Unofficial File parts/5252.dat
External site data provided by Rebrickable.com View on Rebrickable View on BrickLink View on Brickset
Brick  2 x  2 with Rounded Slab and Axlehole
0 Brick 2 x 2 with Rounded Slab and Axlehole 0 Name: 5252.dat 0 Author: Philippe Hurbain [Philo] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !CATEGORY Brick 0 !KEYWORDS Photo Holder, Ribs
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\5252s02.dat 1 16 0 12 -20 20 0 0 0 0 12 0 1 0 rect.dat 1 16 0 14.05 -23.85 19.4 0 0 0 4.45 0 0 0 -3.85 box2-7.dat 0 BFC INVERTNEXT 1 16 0 12.8 -22 19.4 0 0 0 3.2 0 0 0 -2 box2-7.dat 2 24 -19.4 16 -20 19.4 16 -20 2 24 -19.4 18.5 -20 19.4 18.5 -20 2 24 19.4 16 -20 19.4 18.5 -20 1 16 10.4 9.6 -24 9 0 0 0 0 -9 0 -3.7 0 1-4cylo.dat 1 16 10.4 9.6 -24 9 0 0 0 0 -9 0 -1 0 1-4chrd.dat 1 16 10.4 9.6 -27.7 9 0 0 0 0 -9 0 1 0 1-4chrd.dat 4 16 19.4 16 -24 19.4 9.6 -24 19.4 9.6 -27.7 19.4 18.5 -27.7 4 16 19.4 16 -20 19.4 16 -24 19.4 18.5 -27.7 19.4 18.5 -20 2 24 -19.4 18.5 -20 -19.4 16 -20 1 16 -10.4 9.6 -24 -9 0 0 0 0 -9 0 -3.7 0 1-4cylo.dat 1 16 -10.4 9.6 -24 -9 0 0 0 0 -9 0 -1 0 1-4chrd.dat 1 16 -10.4 9.6 -27.7 -9 0 0 0 0 -9 0 1 0 1-4chrd.dat 4 16 -19.4 9.6 -27.7 -19.4 9.6 -24 -19.4 16 -24 -19.4 18.5 -27.7 4 16 -19.4 18.5 -27.7 -19.4 16 -24 -19.4 16 -20 -19.4 18.5 -20 4 16 -19.4 9.6 -24 -10.4 0.6 -24 10.4 0.6 -24 19.4 9.6 -24 4 16 10.4 0.6 -27.7 -10.4 0.6 -27.7 -19.4 9.6 -27.7 19.4 9.6 -27.7 1 16 0 0.6 -25.85 10.4 0 0 0 1 0 0 0 1.85 rect2p.dat 1 16 0 16 -20 1 0 0 0 1 0 0 0 1 s\37452s01.dat 1 16 14 16 -20 1 0 0 0 1 0 0 0 1 s\37452s01.dat 1 16 -14 16 -20 -1 0 0 0 1 0 0 0 1 s\37452s01.dat 1 16 -7 16 -24 1 0 0 0 1 0 0 0 -1 s\37452s01.dat 1 16 7 16 -24 1 0 0 0 1 0 0 0 -1 s\37452s01.dat 1 16 5 18.5 -20 1 0 0 0 1 0 0 0 1 s\5252s01.dat 1 16 14.6 18.5 -20 1 0 0 0 1 0 0 0 1 s\5252s01.dat 1 16 -5 18.5 -20 -1 0 0 0 1 0 0 0 1 s\5252s01.dat 1 16 -14.6 18.5 -20 -1 0 0 0 1 0 0 0 1 s\5252s01.dat
Not releaseable Awaiting Admin Review (CCN) Awaiting Admin Review (CCN)
User Vote
GeraldLasser Certify
RainbowDolphin Certify
2025-08-24 16:56:58
Gerald Lasser [GeraldLasser]
made the following comment.
2025-08-24 18:14:45
May be we shoudl adapt s\62712s02.dat to be more versatile, to fit parts licke this?
posted a vote of Hold
2025-08-24 18:16:07
needs an ering to pad the axlehole
2025-08-25 13:58:54
Mmmmhhh... I do have an ering !?. I also put one at the base of the axle primitive at the junction with cylinder, but it's far from perfect anyway. I wonder if it's really useful, or if there is a better solution...
When we settle on this, I'll do a common subpart.
2025-08-25 14:15:31
I found a kludge that gives a good visual result: instead of the ering, I use a cyli that overlaps the axle primitive cylinder. This way, the unmatching junction with primitive substitution is hidden. Minor drawback, part of the axlehole prim and cylinder quads overlap.
1 16 0 16 0 0 0 6 0 -1 0 6 0 0 4-4ering.dat
changed to
1 16 0 16 0 0 0 6 0 -10 0 6 0 0 4-4cyli.dat
2025-08-25 14:44:45
Used common subpart, improved axlehole
2025-08-25 15:16:05
I only had a look at the missing ering on top, not the conversion from axle to cyli.
the overlap doesn't hurt, I cert now, need to think about it, I need to try the looks of th eering solution
posted a vote of Certify
2025-08-25 15:16:29
2025-08-25 22:03:49
