Unofficial File parts/41531.dat
View official version of part
Technic Cylinder  4 x  4 x  2 with 3 Pin Holes and Center Bar
0 Technic Cylinder 4 x 4 x 2 with 3 Pin Holes and Center Bar 0 Name: 41531.dat 0 Author: Marc Schickele [samrotule] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 2.0 and CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS Connector Block, Turbine 0 !HISTORY 2005-10-01 [mchiles] Centered properly, outer ring completely redone in hi-res, BFC'ed 0 !HISTORY 2005-12-26 [mkennedy] Used cone for outer ring, more primitves, 1-12 primitves around indent 0 !HISTORY 2006-01-09 [mchiles] Fixed final 4 edge lines 0 !HISTORY 2009-09-03 [PTadmin] Official Update 2009-02 0 !HISTORY 2024-03-23 [OrionP] Updated ring primitives 0 !HISTORY 2024-03-24 [OrionP] Official Update 2024-02 0 !HISTORY 2025-09-27 [OrionP] Changed winding to CCW
0 // // edge, outer hole rim top - neg 2 24 -10 0 10 -9.239 -3.827 10 2 24 -9.239 3.827 10 -10 0 10 2 24 -7.787 6 10 -9.239 3.827 10 2 24 -9.239 -3.827 10 -7.787 -6 10 0 // edge, outer hole rim bottom - neg 2 24 -8.14 5.471 -2.266 -7.787 6 0 2 24 -8.14 5.471 -2.266 -8.998 4.187 -4.187 2 24 -8.998 4.187 -4.187 -9.239 3.827 -4.428 2 24 -9.549 2.266 -5.471 -9.239 3.827 -4.428 2 24 -9.549 2.266 -5.471 -10 0 -5.922 2 24 -10 0 -5.922 -9.549 -2.266 -5.471 2 24 -9.239 -3.827 -4.428 -9.549 -2.266 -5.471 2 24 -9.239 -3.827 -4.428 -8.998 -4.187 -4.187 2 24 -8.998 -4.187 -4.187 -8.14 -5.471 -2.266 2 24 -7.787 -6 0 -8.14 -5.471 -2.266 0 // face of cylinder - neg 3 16 -10 0 10 -10 0 -5.922 -9.549 -2.266 -5.471 3 16 -9.549 -2.266 -5.471 -9.239 -3.827 10 -10 0 10 3 16 -9.549 -2.266 -5.471 -9.239 -3.827 -4.428 -9.239 -3.827 10 3 16 -9.239 -3.827 10 -9.239 -3.827 -4.428 -8.998 -4.187 -4.187 4 16 -8.998 -4.187 -4.187 -7.787 -6 0 -7.787 -6 10 -9.239 -3.827 10 3 16 -8.998 -4.187 -4.187 -8.14 -5.471 -2.266 -7.787 -6 0 3 16 -10 0 -5.922 -10 0 10 -9.549 2.266 -5.471 3 16 -9.549 2.266 -5.471 -10 0 10 -9.239 3.827 10 3 16 -9.549 2.266 -5.471 -9.239 3.827 10 -9.239 3.827 -4.428 3 16 -8.998 4.187 -4.187 -9.239 3.827 -4.428 -9.239 3.827 10 4 16 -8.998 4.187 -4.187 -9.239 3.827 10 -7.787 6 10 -7.787 6 0 3 16 -7.787 6 0 -8.14 5.471 -2.266 -8.998 4.187 -4.187 0 // curvy bottom - neg 3 16 -9.239 3.827 -4.428 -8.998 4.187 -4.187 -18 4.187 -4.187 4 16 -18 4.187 -4.187 -18 2.266 -5.471 -9.549 2.266 -5.471 -9.239 3.827 -4.428 4 16 -18 -4.187 -4.187 -9.239 -3.827 -4.428 -9.549 -2.266 -5.471 -18 -2.266 -5.471 3 16 -18 -4.187 -4.187 -8.998 -4.187 -4.187 -9.239 -3.827 -4.428 4 16 -18 -6 0 -7.787 -6 0 -8.14 -5.471 -2.266 -18 -5.471 -2.266 4 16 -18 -5.471 -2.266 -8.14 -5.471 -2.266 -8.998 -4.187 -4.187 -18 -4.187 -4.187 4 16 -18 6 0 -18 5.471 -2.266 -8.14 5.471 -2.266 -7.787 6 0 4 16 -18 5.471 -2.266 -18 4.187 -4.187 -8.998 4.187 -4.187 -8.14 5.471 -2.266 4 16 -18 2.266 -5.471 -18 0 -5.922 -10 0 -5.922 -9.549 2.266 -5.471 4 16 -18 -2.266 -5.471 -9.549 -2.266 -5.471 -10 0 -5.922 -18 0 -5.922 0 // conditional inside lines - neg 5 24 -9.239 3.827 -4.428 -9.239 3.827 10 -7.787 6 10 -10 0 10 5 24 -10 0 10 -10 0 -5.922 -9.549 -2.266 -5.471 -9.239 3.827 -4.428 5 24 -9.239 -3.827 10 -9.239 -3.827 -4.428 -8.998 -4.187 -4.187 -10 0 10 0 // edge, next far negative - pos 2 24 18 8 0.197 18 8 10 2 24 18 -8 10 18 -8 0.197 0 // edge, outer hole rim top - pos 2 24 10 0 10 9.239 -3.827 10 2 24 9.239 3.827 10 10 0 10 2 24 7.787 6 10 9.239 3.827 10 2 24 9.239 -3.827 10 7.787 -6 10 0 // edge, outer hole rim bottom - pos 2 24 8.14 5.471 -2.266 7.787 6 0 2 24 8.14 5.471 -2.266 8.998 4.187 -4.187 2 24 8.998 4.187 -4.187 9.239 3.827 -4.428 2 24 9.549 2.266 -5.471 9.239 3.827 -4.428 2 24 9.549 2.266 -5.471 10 0 -5.922 2 24 10 0 -5.922 9.549 -2.266 -5.471 2 24 9.239 -3.827 -4.428 9.549 -2.266 -5.471 2 24 9.239 -3.827 -4.428 8.998 -4.187 -4.187 2 24 8.998 -4.187 -4.187 8.14 -5.471 -2.266 2 24 7.787 -6 0 8.14 -5.471 -2.266 0 // face of cylinder - pos 3 16 9.549 -2.266 -5.471 10 0 -5.922 10 0 10 3 16 9.549 -2.266 -5.471 9.239 -3.827 10 9.239 -3.827 -4.428 3 16 10 0 10 9.239 -3.827 10 9.549 -2.266 -5.471 3 16 8.998 -4.187 -4.187 9.239 -3.827 -4.428 9.239 -3.827 10 4 16 8.998 -4.187 -4.187 9.239 -3.827 10 7.787 -6 10 7.787 -6 0 3 16 7.787 -6 0 8.14 -5.471 -2.266 8.998 -4.187 -4.187 3 16 9.549 2.266 -5.471 10 0 10 10 0 -5.922 3 16 9.549 2.266 -5.471 9.239 3.827 10 10 0 10 3 16 9.549 2.266 -5.471 9.239 3.827 -4.428 9.239 3.827 10 3 16 9.239 3.827 10 9.239 3.827 -4.428 8.998 4.187 -4.187 4 16 8.998 4.187 -4.187 7.787 6 0 7.787 6 10 9.239 3.827 10 3 16 8.998 4.187 -4.187 8.14 5.471 -2.266 7.787 6 0 0 // curvy bottom - pos 3 16 18 4.187 -4.187 8.998 4.187 -4.187 9.239 3.827 -4.428 4 16 18 4.187 -4.187 9.239 3.827 -4.428 9.549 2.266 -5.471 18 2.266 -5.471 4 16 18 -4.187 -4.187 18 -2.266 -5.471 9.549 -2.266 -5.471 9.239 -3.827 -4.428 3 16 9.239 -3.827 -4.428 8.998 -4.187 -4.187 18 -4.187 -4.187 4 16 18 -6 0 18 -5.471 -2.266 8.14 -5.471 -2.266 7.787 -6 0 4 16 18 -5.471 -2.266 18 -4.187 -4.187 8.998 -4.187 -4.187 8.14 -5.471 -2.266 4 16 18 6 0 7.787 6 0 8.14 5.471 -2.266 18 5.471 -2.266 4 16 18 5.471 -2.266 8.14 5.471 -2.266 8.998 4.187 -4.187 18 4.187 -4.187 4 16 18 2.266 -5.471 9.549 2.266 -5.471 10 0 -5.922 18 0 -5.922 4 16 18 -2.266 -5.471 18 0 -5.922 10 0 -5.922 9.549 -2.266 -5.471 0 // conditional inside lines - pos 5 24 9.239 3.827 -4.428 9.239 3.827 10 7.787 6 10 10 0 10 5 24 10 0 10 10 0 -5.922 9.549 -2.266 -5.471 9.239 3.827 -4.428 5 24 9.239 -3.827 10 9.239 -3.827 -4.428 8.998 -4.187 -4.187 10 0 10 0 // Complex bits on inside of ring 4 16 35.69 4.7 20 35.69 4.7 10 36 0 10 36 0 20 4 16 35.69 4.7 10 35.69 4.7 20 34.77 9.32 20 34.77 9.32 10 3 16 33.26 13.78 20 34.46 10 10 34.77 9.32 20 3 16 34.46 10 10 34.77 9.32 10 34.77 9.32 20 4 16 33.26 13.78 -20 34.46 10 0 34.46 10 10 33.26 13.78 20 0 2 24 34.46 10 10 34.77 9.32 10 2 24 34.77 9.32 10 35.69 4.7 10 2 24 35.69 4.7 10 36 0 10 0 3 16 36 0 -10 35.67 3.83 -9.24 35.69 4.7 -20 3 16 36 0 -20 36 0 -10 35.69 4.7 -20 3 16 35.69 4.7 -8.66 35.69 4.7 -20 35.67 3.83 -9.24 3 16 35.69 4.7 -8.66 35.14 7.07 -7.07 35.69 4.7 -20 3 16 35.14 7.07 -7.07 34.77 9.32 -20 35.69 4.7 -20 3 16 34.71 9.30 -3.83 34.77 9.32 -20 35.14 7.07 -7.07 3 16 34.72 9.24 -3.83 34.71 9.30 -3.83 34.77 9.32 -20 3 16 34.72 9.24 -3.83 33.26 13.78 -20 34.77 9.32 -20 3 16 34.72 9.24 -3.83 34.46 10 0 33.26 13.78 -20 0 2 24 34.72 9.24 -3.83 34.46 10 0 2 24 34.72 9.24 -3.83 34.71 9.30 -3.83 2 24 34.71 9.30 -3.83 35.14 7.07 -7.07 2 24 35.14 7.07 -7.07 35.69 4.7 -8.66 2 24 35.69 4.7 -8.66 35.67 3.83 -9.24 2 24 35.67 3.83 -9.24 36 0 -10 0 4 16 -36 0 20 -36 0 10 -35.69 4.7 10 -35.69 4.7 20 4 16 -34.77 9.32 10 -34.77 9.32 20 -35.69 4.7 20 -35.69 4.7 10 3 16 -34.77 9.32 20 -34.46 10 10 -33.26 13.78 20 3 16 -34.77 9.32 20 -34.77 9.32 10 -34.46 10 10 4 16 -33.26 13.78 20 -34.46 10 10 -34.46 10 0 -33.26 13.78 -20 0 2 24 -34.46 10 10 -34.77 9.32 10 2 24 -34.77 9.32 10 -35.69 4.7 10 2 24 -35.69 4.7 10 -36 0 10 0 3 16 -35.69 4.7 -20 -35.67 3.83 -9.24 -36 0 -10 3 16 -35.69 4.7 -20 -36 0 -10 -36 0 -20 3 16 -35.67 3.83 -9.24 -35.69 4.7 -20 -35.69 4.7 -8.66 3 16 -35.69 4.7 -20 -35.14 7.07 -7.07 -35.69 4.7 -8.66 3 16 -35.69 4.7 -20 -34.77 9.32 -20 -35.14 7.07 -7.07 3 16 -35.14 7.07 -7.07 -34.77 9.32 -20 -34.71 9.30 -3.83 3 16 -34.77 9.32 -20 -34.71 9.30 -3.83 -34.72 9.24 -3.83 3 16 -34.77 9.32 -20 -33.26 13.78 -20 -34.72 9.24 -3.83 3 16 -33.26 13.78 -20 -34.46 10 0 -34.72 9.24 -3.83 0 2 24 -34.72 9.24 -3.83 -34.46 10 0 2 24 -34.72 9.24 -3.83 -34.71 9.30 -3.83 2 24 -34.71 9.30 -3.83 -35.14 7.07 -7.07 2 24 -35.14 7.07 -7.07 -35.69 4.7 -8.66 2 24 -35.69 4.7 -8.66 -35.67 3.83 -9.24 2 24 -35.67 3.83 -9.24 -36 0 -10 0 4 16 36 0 20 36 0 10 35.69 -4.7 10 35.69 -4.7 20 4 16 34.77 -9.32 10 34.77 -9.32 20 35.69 -4.7 20 35.69 -4.7 10 3 16 34.77 -9.32 20 34.46 -10 10 33.26 -13.78 20 3 16 34.77 -9.32 20 34.77 -9.32 10 34.46 -10 10 4 16 33.26 -13.78 20 34.46 -10 10 34.46 -10 0 33.26 -13.78 -20 0 2 24 34.46 -10 10 34.77 -9.32 10 2 24 34.77 -9.32 10 35.69 -4.7 10 2 24 35.69 -4.7 10 36 0 10 0 3 16 35.69 -4.7 -20 35.67 -3.83 -9.24 36 0 -10 3 16 35.69 -4.7 -20 36 0 -10 36 0 -20 3 16 35.67 -3.83 -9.24 35.69 -4.7 -20 35.69 -4.7 -8.66 3 16 35.69 -4.7 -20 35.14 -7.07 -7.07 35.69 -4.7 -8.66 3 16 35.69 -4.7 -20 34.77 -9.32 -20 35.14 -7.07 -7.07 3 16 35.14 -7.07 -7.07 34.77 -9.32 -20 34.71 -9.30 -3.83 3 16 34.77 -9.32 -20 34.71 -9.30 -3.83 34.72 -9.24 -3.83 3 16 34.77 -9.32 -20 33.26 -13.78 -20 34.72 -9.24 -3.83 3 16 33.26 -13.78 -20 34.46 -10 0 34.72 -9.24 -3.83 0 2 24 34.72 -9.24 -3.83 34.46 -10 0 2 24 34.72 -9.24 -3.83 34.71 -9.30 -3.83 2 24 34.71 -9.30 -3.83 35.14 -7.07 -7.07 2 24 35.14 -7.07 -7.07 35.69 -4.7 -8.66 2 24 35.69 -4.7 -8.66 35.67 -3.83 -9.24 2 24 35.67 -3.83 -9.24 36 0 -10 0 4 16 -35.69 -4.7 20 -35.69 -4.7 10 -36 0 10 -36 0 20 4 16 -35.69 -4.7 10 -35.69 -4.7 20 -34.77 -9.32 20 -34.77 -9.32 10 3 16 -33.26 -13.78 20 -34.46 -10 10 -34.77 -9.32 20 3 16 -34.46 -10 10 -34.77 -9.32 10 -34.77 -9.32 20 4 16 -33.26 -13.78 -20 -34.46 -10 0 -34.46 -10 10 -33.26 -13.78 20 0 2 24 -34.46 -10 10 -34.77 -9.32 10 2 24 -34.77 -9.32 10 -35.69 -4.7 10 2 24 -35.69 -4.7 10 -36 0 10 0 3 16 -36 0 -10 -35.67 -3.83 -9.24 -35.69 -4.7 -20 3 16 -36 0 -20 -36 0 -10 -35.69 -4.7 -20 3 16 -35.69 -4.7 -8.66 -35.69 -4.7 -20 -35.67 -3.83 -9.24 3 16 -35.69 -4.7 -8.66 -35.14 -7.07 -7.07 -35.69 -4.7 -20 3 16 -35.14 -7.07 -7.07 -34.77 -9.32 -20 -35.69 -4.7 -20 3 16 -34.71 -9.30 -3.83 -34.77 -9.32 -20 -35.14 -7.07 -7.07 3 16 -34.72 -9.24 -3.83 -34.71 -9.30 -3.83 -34.77 -9.32 -20 3 16 -34.72 -9.24 -3.83 -33.26 -13.78 -20 -34.77 -9.32 -20 3 16 -34.72 -9.24 -3.83 -34.46 -10 0 -33.26 -13.78 -20 0 2 24 -34.72 -9.24 -3.83 -34.46 -10 0 2 24 -34.72 -9.24 -3.83 -34.71 -9.30 -3.83 2 24 -34.71 -9.30 -3.83 -35.14 -7.07 -7.07 2 24 -35.14 -7.07 -7.07 -35.69 -4.7 -8.66 2 24 -35.69 -4.7 -8.66 -35.67 -3.83 -9.24 2 24 -35.67 -3.83 -9.24 -36 0 -10 0 0 // main face of things - neg 4 16 -3.83 9.24 10 0 10 10 -34.46 10 10 -34.77 9.32 10 4 16 -18 8 10 -3.83 9.24 10 -34.77 9.32 10 -22 8 10 4 16 -7.07 7.07 10 -18 8 10 -18 6 10 -7.79 6 10 3 16 -7.07 7.07 10 -3.83 9.24 10 -18 8 10 4 16 -34.77 -9.32 10 -34.46 -10 10 0 -10 10 -3.83 -9.24 10 4 16 -34.77 -9.32 10 -3.83 -9.24 10 -18 -8 10 -22 -8 10 4 16 -7.79 -6 10 -18 -6 10 -18 -8 10 -7.07 -7.07 10 3 16 -3.83 -9.24 10 -7.07 -7.07 10 -18 -8 10 4 16 -22 8 10 -34.77 9.32 10 -34.77 -9.32 10 -22 -8 10 4 16 -34.77 9.32 10 -35.69 4.70 10 -35.69 -4.70 10 -34.77 -9.32 10 3 16 -36 0 10 -35.69 -4.70 10 -35.69 4.70 10 0 // main face of things - pos 4 16 34.77 9.32 10 34.46 10 10 0 10 10 3.83 9.24 10 4 16 18 8 10 22 8 10 34.77 9.32 10 3.83 9.24 10 4 16 7.79 6 10 18 6 10 18 8 10 7.07 7.07 10 3 16 18 8 10 3.83 9.24 10 7.07 7.07 10 4 16 3.83 -9.24 10 0 -10 10 34.46 -10 10 34.77 -9.32 10 4 16 34.77 -9.32 10 22 -8 10 18 -8 10 3.83 -9.24 10 4 16 7.07 -7.07 10 18 -8 10 18 -6 10 7.79 -6 10 3 16 18 -8 10 7.07 -7.07 10 3.83 -9.24 10 4 16 22 -8 10 34.77 -9.32 10 34.77 9.32 10 22 8 10 4 16 34.77 -9.32 10 35.69 -4.7 10 35.69 4.7 10 34.77 9.32 10 3 16 35.69 4.7 10 35.69 -4.7 10 36 0 10 0 // // Indent around outer pin hole - negative end 4 16 -38 -12.23 -8 -38 -12.23 8 -38 -6 6 -38 -6 -6 4 16 -38 6 -6 -38 6 6 -38 12.23 8 -38 12.23 -8 4 16 -38 -12.23 -8 -38 -6 -6 -38 6 -6 -38 12.23 -8 4 16 -38 12.23 8 -38 6 6 -38 -6 6 -38 -12.23 8 2 24 -38 12.230 8 -38 -12.230 8 2 24 -38 -12.230 -8 -38 12.230 -8 2 24 -38 -12.23 -8 -38.637 -10.353 -8 2 24 -38.637 10.353 -8 -38 12.23 -8 2 24 -38 12.23 8 -38.637 10.353 8 2 24 -38.637 -10.353 8 -38 -12.23 8 1 16 0 0 8 -38.637 0 -10.353 -10.353 0 38.637 0 1 0 48\1-12edge.dat 1 16 0 0 -8 -38.637 0 -10.353 -10.353 0 38.637 0 -1 0 48\1-12edge.dat 4 16 -38 12.23 -8 -38.637 10.353 -8 -38.637 -10.353 -8 -38 -12.23 -8 4 16 -38 -12.23 8 -38.637 -10.353 8 -38.637 10.353 8 -38 12.23 8 1 16 0 0 8 -38.637 0 -10.353 -10.353 0 38.637 0 1 0 48\1-12chrd.dat 1 16 0 0 -8 -38.637 0 -10.353 -10.353 0 38.637 0 -1 0 48\1-12chrd.dat 2 24 -38 -12.230 -8 -38 -12.230 8 2 24 -38 12.230 8 -38 12.230 -8 0 // // Indent around outer pin hole - positive end 4 16 38 -6 -6 38 -6 6 38 -12.230 8 38 -12.230 -8 4 16 38 12.230 -8 38 12.230 8 38 6 6 38 6 -6 4 16 38 12.230 -8 38 6 -6 38 -6 -6 38 -12.230 -8 4 16 38 -12.23 8 38 -6 6 38 6 6 38 12.23 8 2 24 38 12.230 -8 38 -12.230 -8 2 24 38 -12.230 8 38 12.230 8 2 24 38 -12.23 8 38.637 -10.353 8 2 24 38.637 10.353 8 38 12.23 8 2 24 38.637 -10.353 -8 38 -12.23 -8 2 24 38 12.23 -8 38.637 10.353 -8 1 16 0 0 8 38.637 0 10.353 10.353 0 -38.637 0 1 0 48\1-12edge.dat 1 16 0 0 -8 38.637 0 10.353 10.353 0 -38.637 0 -1 0 48\1-12edge.dat 4 16 38.637 10.353 8 38.637 -10.353 8 38 -12.23 8 38 12.23 8 4 16 38 12.23 -8 38 -12.23 -8 38.637 -10.353 -8 38.637 10.353 -8 1 16 0 0 8 38.637 0 10.353 10.353 0 -38.637 0 1 0 48\1-12chrd.dat 1 16 0 0 -8 38.637 0 10.353 10.353 0 -38.637 0 -1 0 48\1-12chrd.dat 2 24 38 -12.230 -8 38 -12.230 8 2 24 38 12.230 8 38 12.230 -8 0 // // outer rims around outer holes 1 16 0 0 8 -38.637 0 -10.353 -10.353 0 38.637 0 2 0 48\1-12cyli.dat 1 16 0 0 -10 -38.637 0 -10.353 -10.353 0 38.637 0 2 0 48\1-12cyli.dat 4 16 -38.637 10.353 8 -38.637 10.353 10 -36.955 15.307 10 -38 12.23 8 4 16 -36.955 15.307 10 -36.955 15.307 -10 -38 12.23 -8 -38 12.23 8 4 16 -38 12.230 -8 -36.955 15.307 -10 -38.637 10.353 -10 -38.637 10.353 -8 4 16 -38.637 -10.353 -8 -38.637 -10.353 -10 -36.955 -15.307 -10 -38 -12.23 -8 4 16 -38 -12.23 8 -36.955 -15.307 10 -38.637 -10.353 10 -38.637 -10.353 8 4 16 -38 -12.23 8 -38 -12.23 -8 -36.955 -15.307 -10 -36.955 -15.307 10 0 1 16 0 0 8 38.637 0 10.353 10.353 0 -38.637 0 2 0 48\1-12cyli.dat 1 16 0 0 -10 38.637 0 10.353 10.353 0 -38.637 0 2 0 48\1-12cyli.dat 4 16 38.637 -10.353 8 38.637 -10.353 10 36.955 -15.307 10 38 -12.23 8 4 16 36.955 -15.307 10 36.955 -15.307 -10 38 -12.23 -8 38 -12.23 8 4 16 38 -12.23 -8 36.955 -15.307 -10 38.637 -10.353 -10 38.637 -10.353 -8 4 16 38.637 10.353 -8 38.637 10.353 -10 36.955 15.307 -10 38 12.23 -8 4 16 38 12.23 8 36.955 15.307 10 38.637 10.353 10 38.637 10.353 8 4 16 38 12.23 8 38 12.23 -8 36.955 15.307 -10 36.955 15.307 10 0 0 // // Outer ring major parts 1 16 0 0 10 0 0 40 -40 0 0 0 -20 0 48\3-16cyli.dat 1 16 0 0 10 0 0 -40 -40 0 0 0 -20 0 48\3-16cyli.dat 1 16 0 0 -10 0 0 40 40 0 0 0 20 0 48\3-16cyli.dat 1 16 0 0 -10 0 0 -40 40 0 0 0 20 0 48\3-16cyli.dat 0 BFC INVERTNEXT 1 16 0 0 20 0 0 36 -36 0 0 0 -40 0 48\3-16cyli.dat 0 BFC INVERTNEXT 1 16 0 0 20 0 0 -36 -36 0 0 0 -40 0 48\3-16cyli.dat 0 BFC INVERTNEXT 1 16 0 0 20 0 0 36 36 0 0 0 -40 0 48\3-16cyli.dat 0 BFC INVERTNEXT 1 16 0 0 20 0 0 -36 36 0 0 0 -40 0 48\3-16cyli.dat 1 16 0 0 20 0 0 36 36 0 0 0 -1 0 48\4-4edge.dat 1 16 0 0 20 0 0 38.4 38.4 0 0 0 -1 0 48\4-4edge.dat 1 16 0 0 -20 0 0 38.4 38.4 0 0 0 -1 0 48\4-4edge.dat 1 16 0 0 -20 0 0 36 36 0 0 0 -1 0 48\4-4edge.dat 1 16 0 0 -20 2.4 0 0 0 0 2.4 0 1 0 48\4-4ring15.dat 1 16 0 0 20 2.4 0 0 0 0 2.4 0 -1 0 48\4-4ring15.dat 1 16 0 0 -10 1.6 0 0 0 0 1.6 0 -10 0 48\4-4con24.dat 1 16 0 0 10 1.6 0 0 0 0 1.6 0 10 0 48\4-4con24.dat 1 16 -38 0 0 0 1 0 6 0 0 0 0 6 4-4ndis.dat 1 16 38 0 0 0 -1 0 6 0 0 0 0 6 4-4ndis.dat 0 // // Inside stuff 1 16 0 0 -10 0 0 2 2 0 0 0 1 0 4-4ring4.dat 1 16 0 0 -10 0 0 10 -10 0 0 0 -1 0 4-4edge.dat 1 16 0 0 10 0 0 2 2 0 0 0 -1 0 4-4ring4.dat 1 16 0 0 -10 10 0 0 0 0 -10 0 10 0 1-4cyls.dat 1 16 -10 0 0 0 10 0 0 0 -10 -10 0 0 1-4cyls.dat 1 16 10 0 0 0 -10 0 0 0 10 -10 0 0 1-4cyls.dat 1 16 -10 0 0 0 10 0 0 0 10 -10 0 0 1-4cyls.dat 1 16 10 0 0 0 -10 0 0 0 -10 -10 0 0 1-4cyls.dat 1 16 0 0 -10 -10 0 0 0 0 10 0 10 0 1-4cyls.dat 1 16 0 0 -10 -10 0 0 0 0 -10 0 10 0 1-4cyls.dat 1 16 0 0 -10 10 0 0 0 0 10 0 10 0 1-4cyls.dat 1 16 0 0 0 0 -1 -10 10 0 0 0 1 -10 2-4edge.dat 1 16 0 0 0 0 -1 10 10 0 0 0 -1 -10 2-4edge.dat 1 16 0 10 5 34.45 0 0 0 -1 0 0 0 5 rect3.dat 1 16 0 -10 5 34.45 0 0 0 1 0 0 0 5 rect3.dat 0 0 BFC INVERTNEXT 1 16 0 0 -8 0 0 6 6 0 0 0 16 0 4-4cyli.dat 1 16 0 0 -10 1 0 0 0 0 1 0 1 0 peghole.dat 1 16 0 0 10 1 0 0 0 0 1 0 -1 0 peghole.dat 0 BFC INVERTNEXT 1 16 18 0 0 0 4 0 8 0 0 0 0 -8 2-4cyli.dat 1 16 18 0 0 0 1 0 8 0 0 0 0 -8 2-4edge.dat 1 16 22 0 0 0 1 0 8 0 0 0 0 -8 2-4edge.dat 1 16 18 0 0 0 -1 0 2 0 0 0 0 -2 2-4ring3.dat 1 16 18 0 0 0 1 0 6 0 0 0 0 -6 2-4edge.dat 1 16 22 0 0 0 1 0 2 0 0 0 0 2 4-4ring3.dat 1 16 22 0 0 0 1 0 8 0 0 0 0 8 2-4ndis.dat 1 16 10 0 0 0 26 0 10 0 0 0 0 -10 2-4cyli.dat 1 16 22 0 9 0 1 0 0 0 8 1 0 0 rect1.dat 1 16 18 7 5 0 -1 0 0 0 1 5 0 0 rect1.dat 1 16 18 -7 5 0 -1 0 0 0 1 5 0 0 rect1.dat 1 16 20 8 5 2 0 0 0 1 0 0 0 5 rect3.dat 1 16 20 -8 5 2 0 0 0 -1 0 0 0 5 rect3.dat 1 16 12.9 6 5 5.1 0 0 0 1 0 0 0 5 rect3.dat 1 16 12.9 -6 5 5.1 0 0 0 -1 0 0 0 5 rect3.dat 0 BFC INVERTNEXT 1 16 22 0 0 0 16 0 0 0 6 6 0 0 4-4cyli.dat 1 16 22 0 0 0 1 0 0 0 6 6 0 0 4-4edge.dat 1 16 38 0 0 0 1 0 0 0 6 6 0 0 4-4edge.dat 0 BFC INVERTNEXT 1 16 -18 0 0 0 -4 0 8 0 0 0 0 -8 2-4cyli.dat 1 16 -18 0 0 0 1 0 8 0 0 0 0 -8 2-4edge.dat 1 16 -22 0 0 0 1 0 8 0 0 0 0 -8 2-4edge.dat 1 16 -18 0 0 0 1 0 2 0 0 0 0 -2 2-4ring3.dat 1 16 -18 0 0 0 1 0 6 0 0 0 0 -6 2-4edge.dat 1 16 -22 0 0 0 -1 0 2 0 0 0 0 2 4-4ring3.dat 1 16 -22 0 0 0 -1 0 8 0 0 0 0 8 2-4ndis.dat 1 16 -36 0 0 0 26 0 10 0 0 0 0 -10 2-4cyli.dat 1 16 -22 0 9 0 -1 0 0 0 8 1 0 0 rect1.dat 1 16 -18 7 5 0 1 0 0 0 1 5 0 0 rect1.dat 1 16 -18 -7 5 0 1 0 0 0 1 5 0 0 rect1.dat 1 16 -20 8 5 2 0 0 0 1 0 0 0 5 rect3.dat 1 16 -20 -8 5 2 0 0 0 -1 0 0 0 5 rect3.dat 1 16 -12.9 6 5 5.1 0 0 0 1 0 0 0 5 rect3.dat 1 16 -12.9 -6 5 5.1 0 0 0 -1 0 0 0 5 rect3.dat 0 BFC INVERTNEXT 1 16 -22 0 0 0 -16 0 6 0 0 0 0 6 4-4cyli.dat 1 16 -22 0 0 0 1 0 6 0 0 0 0 6 4-4edge.dat 1 16 -38 0 0 0 1 0 6 0 0 0 0 6 4-4edge.dat 0
Certified (TF) Certified (TF)
  • All parts are required to be CC BY 4.0
User Vote
OrionP Admin Fast Track
None
Orion Pobursky [OrionP]
2025-09-27 02:11:40
posted a vote of Admin Fast Track.
2025-09-27 02:11:40
This part is copyright © Marc Schickele
LDraw.org Parts Tracker, Matthew J. Chiles, Mark Kennedy, Orion Pobursky,
