Unofficial File parts/u9377.dat
View official version of part
~Electric Technic Motor and Gearbox Plastic Axle
0 ~Electric Technic Motor and Gearbox Plastic Axle 0 Name: u9377.dat 0 Author: Jens Bauer [rockford] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS 12V, 4.5V, Gearbox, rotor 0 !HISTORY 2018-03-21 [cwdee] Adjust origin 0 !HISTORY 2018-04-01 [rockford] Adjusted positions, use hollow axles, added axle hole, end-cap + rubber-band grooves, changed title, added keywords 0 !HISTORY 2019-06-28 [PTadmin] Official Update 2019-01 0 !HISTORY 2025-12-20 [MagFors] Reshaped axleend
1 16 0 0 -.5 -1 0 0 0 0 1 0 1 0 axleend2.dat 1 16 0 0 2 1 0 0 0 0 1 0 3.8 0 axlehol8.dat 1 16 0 0 5.8 1 0 0 0 0 1 0 1.5 0 axlecaph2.dat 1 16 0 0 10.8 1 0 0 0 0 1 0 -1.5 0 axlecaph2.dat 1 16 0 0 10.8 1 0 0 0 0 1 0 8.2 0 axlehol8.dat 1 16 0 0 7.3 2.5 0 0 0 0 2.5 0 2 0 4-4cylo.dat 1 16 0 0 7.3 2.5 0 0 0 0 2.5 0 1 0 4-4edge.dat 1 16 0 0 9.3 2.5 0 0 0 0 2.5 0 1 0 4-4edge.dat 0 BFC INVERTNEXT 1 16 0 0 13 -2 0 0 0 0 2 0 10 0 4-4cylc.dat 1 16 0 0 19 1 0 0 0 0 1 0 1 0 axlehol3.dat 1 16 0 0 19 1 0 0 0 0 1 0 1 0 axleho10.dat 1 16 0 0 19 1 0 0 0 0 1 0 1 0 axlehol9.dat 1 16 0 0 19 1 0 0 0 0 1 0 4 0 axleho12.dat 1 16 0 0 23 2 0 0 0 0 -2 0 -1 0 4-4ndis.dat 1 16 0 0 23 6 0 0 0 0 -6 0 1 0 4-4edge.dat 1 16 0 0 23 6 0 0 0 0 -6 0 -1 0 1-8chrd.dat 1 16 0 0 23 0 0 6 -6 0 0 0 -1 0 1-8chrd.dat 4 16 4.2426 -4.2426 23 6 0 23 2 0 23 2 -2 23 4 16 4.2426 -4.2426 23 2 -2 23 0 -2 23 0 -6 23 1 16 0 0 23 0 0 6 6 0 0 0 -1 0 1-8chrd.dat 1 16 0 0 23 6 0 0 0 0 6 0 -1 0 1-8chrd.dat 4 16 4.2426 4.2426 23 0 6 23 0 2 23 2 2 23 4 16 4.2426 4.2426 23 2 2 23 2 0 23 6 0 23 1 16 0 0 23 -6 0 0 0 0 6 0 -1 0 1-8chrd.dat 1 16 0 0 23 0 0 -6 6 0 0 0 -1 0 1-8chrd.dat 4 16 -4.2426 4.2426 23 -6 0 23 -2 0 23 -2 2 23 4 16 -4.2426 4.2426 23 -2 2 23 0 2 23 0 6 23 1 16 0 0 23 0 0 -6 -6 0 0 0 -1 0 1-8chrd.dat 1 16 0 0 23 -6 0 0 0 0 -6 0 -1 0 1-8chrd.dat 4 16 -4.2426 -4.2426 23 0 -6 23 0 -2 23 -2 -2 23 4 16 -4.2426 -4.2426 23 -2 -2 23 -2 0 23 -6 0 23
None
2025-12-21 21:20:34
made the following comment.
2025-12-21 21:32:03
Maybe I should close the mesh?
2025-12-22 17:01:31
Closed mesh.
Rene Rechthaler [Blechtaler]
posted a vote of Certify.
2025-12-22 17:04:56
cancelled their vote.
2025-12-22 20:35:57
checked a 4V motor with broken axle stub: the fracture is closed, the inner hole seems to be not that deep...
(whats the difference to 172.dat then? why is this part then still named "Motor and Gearbox Plastic Axle" if the gearbox has a separate one?)
2025-12-22 20:50:11
I haven't got a clue.
Give me something to work with, or approve the current one.
Or should I remove the hole?
2025-12-22 20:57:13
suggestion: shorten the inverted cylc to about 10-12 LDU, then it stops before the rubber band notch
(that notch is already the weakest point, no need to weaken it further with the hole)
2025-12-22 22:16:55
2025-12-22 22:21:49
should the "gearbox" get removed from title/keywords?
This part is copyright © Jens Bauer
LDraw.org Parts Tracker, Chris Dee, Magnus Forsberg
