Unofficial File parts/3070bpz5.dat
Tile  1 x  1 with 3 Black Rectangles and Red Switch Pattern
0 Tile  1 x  1 with 3 Black Rectangles and Red Switch Pattern
0 Name: 3070bpz5.dat
0 Author: Peter Grass [Evilspyre]
0 !CATEGORY Tile
0 !KEYWORDS BrickLink 3070pb365, Brickowl 1159678, Brickset 109290, Harry Potter
0 !KEYWORDS Rebrickable 3070bpr0323, Set 76437, Set 76451, UK Power Socket
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3070bs01.dat
1 16 8.2 0 8.49 1 0 0 0 1 0 0 0 1 1-4ndis.dat
1 72 8.2 0 8.49 1 0 0 0 1 0 0 0 1 1-4chrd.dat
1 16 6.87 0 8.49 -1 0 0 0 1 0 0 0 1 1-4ndis.dat
1 72 6.87 0 8.49 -1 0 0 0 1 0 0 0 1 1-4chrd.dat
1 16 6.87 0 4.77 -1 0 0 0 1 0 0 0 -1 1-4ndis.dat
1 72 6.87 0 4.77 -1 0 0 0 1 0 0 0 -1 1-4chrd.dat
1 16 8.2 0 4.77 1 0 0 0 1 0 0 0 -1 1-4ndis.dat
1 72 8.2 0 4.77 1 0 0 0 1 0 0 0 -1 1-4chrd.dat
3 16 -5.06 0 -6.97 -10 0 -10 -4.92 0 -7.13
3 16 5.02 0 -6.97 4.84 0 -7.13 10 0 -10
3 16 4.84 0 -7.13 2.57 0 -7.13 10 0 -10
3 16 10 0 -10 2.57 0 -7.13 -2.58 0 -7.13
3 16 -10 0 0 -1.17 0 -.06 -1.17 0 3.26
3 16 8.2 0 3.77 6.87 0 3.77 10 0 0
3 16 8.2 0 3.77 10 0 0 9.2 0 3.77
3 16 9.2 0 4.77 9.2 0 3.77 10 0 0
3 16 5.87 0 8.49 5.87 0 9.49 0 0 10
3 16 8.2 0 9.49 9.2 0 9.49 10 0 10
3 16 9.2 0 9.49 9.2 0 8.49 10 0 10
3 16 1.11 0 -.06 5.87 0 3.77 1.11 0 3.26
3 16 10 0 10 6.87 0 9.49 8.2 0 9.49
4 16 8.38 0 7.68 6.78 0 7.68 6.78 0 4.77 8.38 0 4.77
4 16 9.2 0 8.49 9.2 0 4.77 10 0 0 10 0 10
4 16 2.4 0 -5.34 2.57 0 -5.23 -2.58 0 -5.23 -2.44 0 -5.34
4 16 2.4 0 -6.97 -2.44 0 -6.97 -2.58 0 -7.13 2.57 0 -7.13
4 16 6.87 0 3.77 4.84 0 -5.23 5.02 0 -5.34 10 0 0
4 16 10 0 0 5.02 0 -5.34 5.02 0 -6.97 10 0 -10
4 16 -4.92 0 -7.13 -10 0 -10 10 0 -10 -2.58 0 -7.13
4 16 -2.44 0 -5.34 -2.44 0 -6.97 2.4 0 -6.97 2.4 0 -5.34
4 16 -1.01 0 -.25 -2.58 0 -5.23 2.57 0 -5.23 .98 0 -.25
4 16 1.11 0 -.06 .98 0 -.25 2.57 0 -5.23 4.84 0 -5.23
4 16 -1.01 0 -.25 -1.17 0 -.06 -4.92 0 -5.23 -2.58 0 -5.23
4 16 -10 0 0 -1.17 0 3.26 -1.01 0 3.4 -10 0 10
4 16 -1.17 0 -.06 -10 0 0 -5.06 0 -5.34 -4.92 0 -5.23
4 16 -10 0 -10 -5.06 0 -6.97 -5.06 0 -5.34 -10 0 0
4 16 -10 0 10 -1.01 0 3.4 .96 0 3.4 0 0 10
4 16 6.78 0 4.77 6.98 0 4.59 8.202 0 4.59 8.38 0 4.77
4 16 5.87 0 4.77 5.87 0 8.49 0 0 10 .96 0 3.4
4 16 5.87 0 3.77 5.87 0 4.77 .96 0 3.4 1.11 0 3.26
4 16 1.11 0 -.06 4.84 0 -5.23 6.87 0 3.77 5.87 0 3.77
4 16 0 0 10 5.87 0 9.49 6.87 0 9.49 10 0 10
4 4 8.38 0 7.68 8.202 0 8.71 6.98 0 8.71 6.78 0 7.68
3 4 6.78 0 8.5 6.78 0 7.68 6.98 0 8.71
3 4 8.38 0 7.68 8.38 0 8.5 8.202 0 8.71
4 0 -2.44 0 -6.97 -2.44 0 -5.34 -2.58 0 -5.23 -2.58 0 -7.13
4 0 -5.06 0 -6.97 -4.92 0 -7.13 -4.92 0 -5.23 -5.06 0 -5.34
4 0 -4.92 0 -7.13 -2.58 0 -7.13 -2.58 0 -5.23 -4.92 0 -5.23
4 0 2.57 0 -5.23 2.4 0 -5.34 2.4 0 -6.97 2.57 0 -7.13
4 0 5.02 0 -6.97 5.02 0 -5.34 4.84 0 -5.23 4.84 0 -7.13
4 0 4.84 0 -7.13 4.84 0 -5.23 2.57 0 -5.23 2.57 0 -7.13
4 0 -1.17 0 -.06 -1.01 0 -.25 -1.01 0 3.4 -1.17 0 3.26
4 0 1.11 0 -.06 1.11 0 3.26 .96 0 3.4 .98 0 -.25
4 0 -1.01 0 -.25 .98 0 -.25 .96 0 3.4 -1.01 0 3.4
3 72 8.38 0 7.68 9.2 0 8.49 8.38 0 8.5
4 72 6.98 0 4.59 6.87 0 3.77 8.2 0 3.77 8.202 0 4.59
4 72 9.2 0 8.49 8.38 0 7.68 8.38 0 4.77 9.2 0 4.77
4 72 8.202 0 8.71 8.2 0 9.49 6.87 0 9.49 6.98 0 8.71
3 72 6.78 0 7.68 6.78 0 8.5 5.87 0 8.49
4 72 6.78 0 4.77 6.78 0 7.68 5.87 0 8.49 5.87 0 4.77
4 72 6.87 0 3.77 6.98 0 4.59 6.78 0 4.77 5.87 0 4.77
4 72 8.38 0 4.77 8.202 0 4.59 8.2 0 3.77 9.2 0 4.77
4 72 6.78 0 8.5 6.98 0 8.71 6.87 0 9.49 5.87 0 8.49
4 72 8.2 0 9.49 8.202 0 8.71 8.38 0 8.5 9.2 0 8.49
Part Author
2026-02-21 15:51:40
Part Reviewer
made the following comment.
2026-02-21 15:58:09
Triangle:
3 8 8.38 0 9.49 8.66 0 9.4 10 0 10
overlaps with other triangles (upper right corner).
Part Reviewer
2026-02-21 16:02:10
Some of the lines that form the rectangles are not perfectly horizontal or vertical. Consider using primitives at the corners.
Part Author
2026-02-21 18:20:34
I did think about using prims for the corners, since I don't like the number of small triangles used to get the curves. I will upload a fixed version for now and see what I can do about making it use the primatives later on.
Part Author
2026-02-21 18:31:44
Part Author
2026-02-21 19:15:01
2026-02-21 20:37:42
*yes using prims here sounds like a good idea to me
*I don't think the black rectangles (forming the actual "plug socket") are meant to have rounded corners - real ones seem to have sharp corners
Rene Rechthaler [Blechtaler]
2026-02-21 22:33:21
I think only the outer switch corners should use 1-4chrd+ndis, all other ones should be at most a single 45° chamfer
Philippe Hurbain [Philo]
2026-02-22 05:46:29
Completely agree with René.
Part Author
2026-02-22 07:27:26
the lego design does have rounded corners for the 3 black rectangles even if actual UK plug sockets don't have them.
Here is the original texture:
https://i.postimg.cc/fLbpR0bg/1037422-0-VME-11003070-LEG-Top-1.png
2026-02-22 14:23:12
Considering the ridiculously small size of these rounded corners (less that 0.3ldu!), I still maintain that a 45° bevel is more than enough. Think of it as a 4\1-4disc :D
Part Reviewer
2026-02-22 17:48:26
I agree with René and Philo. Keeping the three black objects as rectangles (I’m also fine with 45° chamfers) and using 1–4chrd+ndis only for the outer switch corners is a good compromise between image accuracy, polygon count, and the use of primitives. At the moment, there are very small triangles on the switch corners, and we should avoid leaving it that way.
Part Author
2026-02-24 18:57:07
New and improved and now with added 1–4chrd+ndis's
Part Author
2026-02-24 18:59:13
2026-02-24 19:31:13
i think the 45° chamfer should also be at the inner switch corners (not as critical as the other ones)
Part Author
2026-02-24 19:47:29
OK I changed that too.
