0 Constraction Claw Triple with Peghole and Axle
0 Name: 32506.dat
0 !HELP finger rotation centre at z=9.25, angle 28°
0 !CATEGORY Constraction
0 !KEYWORDS bionicle, Brickowl 54244, Onua, Technic, Toa Mata, voodoo
0 !HISTORY 2025-10-04 [MagFors] Shaped axleend
0 !HISTORY 2026-07-29 {LEGO Digital Designer} Original part shape
0 !HISTORY 2026-07-29 [MagFors] total rework using LDD data
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\32506s01.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\32506s01.dat
1 16 0 0 10 0 0 1 1 0 0 0 -1 0 axleend20.dat
1 16 0 10 0 0 0 1 0 -1 0 -1 0 0 peghole.dat
1 16 0 -8 0 0 0 6 0 16 0 -6 0 0 4-4cyli.dat
1 16 0 -10 0 0 0 1 0 1 0 -1 0 0 peghole.dat
3 16 0 10 -9 2.5 9.335 -9.812 -2.5 9.335 -9.812
4 16 -1.875 10.052 -59.91 -1.875 5.273 -52.095 1.875 5.273 -52.095 1.875 10.052 -59.91
4 16 -1.875 5.273 -52.095 -1.875 1.875 -40.535 1.875 1.875 -40.535 1.875 5.273 -52.095
4 16 -3.005 1.767 -29.188 -3.742 1.873 -27.17 3.742 1.873 -27.17 3.005 1.767 -29.188
4 16 3.005 1.767 -29.188 1.875 1.655 -30.19 -1.875 1.655 -30.19 -3.005 1.767 -29.188
4 16 -1.875 1.875 -40.535 -1.875 1.655 -30.19 1.875 1.655 -30.19 1.875 1.875 -40.535
4 16 -2.5 5.235 -16.92 -2.5 9.335 -9.812 2.5 9.335 -9.812 2.5 5.235 -16.92
4 16 -7.88 -16.355 -22.358 -8.125 -17.828 -23.337 8.125 -17.828 -23.337 7.88 -16.355 -22.358
4 16 -8.125 -17.828 -23.337 -6.875 -18.475 -24.098 6.875 -18.475 -24.098 8.125 -17.828 -23.337
3 16 5.028 -10 10 -5.028 -10 10 0 -10 8
4 16 -2.5 -14.56 -16.942 -2.5 -14.56 -21.942 2.5 -14.56 -21.942 2.5 -14.56 -16.942
4 16 -2.5 -10 -8.905 -2.5 -14.56 -16.942 2.5 -14.56 -16.942 2.5 -10 -8.905
4 16 2.5 5.235 -16.92 2.5 2.712 -24.148 -2.5 2.712 -24.148 -2.5 5.235 -16.92
3 16 1.875 10.052 -59.91 0 36.76 -60.811 -1.875 10.052 -59.91
4 16 -3.742 1.873 -27.17 -3.088 2.552 -24.812 3.088 2.552 -24.812 3.742 1.873 -27.17
4 16 2.5 2.712 -24.148 3.088 2.552 -24.812 -3.088 2.552 -24.812 -2.5 2.712 -24.148
4 16 -6.875 -18.475 -24.098 -2.56 -18.475 -29.785 2.56 -18.475 -29.785 6.875 -18.475 -24.098
3 16 2.56 -18.475 -29.785 -2.56 -18.475 -29.785 0 -18.475 -32.01
4 16 7.88 -16.355 -22.358 2.5 -14.56 -21.942 -2.5 -14.56 -21.942 -7.88 -16.355 -22.358
4 16 -5.028 10 10 -5.028 -10 10 5.028 -10 10 5.028 10 10
3 16 0 -10 -8 -2.5 -10 -8.905 2.5 -10 -8.905
3 16 -5.028 10 10 5.028 10 10 0 10 8
4 16 1.875 -3.725 -46.212 3.112 -5.108 -46.212 -3.112 -5.108 -46.212 -1.875 -3.725 -46.212
4 16 -3.662 -6.952 -46.212 -3.112 -5.108 -46.212 3.112 -5.108 -46.212 3.662 -6.952 -46.212
4 16 3.662 -6.952 -46.212 3.418 -8.872 -46.212 -3.418 -8.872 -46.212 -3.662 -6.952 -46.212
4 16 -2.25 -10.688 -46.212 -3.418 -8.872 -46.212 3.418 -8.872 -46.212 2.25 -10.688 -46.212
3 16 2.25 -10.688 -46.212 0 -11.447 -46.212 -2.25 -10.688 -46.212
5 24 0 .58 -68.598 0 -8.422 -68.592 .705 .58 -68.498 -.705 .58 -68.498
5 24 0 -4.3 -63.598 0 .58 -63.598 1.35 -4.512 -63.998 -1.35 -4.512 -63.998
5 24 2.5 9.335 -9.812 -2.5 9.335 -9.812 -4.818 10 -8.905 2.5 5.235 -16.92
5 24 -1.875 5.273 -52.095 1.875 5.273 -52.095 1.875 10.052 -59.91 -1.875 1.875 -40.535
2 24 1.875 10.052 -59.91 -1.875 10.052 -59.91
5 24 -1.875 1.875 -40.535 1.875 1.875 -40.535 1.875 5.273 -52.095 -1.875 1.655 -30.19
5 24 -3.742 1.873 -27.17 3.742 1.873 -27.17 3.005 1.767 -29.188 -3.088 2.552 -24.812
5 24 3.005 1.767 -29.188 -3.005 1.767 -29.188 -3.742 1.873 -27.17 1.875 1.655 -30.19
5 24 1.875 1.655 -30.19 -1.875 1.655 -30.19 -3.005 1.767 -29.188 1.875 1.875 -40.535
5 24 2.5 5.235 -16.92 -2.5 5.235 -16.92 -2.5 9.335 -9.812 2.5 2.712 -24.148
5 24 0 -10.067 -46.212 0 -2.458 -61.796 1.315 -9.618 -46.212 -1.315 -9.618 -46.212
5 24 -8.125 -17.828 -23.337 8.125 -17.828 -23.337 7.88 -16.355 -22.358 -6.875 -18.475 -24.098
5 24 7.88 -16.355 -22.358 -7.88 -16.355 -22.358 -8.125 -17.828 -23.337 2.5 -14.56 -21.942
2 24 -6.875 -18.475 -24.098 6.875 -18.475 -24.098
5 24 0 -2.458 -61.796 0 -4.3 -63.598 6.25 -4.06 -63.23 -6.25 -4.06 -63.23
5 24 0 19.438 -68.73 0 28.875 -65.945 3.955 19.22 -67.725 -3.955 19.22 -67.725
5 24 0 9.755 -70.472 0 19.438 -68.73 3.955 19.22 -67.725 -3.955 19.22 -67.725
5 24 0 -.015 -71.15 0 9.755 -70.472 1.95 1.645 -70.872 -1.95 1.645 -70.872
5 24 0 -4.37 -70.84 0 -.015 -71.15 2.187 -1.85 -70.795 -2.187 -1.85 -70.795
5 24 0 -7.805 -70.137 0 -4.37 -70.84 3.898 -5.618 -69.622 -3.898 -5.618 -69.622
2 24 5.028 -10 10 -5.028 -10 10
2 24 -2.5 -14.56 -21.942 2.5 -14.56 -21.942
5 24 2.5 -14.56 -16.942 -2.5 -14.56 -16.942 -2.5 -14.56 -21.942 2.5 -10 -8.905
2 24 2.5 -10 -8.905 -2.5 -10 -8.905
5 24 2.5 2.712 -24.148 -2.5 2.712 -24.148 -2.5 5.235 -16.92 3.088 2.552 -24.812
5 24 -3.088 2.552 -24.812 3.088 2.552 -24.812 3.742 1.873 -27.17 -2.5 2.712 -24.148
2 24 5.028 10 10 -5.028 10 10
5 24 0 37.267 -61.325 0 36.8 -61.253 1.905 36.8095 -61.1128 -1.905 36.8095 -61.1128
5 24 0 36.8 -61.253 0 36.76 -60.811 1.886 36.78 -60.811 -1.886 36.78 -60.811
5 24 0 28.875 -65.945 0 37.383 -62.29 .92 37.447 -62.392 -.92 37.447 -62.392
5 24 0 37.383 -62.29 0 37.267 -61.325 .92 37.447 -62.392 -.92 37.447 -62.392
5 24 0 -18.475 -32.01 0 -11.447 -46.212 -1.302 -18.475 -31.545 1.302 -18.475 -31.545
Has Uncertified Subfiles
center finger misses intersection lines at the base
keywords:
bionicle, Technic
to
Technic, Bionicle, voodoo
description:
Constraction Claw with Axle
to
help:
0 !HELP
to
0 !HELP
keywords:
bionicle, Technic, voodoo
to
Technic, bionicle, voodoo, Onua, Toa Mata
the fingers are too long i was building the kaita akamai
and the claw was clipping into the torso
@Jeff:
I don't see a collision. Are sure you used the correct axles in the neck area?
Anyways, it does seem quite off to the LDD mesh, but I'm not sure that is correct either...
Tips of the claws should be a bit further down and more stretched out.
@Philo, is that ok with you?
Are there any other connection points on this, other than the axle and the connhole?
help:
0 !HELPto
0 !HELPcategory:
Technicto
Constractionkeywords:
to
Technic, Bionicledescription:
Technic Bionicle Claw with Axleto
