Unofficial File parts/4515p04.dat
Slope Brick 10  6 x  8 with U.S.S. Enterprise Name Plate and Blueprint Pattern
0 Slope Brick 10  6 x  8 with U.S.S. Enterprise Name Plate and Blueprint Pattern
0 Name: 4515p04.dat
0 !CATEGORY Slope
0 !KEYWORDS Bricklink 4515pb086, Brickowl 273437, Brickset 114633
0 !KEYWORDS Rebrickable 4515pr0009, Set 10356, Star Trek
0 !KEYWORDS U.S.S. Enterprise NCC-1701-D
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\4515s01.dat
1 16 0 9.5 0 1 0 0 0 1 -0.158333 0 0 1 s\4515p04s01.dat
    Line 15: 1 16 0 9.5 0 1 0 0 0 1 -0.158333 0 0 1 s\4515p04s01.dat
Philippe Hurbain [Philo]
2025-11-29 19:44:48
Pattern is subparted to reduce it to 2dp and lower overall file size while keeping it perfectly planar.
Resolution of fine text could be improved but it will have to do the trick at the moment...
edited the part header.
2025-11-29 19:45:19
Header Edits
preview:
to
16 0 0 0 -1 0 0 0 1 0 0 0 -1
Peter Grass [Evilspyre]
Part Author
made the following comment.
2025-12-10 18:27:53
Studio's part designer doesn't like this file and it's impossible to import since it doesn't like the -0.158333 entry. I don't think it can accept angled sub-parts.
Part Reviewer
2025-12-10 18:57:13
You can import the part: Manually change the value from -0.158333 to 0.0 and import the file. Right‑click on the assembly and select Ungroup. Convert the value into degrees and tilt the pattern accordingly. Then you need to scale the Y‑direction from 120 to about 121.5 so that it aligns more precisely with the base part (after tilting there is a small gap). The second option is to import the two components separately in Part Designer.
2025-12-10 19:35:11
Improved fine text.
2025-12-10 19:42:06
We can't be responsible of the pile of bugs contained in Studio...
Actually, the part works perfectly in Studio, only part designer chokes on it. So the method is fairly simple, put the part in custom parts folder, and copy 4515.col/4515.conn to 4515p04.col/.conn (or any name you choose to avoid name clashing with Studio parts)
Rene Rechthaler [Blechtaler]
2025-12-10 20:12:07
Header Edits
description:
Slope Brick 10 6 x 8 with U.S.S. Enterprice Name Plate and Blueprint Pattern
to
Comment:
Enterprice -> Enterprise
Florent Faramond [Makou]
Part Author
2026-01-14 19:40:54
In fact the rotation is not correct : 0 1 -0.158333 0 0 1
If you replace with the correct one, it's working: 0.987385 -0.158333 0 0.158333 0.987385
Part Author
2026-01-14 19:49:27
Finally the correct one: 1 16 0 9.5 0 1 0 0 0 1 -0.158333 0 0.158333 1 s\4515p04s01.dat
2026-01-14 20:30:19
The subfile is not rotated. It's deformed.
https://jc-tchang.philohome.com/manuel/prim_def.htm
