Unofficial File parts/56890.dat
Tyre 12/ 61 x 11 Balloon
0 Tyre 12/ 61 x 11 Balloon
0 Name: 56890.dat
0 !CATEGORY Tyre
0 !KEYWORDS 24 x 12 R, Brickowl 587775, rim 30190, rim 6014a, rim 6014b
0 !HISTORY 2009-10-13 {LEGO Universe Team} Original part shape
0 !HISTORY 2010-05-17 [MagFors] File preparation for LDraw Parts Tracker
0 !HISTORY 2013-05-20 [MagFors] Moved origin, Changed description to standardized nomenclature
0 !HISTORY 2020-03-07 [MagFors] Corrected description
0 !HISTORY 2020-03-07 [MagFors] Replaced bad LDD shape with good from Arezey
0 !HISTORY 2026-01-15 [Blechtaler] used ndis for sidewall instead rings
0 // Nomenclature: width_(mm)/profile_as_%age_of_width x rim_diameter_(mm) [optional qualifier]
0 // tread
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\56890s01.dat
1 16 0 0 0 0 -1 0 1 0 0 0 0 1 s\56890s01.dat
1 16 0 0 0 -1 0 0 0 -1 0 0 0 1 s\56890s01.dat
1 16 0 0 0 0 1 0 -1 0 0 0 0 1 s\56890s01.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 -1 s\56890s01.dat
1 16 0 0 0 0 1 0 1 0 0 0 0 -1 s\56890s01.dat
1 16 0 0 0 1 0 0 0 -1 0 0 0 -1 s\56890s01.dat
1 16 0 0 0 0 -1 0 -1 0 0 0 0 -1 s\56890s01.dat
1 16 0 0 14 1 0 0 0 0 1 0 -1 0 4-4rin13.dat
1 16 0 0 -14 1 0 0 0 0 1 0 1 0 4-4rin13.dat
0 // inside
1 16 0 0 -1 12.5 0 0 0 0 12.5 0 2 0 4-4cylo.dat
1 16 0 0 -14 13 0 0 0 0 13 0 12 0 4-4cylo.dat
1 16 0 0 2 13 0 0 0 0 13 0 12 0 4-4cylo.dat
1 16 0 0 2 0.5 0 0 0 0 0.5 0 -1 0 4-4con25.dat
1 16 0 0 -2 0.5 0 0 0 0 0.5 0 1 0 4-4con25.dat
Rene Rechthaler [Blechtaler]
2026-01-15 11:35:18
used ndis+quads instead of 5 stacked rings
should I also extend the subfile from 1/16 to 1/4? would solve both the excessive decimals and the gaps due to rounding...
2026-01-15 16:13:49
with bigger subpart to avoid rotation
