Unofficial File parts/s/4181b01.dat
~Sticker  1.0 x  4.4 (Formed)
0 ~Sticker 1.0 x 4.4 (Formed) 0 Name: s\4181b01.dat 0 Author: Chris Böhnke [KnightOfTarenta] 0 !LDRAW_ORG Unofficial_Subpart 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW
0 // Sticker Back 0 BFC INVERTNEXT 1 16 0 0 0 10 0 0 0 24 0 0 0 -10 3-16cyli.dat 0 BFC INVERTNEXT 1 16 0 0 60 10 0 0 0 24 0 0 0 10 3-16cyli.dat 4 16 10 24 0 10 0 0 10 0 60 10 24 60 4 16 2.588 24 69.659 3.827 24 69.239 3.827 0 69.239 2.588 0 69.659 4 16 3.827 0 -9.239 3.827 24 -9.239 2.588 24 -9.659 2.588 0 -9.659 0 // Sticker Sides 1 16 0 0 0 .25 0 0 0 1 0 0 0 -.25 3-16ring40.dat 1 16 0 0 60 .25 0 0 0 1 0 0 0 .25 3-16ring40.dat 1 16 0 24 0 .25 0 0 0 -1 0 0 0 -.25 3-16ring40.dat 1 16 0 24 60 .25 0 0 0 -1 0 0 0 .25 3-16ring40.dat 4 16 2.588 24 69.659 2.588 0 69.659 2.653 0 69.901 2.653 24 69.901 4 16 2.588 24 -9.659 2.653 24 -9.901 2.653 0 -9.901 2.588 0 -9.659 4 16 2.588 24 -9.659 3.827 24 -9.239 3.922675 24 -9.469975 2.653 24 -9.901 4 16 10 24 60 10.25 24 60 10.25 24 0 10 24 0 4 16 2.588 24 69.659 2.653 24 69.901 3.922675 24 69.469975 3.827 24 69.239 4 16 3.922675 0 -9.469975 3.827 0 -9.239 2.588 0 -9.659 2.653 0 -9.901 4 16 10 0 60 10 0 0 10.25 0 0 10.25 0 60 4 16 2.588 0 69.659 3.827 0 69.239 3.922675 0 69.469975 2.653 0 69.901
    Line 25: 4 16 2.588 24 -9.659 3.827 24 -9.239 3.922675 24 -9.469975 2.653 24 -9.901
    Line 27: 4 16 2.588 24 69.659 2.653 24 69.901 3.922675 24 69.469975 3.827 24 69.239
    Line 28: 4 16 3.922675 0 -9.469975 3.827 0 -9.239 2.588 0 -9.659 2.653 0 -9.901
    Line 30: 4 16 2.588 0 69.659 3.827 0 69.239 3.922675 0 69.469975 2.653 0 69.901
None
2025-10-10 23:20:11
made the following comment.
2025-10-10 23:21:05
Not sure if there are still parts left for this, but technically this requires a stickerback subfile.
posted a vote of Hold.
2025-10-11 07:26:43
Why is it made using hi-res prims? The surface on the door isn't.
2025-10-11 16:06:33
The angle wouldn't work with regular ones.
Rene Rechthaler [Blechtaler]
2025-10-11 19:32:11
try using the biggest possible normal res prim and use quads for the rest...
2025-10-16 02:51:56
2025-10-16 02:52:37
*changed to standard resolution
2025-10-16 10:15:19
could use 4 decimals at the connection to the ring prim (3.922 0 69.47 to 3.9227 0 69.47), as of now there is a small gap
why two segments at the end?
2025-10-17 22:06:02
*removed a segment at each end
*gaps should be closed
This part is copyright © Chris Böhnke
