Unofficial File parts/7230.dat
Wheel  6 x 56 with Center Axle Hole, 6 Pin Holes, Curved Spokes
0 Wheel 6 x 56 with Center Axle Hole, 6 Pin Holes, Curved Spokes 0 Name: 7230.dat 0 Author: Rene Rechthaler [Blechtaler] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !CATEGORY Wheel 0 !HISTORY 2025-08-01 {LEGO Instructions App} Original part shape 0 !HISTORY 2025-08-15 [Blechtaler] File preparation for LDraw Parts Tracker
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\7230s01.dat 1 16 0 0 0 1 0 0 0 -1 0 0 0 1 s\7230s01.dat 1 16 0 0 0 -1 0 0 0 -1 0 0 0 1 s\7230s01.dat 1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\7230s01.dat 1 16 0 0 0 1 0 0 0 0 -1 0 20 0 axl3hole.dat 1 16 0 0 0 6 0 0 0 0 6 0 1 0 4-4ering.dat 1 16 0 0 20 6 0 0 0 0 6 0 -1 0 4-4ering.dat 1 16 0 0 0 3 0 0 0 0 3 0 1 0 4-4ring2.dat 1 16 0 0 20 3 0 0 0 0 3 0 -1 0 4-4ring2.dat 1 16 0 20 0 1 0 0 0 0 1 0 1 0 peghole.dat 1 16 0 20 20 1 0 0 0 0 1 0 -1 0 peghole.dat 0 BFC INVERTNEXT 1 16 0 20 2 6 0 0 0 0 6 0 16 0 4-4cyli.dat 1 16 0 -20 0 1 0 0 0 0 1 0 1 0 peghole.dat 1 16 0 -20 20 1 0 0 0 0 1 0 -1 0 peghole.dat 0 BFC INVERTNEXT 1 16 0 -20 2 6 0 0 0 0 6 0 16 0 4-4cyli.dat 1 16 11.4566 0 2 0 0 .5 3.6361 0 0 0 -2 0 box3u8p.dat 1 16 22.6844 0 1 0 1 0 3.6361 0 0 0 0 1 rect2p.dat 1 16 -11.4566 0 2 0 0 .5 3.6361 0 0 0 -2 0 box3u8p.dat 1 16 -22.6844 0 1 0 -1 0 3.6361 0 0 0 0 1 rect2p.dat 4 16 22.6844 -3.6361 2 21.5631 -4 2 21.5631 4 2 22.6844 3.6361 2 4 16 21.5631 4 2 21.5631 -4 2 17.3205 -4 2 17.3205 4 2 4 16 17.3205 4 2 17.3205 -4 2 13.0779 -4 2 13.0779 4 2 4 16 11.9566 3.6361 2 13.0779 4 2 13.0779 -4 2 11.9566 -3.6361 2 4 16 -13.0779 4 2 -11.9566 3.6361 2 -11.9566 -3.6361 2 -13.0779 -4 2 4 16 -17.3205 4 2 -13.0779 4 2 -13.0779 -4 2 -17.3205 -4 2 4 16 -21.5631 4 2 -17.3205 4 2 -17.3205 -4 2 -21.5631 -4 2 4 16 -22.6844 3.6361 2 -21.5631 4 2 -21.5631 -4 2 -22.6844 -3.6361 2 3 16 30 0 0 22.6844 -3.6361 0 22.6844 3.6361 0 3 16 10.9566 3.6361 2 10.9566 -3.6361 2 9 0 2 3 16 -9 0 2 -10.9566 -3.6361 2 -10.9566 3.6361 2 3 16 -22.6844 3.6361 0 -22.6844 -3.6361 0 -30 0 0 5 24 26 0 20 26 0 6 25.7764 3.393 6 25.7764 -3.393 6 5 24 -26 0 20 -26 0 6 -25.7764 3.393 6 -25.7764 -3.393 6 0 // Arm intersection lines + condlines 2 24 0 42.255 12.069 0 43.804 8.688 2 24 58.3847 0 2.247 56.7323 0 1.63 2 24 -56.7323 0 1.63 -57.9026 0 .383 2 24 0 -43.258 5.955 0 -41.714 3.904 2 24 -58.3847 0 2.247 -56.7323 0 1.63 2 24 56.7323 0 1.63 57.9026 0 .383 2 24 57.9026 0 .383 61.8141 0 -1.129 2 24 0 -43.804 8.688 0 -43.258 5.955 2 24 0 43.804 8.688 0 43.258 5.955 2 24 0 -42.255 12.069 0 -43.804 8.688 2 24 -57.9026 0 .383 -61.8141 0 -1.129 2 24 0 43.258 5.955 0 41.714 3.904 2 24 0 39.981 15.024 0 41.25 13.646 2 24 0 41.25 13.646 0 42.255 12.069 2 24 0 -41.25 13.646 0 -42.255 12.069 2 24 0 39.268 15.139 0 39.981 15.024 2 24 0 -39.981 15.024 0 -41.25 13.646 2 24 -63.194 0 2.078 -58.3847 0 2.247 2 24 -61.8141 0 -1.129 -65.7588 0 -1.183 2 24 63.194 0 2.078 58.3847 0 2.247 2 24 61.8141 0 -1.129 65.7588 0 -1.183 2 24 0 -38.425 3.213 0 -33.876 2.873 2 24 0 41.714 3.904 0 38.425 3.213 2 24 0 -41.714 3.904 0 -38.425 3.213 2 24 0 33.876 2.873 0 30 2.5689 2 24 0 38.425 3.213 0 33.876 2.873 2 24 0 -33.876 2.873 0 -30 2.5689 2 24 0 -39.268 15.139 0 -39.981 15.024 2 24 63.194 0 2.078 65.7588 0 1.696 2 24 -63.194 0 2.078 -65.7588 0 1.696 5 24 0 36.918 6.408 0 38.782 14.559 1.338 39.151 14.666 -1.338 39.151 14.666 5 24 0 32.913 6.693 0 36.918 6.408 .894 37.254 6.367 -.894 37.254 6.367 5 24 0 -38.782 14.559 0 -39.268 15.139 .988 -39.563 15.236 -.988 -39.563 15.236 5 24 0 -32.913 6.693 0 -36.918 6.408 .894 -37.254 6.367 -.894 -37.254 6.367 5 24 0 38.782 14.559 0 39.268 15.139 -.988 39.563 15.236 .988 39.563 15.236 5 24 0 -36.918 6.408 0 -38.782 14.559 1.338 -39.151 14.666 -1.338 -39.151 14.666
None
2025-08-15 22:01:43
anyone who wants to rework the "organic arms"?
2025-08-19 16:50:52
Philo, thanks for the subparting!
Philippe Hurbain [Philo]
made the following comment.
2025-08-19 18:24:17
2025-08-19 19:05:53
how is the nomenclature here?
width: just the outer rim or total width? (part has deep hub and small, shifted rim)
does anyone have the part for the real diameter? or should it just use D56mm? (approx. from D7 studs)
edited the part header.
2025-08-19 20:16:34
Header Edits
description:
Wheel 7 x 7 with Center Axle Hole, 6 Pin Holes, Curved Spokes
to
Comment:
The "width" is only the rim, not including the spokes or hub.
Why is the diameter 138.74 ldu? (Rounded of to 56mm in the description)
2025-08-20 10:18:28
thanks for the renaming!
geometrically it should be D140, but Philo had the good idea to scale it a bit so it would need only one ring prim (was also closer to the original mesh)
2025-12-23 08:07:55
Header Edits
description:
to
Comment:
