Unofficial File parts/s/6178017as01.dat
0 ~Sticker 1.8 x 1.8 Round with Eye of a Rooster
0 Name: s\6178017as01.dat
0 Author: Manfred Schaefer [Lego-Manfred]
1 0 0 -.25 0 18 0 0 0 1 0 0 0 18 1-8chrd.dat
1 0 0 -.25 0 0 0 18 0 1 0 -18 0 0 3-16chrd.dat
1 0 0 -.25 0 -18 0 0 0 1 0 0 0 -18 1-16chrd.dat
1 0 0 -.25 0 0 0 -18 0 1 0 18 0 0 3-16chrd.dat
1 0 0 -.25 0 -18 0 0 0 1 0 0 0 18 1-16chrd.dat
1 0 0 -.25 0 0 0 -18 0 1 0 -18 0 0 3-16chrd.dat
1 0 0 -.25 0 18 0 0 0 1 0 0 0 -18 1-16chrd.dat
1 0 0 -.25 0 0 0 18 0 1 0 18 0 0 1-8chrd.dat
1 15 3.45 -.25 5 10.3 0 0 0 1 0 0 0 10.3 4-4disc.dat
1 0 3.45 -.25 5 -10.3 0 0 0 1 0 0 0 -10.3 2-4ndis.dat
1 0 3.45 -.25 5 -10.3 0 0 0 1 0 0 0 10.3 1-8tndis.dat
1 0 3.45 -.25 5 10.3 0 0 0 1 0 0 0 10.3 1-4tang.dat
1 0 3.45 -.25 5 0 0 -10.3 0 1 0 10.3 0 0 1-8tang.dat
1 15 -8.31 -.25 -8.5 1.3 0 0 0 1 0 0 0 1.3 4-4disc.dat
1 0 -8.31 -.25 -8.5 1.3 0 0 0 1 0 0 0 1.3 4-4ndis.dat
1 15 -11.47 -.25 -4.54 2.6 0 0 0 1 0 0 0 2.6 4-4disc.dat
1 0 -11.47 -.25 -4.54 2.6 0 0 0 1 0 0 0 2.6 4-4ndis.dat
1 15 -13.11 -.25 3.04 2.7 0 0 0 1 0 0 0 4 4-4disc.dat
1 0 -13.11 -.25 3.04 -2.7 0 0 0 1 0 0 0 -4 4-4ndis.dat
4 0 0 -.25 18 5.49867 -.25 15.3 7.39181 -.25 14.51617 12.7278 -.25 12.7278
3 0 12.7278 -.25 12.7278 7.39181 -.25 14.51617 9.28495 -.25 13.73234
3 0 12.7278 -.25 12.7278 9.28495 -.25 13.73234 10.73313 -.25 12.28313
3 0 12.7278 -.25 12.7278 10.73313 -.25 12.28313 12.18234 -.25 10.83495
3 0 12.7278 -.25 12.7278 12.18234 -.25 10.83495 12.96617 -.25 8.94181
3 0 12.7278 -.25 12.7278 12.96617 -.25 8.94181 13.75 -.25 7.04867
3 0 12.7278 -.25 12.7278 13.75 -.25 7.04867 18 -.25 0
3 0 13.75 -.25 7.04867 13.75 -.25 5 18 -.25 0
4 0 13.75 -.25 5 13.75 -.25 -5.3 16.6302 -.25 -6.8886 18 -.25 0
4 0 16.6302 -.25 -6.8886 13.75 -.25 -5.3 3.45 -.25 -5.3 0 -.25 -18
3 0 3.45 -.25 -5.3 -6.85 -.25 -5.3 0 -.25 -18
3 0 0 -.25 18 3.45 -.25 15.3 5.49867 -.25 15.3
3 0 0 -.25 18 1.40133 -.25 15.3 3.45 -.25 15.3
3 0 0 -.25 18 -2.38495 -.25 13.73234 -0.49181 -.25 14.51617
3 0 0 -.25 18 -0.49181 -.25 14.51617 1.40133 -.25 15.3
4 0 0 -.25 18 -6.85 -.25 12.28313 -3.83313 -.25 12.28313 -2.38495 -.25 13.73234
4 0 0 -.25 18 -16.6302 -.25 6.8886 -15.81 -.25 7.04 -6.85 -.25 12.28313
3 0 -6.85 -.25 12.28313 -15.81 -.25 7.04 -13.11 -.25 7.04
3 0 -6.85 -.25 12.28313 -13.11 -.25 7.04 -10.41 -.25 7.04
4 0 -15.81 -.25 7.04 -16.6302 -.25 6.8886 -18 -.25 0 -15.81 -.25 3.04
4 0 -15.81 -.25 3.04 -18 -.25 0 -16.6302 -.25 -6.8886 -15.81 -.25 -0.96
4 0 -15.81 -.25 -0.96 -14.07 -.25 -1.94 -11.47 -.25 -1.94 -13.11 -.25 -0.96
4 0 -13.11 -.25 -0.96 -11.47 -.25 -1.94 -8.87 -.25 -1.94 -10.41 -.25 -0.96
4 0 -11.47 -.25 -7.14 -9.61 -.25 -7.2 -8.31 -.25 -7.2 -8.87 -.25 -7.14
4 0 -15.81 -.25 -0.96 -16.6302 -.25 -6.8886 -14.07 -.25 -4.54 -14.07 -.25 -1.94
3 0 -14.07 -.25 -4.54 -16.6302 -.25 -6.8886 -14.07 -.25 -7.14
3 0 -11.47 -.25 -7.14 -9.61 -.25 -8.5 -9.61 -.25 -7.2
4 0 -14.07 -.25 -7.14 -9.61 -.25 -9.8 -9.61 -.25 -8.5 -11.47 -.25 -7.14
4 0 -16.6302 -.25 -6.8886 0 -.25 -18 -9.61 -.25 -9.8 -14.07 -.25 -7.14
3 0 -9.61 -.25 -9.8 0 -.25 -18 -8.31 -.25 -9.8
3 0 -8.31 -.25 -9.8 0 -.25 -18 -7.01 -.25 -9.8
3 0 -7.01 -.25 -8.5 -7.01 -.25 -9.8 0 -.25 -18
4 0 -6.85 -.25 -5.3 -7.01 -.25 -7.2 -7.01 -.25 -8.5 0 -.25 -18
4 0 -6.85 -.25 12.28313 -10.41 -.25 7.04 -10.41 -.25 3.04 -6.85 -.25 5
4 0 -6.85 -.25 5 -10.41 -.25 3.04 -10.41 -.25 -0.96 -8.87 -.25 -1.94
4 0 -6.85 -.25 5 -8.87 -.25 -1.94 -8.87 -.25 -4.54 -6.85 -.25 -5.3
3 0 -6.85 -.25 -5.3 -8.31 -.25 -7.2 -7.01 -.25 -7.2
4 0 -8.87 -.25 -4.54 -8.87 -.25 -7.14 -8.31 -.25 -7.2 -6.85 -.25 -5.3
Needs 2 More Votes (N)
2026-01-05 17:47:54
renamed the part.
2026-01-05 18:18:00
"parts/s/6178017s01.dat" to "parts/s/6178017as01.dat"
posted a vote of Hold
2026-01-05 18:19:39
The edge primitive must be removed
2026-01-05 18:51:33
Correction of the file name.
made the following comment.
2026-01-05 18:55:59
The edge primitive was removed.
Rene Rechthaler [Blechtaler]
2026-01-06 18:30:22
sticker is a paper sticker (not transparent) -> pattern spots should be hardcoded white
2026-01-07 19:26:04
The color of the spots is now set to white.
2026-04-22 20:52:29
you could set everything to Y=0 and move it in the main part (saves a tiny bit of code size)
