Unofficial File parts/s/7796s01.dat
0 ~Plate 4 x 4 with Side Bricks 1 x 4 with Axle Hole - Quarter
0 Name: s\7796s01.dat
1 16 30 0 20 10 0 0 0 1 0 0 0 20 rect3.dat
1 16 20 20 20 0 0 -1 0 -1 0 1 0 0 2-4stud4.dat
1 16 20 22 20 0 1 0 0 0 2 6 0 0 rect3.dat
1 16 20 22 10 0 1 0 0 0 2 2 0 0 rect3.dat
1 16 20 22 32 0 1 0 0 0 2 -4 0 0 rect2a.dat
1 16 30 24 18 6 0 0 0 1 0 0 0 18 recte3.dat
1 16 30 14 22.5 6 0 0 0 -10 0 0 0 13.5 box2-7.dat
1 16 30 7 9 -6 0 0 0 0 -3 0 -1 0 rect3.dat
1 16 30 11.1646 8.8465 0 0 6 1.1646 0 0 -.1535 -1 0 rect2p.dat
1 16 30 13.4146 8.2435 0 0 6 1.0854 0 0 -.4495 -1 0 rect2p.dat
5 24 36 10 9 24 10 9 24 4 9 24 12.3292 8.693
5 24 24 12.3292 8.693 36 12.3292 8.693 24 14.5 7.794 36 10 9
1 16 30 16.05115 6.147 6 0 0 0 -1.55115 0 0 0 -1.647 box2-5.dat
1 16 30 16.6023 3.25 6 0 0 0 1 0 0 0 -1.25 box2-7.dat
1 16 22.25 15.80115 1 1.75 0 0 0 1 -.19885 0 0 1 rect3.dat
1 16 38 15.80115 1 2 0 0 0 1 -.19885 0 0 1 rect3.dat
1 16 30 4 20 1 0 0 0 -5 0 0 0 1 stud3.dat
4 16 24 24 36 24 4 36 24 4 9 24 10 9
3 16 24 10 9 24 14.5 7.794 24 24 36
4 16 24 24 36 24 14.5 7.794 24 14.5 4.5 24 17.6023 4.5
4 16 24 24 36 24 17.6023 4.5 24 17.6023 2 24 24 0
4 16 24 17.6023 2 24 15.6023 2 24 16 0 24 24 0
4 16 36 16 0 36 15.6023 2 36 17.6023 2 36 24 0
4 16 36 24 0 36 17.6023 2 36 17.6023 4.5 36 24 36
4 16 36 17.6023 4.5 36 14.5 4.5 36 14.5 7.794 36 24 36
3 16 36 14.5 7.794 36 10 9 36 24 36
4 16 36 4 9 36 4 36 36 24 36 36 10 9
4 16 40 16 0 40 24 0 40 24 40 40 16 6
4 16 40 16 6 40 24 40 40 0 40 40 10 6
3 16 40 4 6 40 10 6 40 0 40
4 16 40 4 0 40 4 6 40 0 40 40 0 0
4 16 40 0 40 40 24 40 20 16 40 20 0 40
4 16 20 14 4 20 16 40 20 16 0 20 14 0
3 16 20 16 40 20 14 4 20 10 4
4 16 20 6 4 20 0 40 20 16 40 20 10 4
4 16 20 0 0 20 0 40 20 6 4 20 6 0
2 24 40 0 40 40 24 40
2 24 20 0 40 20 16 40
4 16 40 24 40 40 24 0 36 24 0 36 24 36
3 16 40 24 40 36 24 36 24 24 36
3 16 40 24 40 24 24 36 20 24 36
3 16 20 24 36 24 24 36 20 24 28
3 16 20 24 28 24 24 36 20 24 26
4 16 24 24 0 20 24 14 20 24 26 24 24 36
3 16 20 24 14 24 24 0 20 24 12
3 16 20 24 12 24 24 0 20 24 8
3 16 20 24 8 24 24 0 20 24 6
1 16 24 23.5 5 0 0 1 0 9 0 1 0 0 ridge.dat
1 16 36 23.5 5 0 0 -1 0 9 0 1 0 0 ridge.dat
2 24 35 17.6023 3.5 36 17.6023 3.5
2 24 25 17.6023 3.5 24 17.6023 3.5
2 24 34 17.6023 4.5 35 17.6023 3.5
2 24 26 17.6023 4.5 25 17.6023 3.5
2 24 34 17.6023 4.5 34 14.5 4.5
2 24 26 14.5 4.5 26 17.6023 4.5
Needs 2 More Votes (N)
Rene Rechthaler [Blechtaler]
2025-12-04 11:18:08
made from NewElementary pics, needs confirmation of the axle hole bottom to the ridges
2025-12-04 12:22:00
used a more rounded axlehole bottom
edited the part header.
2025-12-23 10:50:41
Header Edits
description:
to
2026-01-09 18:17:10
should I change that internal hi-res cylo to just a rect2p?
Gerald Lasser [GeraldLasser]
made the following comment.
2026-01-09 22:51:50
Yes, replacing the hires cylo with one or two rects is better, practically an invisible space
2026-01-10 11:29:04
fixed
