Unofficial File parts/s/65082s01.dat
0 ~Duplo Arm 3L with Locking Ring without Locking Finger
0 Name: s\65082s01.dat
0 !HISTORY 2025-08-26 [KnightOfTarenta] subfiled from 65082p01 by Philippe Hurbain [Philo]
1 16 0 0 0 1 0 0 0 1 0 0 0 1 dhingepin2.dat
1 16 0 0 120 1 0 0 0 0 1 0 -1 0 dhingesocket.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 dhingepin2.dat
1 16 0 0 120 -1 0 0 0 0 1 0 -1 0 dhingesocket.dat
1 16 -15.8 0 0 0 31.6 0 0 0 19 19 0 0 4-4cylo.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\21996s02.dat
1 16 0 0 0 1 0 0 0 -1 0 0 0 1 s\21996s02.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\21996s02.dat
1 16 0 0 0 -1 0 0 0 -1 0 0 0 1 s\21996s02.dat
1 16 0 2 28.30115 -15.8 0 0 0 -1 0 0 0 9.69885 rect2p.dat
1 16 0 9 45.5 0 0 15.8 7 -1 0 7.5 0 0 rect1.dat
1 16 0 16 56.09375 0 0 15.8 0 -1 0 3.09375 0 0 rect1.dat
4 16 -15.8 16 59.1875 -22.5 3 73 22.5 3 73 15.8 16 59.1875
1 16 0 -2 28.30115 15.8 0 0 0 1 0 0 0 9.69885 rect2p.dat
1 16 0 -9 45.5 0 0 -15.8 -7 1 0 7.5 0 0 rect1.dat
1 16 0 -16 56.09375 0 0 -15.8 0 1 0 3.09375 0 0 rect1.dat
4 16 22.5 -3 73 -22.5 -3 73 -15.8 -16 59.1875 15.8 -16 59.1875
1 16 0 0 73 0 0 22.5 -3 0 0 0 -1 0 rect.dat
1 16 22.5 0 90 0 1 0 4 0 0 0 0 -4 2-4ndis.dat
1 16 22.5 0 100 0 1 0 4 0 0 0 0 4 2-4ndis.dat
4 16 22.5 -5.8667 114.1333 22.5 5.8667 114.1333 22.5 4 104 22.5 -4 104
4 16 22.5 -5.8667 114.1333 22.5 -4 104 22.5 -4 86 22.5 -12 105.6061
4 16 22.5 -4 86 22.5 -3 73 22.5 -12 63.4375 22.5 -12 105.6061
4 16 22.5 -3 73 22.5 -4 86 22.5 4 86 22.5 3 73
4 16 22.5 4 86 22.5 4 104 22.5 5.8667 114.1333 22.5 12 105.6061
4 16 22.5 12 63.4375 22.5 3 73 22.5 4 86 22.5 12 105.6061
1 16 29.5 0 93.5 0 -1 0 4 0 0 0 0 -4 2-4ndis.dat
1 16 29.5 0 96 0 -1 0 4 0 0 0 0 4 2-4ndis.dat
1 16 29.5 0 120 0 -1 0 0 0 19 -19 0 0 1-8edge.dat
1 16 29.5 0 67 0 -3 0 0 0 19 19 0 0 1-8cylo.dat
1 16 29.5 0 67 0 -1 0 0 0 19 19 0 0 1-8tang.dat
2 24 29.5 13.0818 80.6709 26.5 10.9 82.129
2 24 29.5 13.0818 106.3291 29.5 13.0818 80.6709
4 16 29.5 0 101 29.5 0 100 29.5 4 100 29.5 13.0818 106.3291
4 16 29.5 13.0818 80.6709 29.5 13.0818 106.3291 29.5 4 100 29.5 10.7635 83.1082
4 16 29.5 10.7635 83.1082 29.5 4 100 29.5 4 89.5 29.5 7.2713 84.5541
4 16 29.5 0 89.5 29.5 0 86 29.5 3.7791 86 29.5 4 89.5
3 16 29.5 4 89.5 29.5 3.7791 86 29.5 7.2713 84.5541
1 16 29.5 0 120 0 -1 0 0 0 -19 -19 0 0 1-8edge.dat
1 16 29.5 0 67 0 -3 0 0 0 -19 19 0 0 1-8cylo.dat
1 16 29.5 0 67 0 -1 0 0 0 -19 19 0 0 1-8tang.dat
2 24 29.5 -13.0818 80.6709 26.5 -10.9 82.129
2 24 29.5 -13.0818 106.3291 29.5 -13.0818 80.6709
4 16 29.5 -4 100 29.5 0 100 29.5 0 101 29.5 -13.0818 106.3291
4 16 29.5 -4 100 29.5 -13.0818 106.3291 29.5 -13.0818 80.6709 29.5 -10.7635 83.1082
4 16 29.5 -4 89.5 29.5 -4 100 29.5 -10.7635 83.1082 29.5 -7.2713 84.5541
4 16 29.5 -3.7791 86 29.5 0 86 29.5 0 89.5 29.5 -4 89.5
3 16 29.5 -3.7791 86 29.5 -4 89.5 29.5 -7.2713 84.5541
4 16 26.5 0 70 26.5 10.9 86.129 26.5 -10.9 86.129 26.5 -3 69
3 16 26.5 -10.9 61 26.5 -3 69 26.5 -10.9 86.129
3 16 26.5 0 70 26.5 3 69 26.5 10.9 86.129
3 16 26.5 10.9 86.129 26.5 3 69 26.5 10.9 61
1 16 -22.5 0 90 0 -1 0 4 0 0 0 0 -4 2-4ndis.dat
1 16 -22.5 0 100 0 -1 0 4 0 0 0 0 4 2-4ndis.dat
4 16 -22.5 4 104 -22.5 5.8667 114.1333 -22.5 -5.8667 114.1333 -22.5 -4 104
4 16 -22.5 -4 86 -22.5 -4 104 -22.5 -5.8667 114.1333 -22.5 -12 105.6061
4 16 -22.5 -12 63.4375 -22.5 -3 73 -22.5 -4 86 -22.5 -12 105.6061
4 16 -22.5 4 86 -22.5 -4 86 -22.5 -3 73 -22.5 3 73
4 16 -22.5 5.8667 114.1333 -22.5 4 104 -22.5 4 86 -22.5 12 105.6061
4 16 -22.5 4 86 -22.5 3 73 -22.5 12 63.4375 -22.5 12 105.6061
1 16 -29.5 0 93.5 0 1 0 4 0 0 0 0 -4 2-4ndis.dat
1 16 -29.5 0 96 0 1 0 4 0 0 0 0 4 2-4ndis.dat
1 16 -29.5 0 120 0 1 0 0 0 19 -19 0 0 1-8edge.dat
1 16 -29.5 0 67 0 3 0 0 0 19 19 0 0 1-8cylo.dat
1 16 -29.5 0 67 0 1 0 0 0 19 19 0 0 1-8tang.dat
2 24 -29.5 13.0818 80.6709 -26.5 10.9 82.129
2 24 -29.5 13.0818 106.3291 -29.5 13.0818 80.6709
4 16 -29.5 4 100 -29.5 0 100 -29.5 0 101 -29.5 13.0818 106.3291
4 16 -29.5 4 100 -29.5 13.0818 106.3291 -29.5 13.0818 80.6709 -29.5 10.7635 83.1082
4 16 -29.5 4 89.5 -29.5 4 100 -29.5 10.7635 83.1082 -29.5 7.2713 84.5541
4 16 -29.5 3.7791 86 -29.5 0 86 -29.5 0 89.5 -29.5 4 89.5
3 16 -29.5 3.7791 86 -29.5 4 89.5 -29.5 7.2713 84.5541
1 16 -29.5 0 120 0 1 0 0 0 -19 -19 0 0 1-8edge.dat
1 16 -29.5 0 67 0 3 0 0 0 -19 19 0 0 1-8cylo.dat
1 16 -29.5 0 67 0 1 0 0 0 -19 19 0 0 1-8tang.dat
2 24 -29.5 -13.0818 80.6709 -26.5 -10.9 82.129
2 24 -29.5 -13.0818 106.3291 -29.5 -13.0818 80.6709
4 16 -29.5 0 101 -29.5 0 100 -29.5 -4 100 -29.5 -13.0818 106.3291
4 16 -29.5 -13.0818 80.6709 -29.5 -13.0818 106.3291 -29.5 -4 100 -29.5 -10.7635 83.1082
4 16 -29.5 -10.7635 83.1082 -29.5 -4 100 -29.5 -4 89.5 -29.5 -7.2713 84.5541
4 16 -29.5 0 89.5 -29.5 0 86 -29.5 -3.7791 86 -29.5 -4 89.5
3 16 -29.5 -4 89.5 -29.5 -3.7791 86 -29.5 -7.2713 84.5541
4 16 -26.5 -10.9 86.129 -26.5 10.9 86.129 -26.5 0 70 -26.5 -3 69
3 16 -26.5 -3 69 -26.5 -10.9 61 -26.5 -10.9 86.129
3 16 -26.5 3 69 -26.5 0 70 -26.5 10.9 86.129
3 16 -26.5 3 69 -26.5 10.9 86.129 -26.5 10.9 61
2 24 19.8 0 -28 19.8 0 -19
2 24 -19.8 0 -19 -19.8 0 -28
5 24 26.5 0 70 2 0 70 2 3 69 2 -3 69
5 24 -26.5 0 70 -2 0 70 -2 -3 69 -2 3 69
Needs 2 More Votes (N)
2025-08-25 22:47:28
Peter Blomberg [WUIt]
made the following comment.
2025-10-10 19:19:16
2025-10-16 02:58:16
*moved edges/conds to more appropriate file
2 5 -15.8 -16 59.1875 -15.8 -3 73
with a surface along
2 5 -15.8 -19 56 -31 -19 58
on the outer side. The edge line
2 24 -25 -19 56 -22.5 -12 63.4375
should not exist.
The bend at
2 5 -25 -7.071296997 38.928800521 -25 -19 51.5597
should be at
2 5 -31 -7.071296997 38.928800521 -31 -19 51.5597
These changes are needed in subfile s02
