Unofficial File parts/170877c.dat
0 Sticker 1.1 x 1.7 with Black Number "2" and Green Laurels
0 Name: 170877c.dat
0 Author: Max Seidenstücker [MaxSeidenstuecker]
0 !CATEGORY Sticker
0 !KEYWORDS BrickLink 6337stk01, Brickowl 293024, Rebrickable 170877
0 !KEYWORDS Set 6337 Fast Track Finish
1 16 0 -0.25 0 17 0 0 0 0.25 0 0 0 11 box5-12.dat
0 BFC NOCLIP
1 16 0 -0.25 0 1 0 0 0 1 0 0 0 1 s\821435js01.dat
1 16 0 -0.25 0 -1 0 0 0 1 0 0 0 1 s\821435js01.dat
1 15 0 -0.25 1.5 8 0 0 0 1 0 0 0 8 type-swiss721bt-bold-n2.dat
0 BFC CLIP
1 15 0 -0.25 0 1 0 0 0 1 0 0 0 1 s\821435js02.dat
1 15 0 -0.25 0 -1 0 0 0 1 0 0 0 1 s\821435js02.dat
1 15 0 -0.25 0 1 0 0 0 1 0 0 0 1 s\821435js03.dat
Awaiting Admin Review (CCN)
Willy Tschager [Holly-Wood]
2025-09-10 06:39:08
6337 - Fast Track Finish - stickers from sheet 170877 (track map and podium 1,2,3)
made the following comment.
2025-09-10 08:01:23
* The subs of this part have to be named:
170877cs01
170877cs02
170877cs03
the naming of the subs is not bound to the stickersheet number but the single stickers
170877cs01
170877cs02
170877cs03
2025-09-10 12:57:13
Applied naming scheme to leave space for one digit dimensions
track map sticker reworked:
- inlined subpart
- rotated
- stickerback
- flattenend geometry instead of layering
- as subpart became obsolete, moved 170877s06.dat to 170877s05.dat
- inlined subpart
- rotated
- stickerback
2025-09-10 13:45:30
* I will not comment on this or the other stickers but concentrate on 170877a. Once you got that right I'm happy to help with this one.
2025-09-11 23:39:55
The same set of stickers are already on the tracker (821435i,j,k) with way better and lower poly representation of the laurels. Close this and number 3 part from my efforts. They are not worth continuing then.
2025-09-12 15:12:08
In a case like this we need to figure out how we can reuse the previous version.
Are they identical in size, shape, colouring? => make an alias file.
Different size. Possible to scale? => make a scaled alias.
Are they different?
Printed on the same material? Transparent or solid (white) base?
Is there subfiles to be used, or need to be made? A set of subfiles, to use in both sets?
Are they different?
2025-09-15 06:24:07
https://www.bricklink.com/v2/catalog/catalogitem.page?S=6327#T=S&O={%22iconly%22:0}
and
https://www.bricklink.com/v2/catalog/catalogitem.page?S=6337-1#T=S&O={%22iconly%22:0}
and
2025-09-15 06:24:48
2025-09-16 16:48:31
170877b updated and relevant for discussion of similarities and differences of the mentioned parts.
2025-09-23 09:36:44
Reuse subfiles of 821435.
Can s.o. change the header to this variant with "" instead of word of number.
2025-09-23 09:38:10
Ignore the last comment, its already changed.
posted a vote of Certify
2025-09-23 11:12:03
2025-09-23 13:27:39
