Unofficial File parts/s/7885s01.dat
~Car Base  2 x  6 with Bottom Axle Holes - Qarter Axle Hole
0 ~Car Base 2 x 6 with Bottom Axle Holes - Qarter Axle Hole 0 Name: s\7885s01.dat 0 Author: Rene Rechthaler [Blechtaler] 0 !LDRAW_ORG Unofficial_Subpart 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW
0 // axlehole end and cutout 1 16 .5 10 0 0 -1 0 2 0 0 0 0 2 2-4ring2.dat 0 BFC INVERTNEXT 1 16 8.75 17.5 0 0 0 6.25 -1.5 0 0 0 2 0 box3u7a.dat 1 16 1.5 15.80115 1 1 0 0 0 1 -.19885 0 0 1 rect3.dat 1 16 17.5 15.80115 1 2.5 0 0 0 1 -.19885 0 0 1 rect3.dat 1 16 8.75 15.80115 2 0 0 6.25 .19885 0 0 0 1 0 rect2p.dat 5 24 20 16 0 15 16 0 20 15.6023 2 20 16 -1 5 24 .5 16 0 2.5 16 0 .5 15.6023 2 0 16 -1 2 24 .5 6 2 .5 6.7951 2.265 2 24 .5 6 2 .5 4.3977 2 2 24 .5 8 4 .5 8 5.6023 2 24 .5 7.735 3.2049 .5 8 4 2 24 .5 12 5.6023 .5 10 6 2 24 .5 12 5.6023 .5 12 4 2 24 .5 8 5.6023 .5 10 6 2 24 .5 15.6023 2 .5 14 2 2 24 .5 13.2049 2.265 .5 14 2 2 24 .5 4 0 .5 4.3977 2 2 24 .5 12.265 3.2049 .5 12 4 3 16 2.5 16 0 2.5 16 2 2.5 15.6023 2 3 16 15 16 2 15 16 0 15 15.6023 2 0 // connector to outside 4 16 20 19.239 3.827 20 15.6023 2 20 16 0 20 20 0 3 16 20 15.6023 2 20 19.239 3.827 20 15.5432 2.2961 4 16 20 14.2428 4.2427 20 15.5432 2.2961 20 19.239 3.827 20 17.071 7.071 4 16 20 12.2961 5.5433 20 14.2428 4.2427 20 17.071 7.071 20 13.827 9.239 3 16 20 12.2961 5.5433 20 13.827 9.239 20 12 5.6023 4 16 20 10 6 20 12 5.6023 20 13.827 9.239 20 10 10 4 16 20 10 6 20 10 10 20 8 10 20 8 5.6023 3 16 20 8 5.6023 20 8 10 20 7.7039 5.5433 3 16 20 7.7039 5.5433 20 8 10 20 5.7573 4.2428 4 16 20 8 10 20 0 0 20 4.4567 2.2961 20 5.7573 4.2428 3 16 20 4.4567 2.2961 20 0 0 20 4.3977 2 3 16 20 4.3977 2 20 0 0 20 4 0 0 // outside (inlined cylo) 2 24 20 13.827 9.239 20 17.071 7.071 2 24 20 17.071 7.071 20 19.239 3.827 1 16 18 11.9135 9.6195 0 0 2 1.9135 0 0 -.3805 -1 0 rect2p.dat 5 24 20 10 10 16 10 10 20 13.827 9.239 20 8 10 5 24 20 13.827 9.239 16 13.827 9.239 20 17.071 7.071 20 10 10 1 16 18 19.6195 1.9135 0 0 2 .3805 -1 0 -1.9135 0 0 rect2p.dat 5 24 20 19.239 3.827 16 19.239 3.827 20 20 0 20 17.071 7.071 5 24 20 20 0 16 20 0 20 19.239 3.827 20 20 -1 0 // rear connectors 4 16 16 14.1846 9 16 13.827 9.239 20 13.827 9.239 20 17.071 7.071 4 16 16 19 4.1846 20 17.071 7.071 20 19.239 3.827 16 19.239 3.827 2 24 16 13.827 9.239 16 14.1846 9 2 24 16 19 4.1846 16 19.239 3.827 2 24 16 19 0 16 19 4.1846 4 16 16 20 0 16 19 0 16 19 4.1846 16 19.239 3.827 1 16 18 9 10 2 0 0 0 0 -1 0 -1 0 rect3.dat 4 16 16 10 10 16 13.827 9.239 16 14.1846 9 16 8 10 3 16 16 8 10 16 14.1846 9 16 4 9 4 16 16 19 0 15 19 0 15 19 2 16 19 4.1846 3 16 16 19 4.1846 15 19 2 2.5 19 2
None
2026-01-04 00:59:56
Philippe Hurbain [Philo]
made the following comment.
2026-01-04 09:35:43
As axlehol4 contains an adapter ring, it would be better to use ndises instead of direct quads (but I can live with current solution!)
