.5434 -11.2962 6 -5.5434 -11.2962 -6 -4.2426 -13.2426 -4.2426
4 16 5.5434 -11.2962 -6 5.5434 -11.2962 6 4.2426 -13.2426 4.2426 4.2426 -13.2426 -4.2426
4 16 5.8012 -10 -3 5.8012 -10 3 5.5434 -11.2962 6 5.5434 -11.2962 -6
4 16 -5.5434 -11.2962 6 -5.8012 -10 3 -5.8012 -10 -3 -5.5434 -11.2962 -6
1 16 5.9006 -9.5 0 -.0994 -1 0 -.5 0 0 0 0 3 rect2p.dat
1 16 5.7717 -7.8519 0 -.2283 -1 0 1.1481 0 0 0 0 3 rect2p.dat
1 16 4.893 -5.7306 0 -.6504 -1 0 .9732 0 0 0 0 3 rect2p.dat
1 16 3.2694 -4.107 0 -.9732 0 0 .6504 -1 0 0 0 3 rect2p.dat
1 16 1.8981 -3.3774 0 -.3981 0 0 .0792 -1 0 0 0 3 rect2p.dat
1 16 -5.9006 -9.5 0 .0994 1 0 -.5 0 0 0 0 3 rect2p.dat
1 16 -5.7717 -7.8519 0 .2283 1 0 1.1481 0 0 0 0 3 rect2p.dat
1 16 -4.893 -5.7306 0 .6504 1 0 .9732 0 0 0 0 3 rect2p.dat
1 16 -3.2694 -4.107 0 .9732 0 0 .6504 -1 0 0 0 3 rect2p.dat
1 16 -1.8981 -3.3774 0 .3981 0 0 .0792 -1 0 0 0 3 rect2p.dat
1 16 1.5 -1.6491 0 0 -1 0 1.6491 0 0 0 0 3 rect.dat
1 16 -1.5 -1.6491 0 0 1 0 1.6491 0 0 0 0 3 rect.dat
1 16 8.75 0 0 7.25 0 0 0 1 0 0 0 3 rect2p.dat
1 16 -8.75 0 0 7.25 0 0 0 1 0 0 0 3 rect2p.dat
2 24 -16 0 -6 16 0 -6
2 24 -16 0 6 16 0 6
4 16 -16 0 -3 -16 0 3 -18 0 10 -18 0 -10
4 16 16 0 3 16 0 -3 18 0 -10 18 0 10
4 16 -16 0 6 16 0 6 18 0 10 -18 0 10
4 16 5.8012 -10 6 16 0 6 -16 0 6 -5.8012 -10 6
4 16 16 0 -6 -16 0 -6 -18 0 -10 18 0 -10
4 16 5.8012 -10 -6 -5.8012 -10 -6 -16 0 -6 16 0 -6
3 16 0 -15 -6 -5.8012 -10 -6 5.8012 -10 -6
3 16 0 -15 6 5.8012 -10 6 -5.8012 -10 6
5 24 -5.5434 -6.7038 3 -5.5434 -6.7038 -3 -4.2426 -4.7574 -3 -6 -9 3
5 24 -2.2962 -3.4566 -3 -2.2962 -3.4566 3 -1.5 -3.2982 -3 -4.2426 -4.7574 3
5 24 -4.2426 -4.7574 3 -4.2426 -4.7574 -3 -2.2962 -3.4566 -3 -5.5434 -6.7038 3
5 24 5.5434 -11.2962 -6 5.5434 -11.2962 6 4.2426 -13.2426 4.2426 5.8012 -10 -3
5 24 4.2426 -4.7574 -3 4.2426 -4.7574 3 5.5434 -6.7038 3 2.2962 -3.4566 -3
5 24 6 -9 3 6 -9 -3 5.5434 -6.7038 -3 5.8012 -10 -3
5 24 -6 -9 3 -6 -9 -3 -5.8012 -10 -3 -5.5434 -6.7038 -3
5 24 5.5434 -6.7038 -3 5.5434 -6.7038 3 4.2426 -4.7574 -3 6 -9 3
5 24 2.2962 -3.4566 -3 2.2962 -3.4566 3 1.5 -3.2982 -3 4.2426 -4.7574 3
5 24 -5.5434 -11.2962 6 -5.5434 -11.2962 -6 -4.2426 -13.2426 -4.2426 -5.8012 -10 3
0 // hip
1 16 0 0 0 18 0 0 0 1 0 0 0 10 recte4.dat
1 16 0 3 10 0 0 18 3 0 0 0 -1 0 rect2p.dat
1 16 0 6 -8.155 18 0 0 0 -1 0 0 0 1.845 rect.dat
1 16 0 6 8.155 18 0 0 0 -1 0 0 0 1.845 rect.dat
2 24 -18 0 -10 -18 6 -10
2 24 18 0 -10 18 6 -10
3 16 18 0 10 18 0 -10 18 3.2501 0
3 16 -18 3.2501 0 -18 0 -10 -18 0 10
1 16 2 12 0 0 -4 0 0 0 -8.75 8.75 0 0 1-8cyli.dat
1 16 2 12 0 0 -4 0 0 0 8.75 8.75 0 0 3-16cyli.dat
1 16 0 20.0841 0 2 0 0 0 -1 0 0 0 3.3486 rect.dat
3 16 2 20.0841 -3.3486 2 20.0841 3.3486 2 3.25 0
3 16 -2 20.0841 3.3486 -2 20.0841 -3.3486 -2 3.25 0
1 16 -9.92 12 0 0 7.92 0 3 0 0 0 0 3 4-4cylc.dat
1 16 9.92 12 0 0 -7.92 0 3 0 0 0 0 3 4-4cylc.dat
Needs 2 More Votes (N)
Has Uncertified Subfiles
Rene Rechthaler [Blechtaler]
2025-08-08 13:34:51
2026-04-20 23:11:32
added flat spot at the bottom of the hip disc (visual differentiation from normal hips)
