Unofficial File parts/s/7798s01.dat
0 ~Tile 6 x 6 with Rounded Underside Corners without Top Face
0 Name: s\7798s01.dat
0 Author: Peter Grass [Evilspyre]
1 16 0 8 0 56 0 0 0 -4 0 0 0 56 box5.dat
1 16 0 7 0 60 0 0 0 -7 0 0 0 60 box4.dat
1 16 0 4 0 1 0 0 0 -1 0 0 0 1 stug4-5x5.dat
3 16 -59.098 7 -59.094 -60 7 -60 -59.5 7 -58.066
4 16 -59.5 7 -58.066 -60 7 -60 -60 7 60 -59.5 7 58.066
3 16 -60 7 60 -59.098 7 59.094 -59.5 7 58.066
3 16 -58.069 7 -59.5 -60 7 -60 -59.098 7 -59.094
4 16 60 7 -60 -60 7 -60 -58.069 7 -59.5 58.069 7 -59.5
3 16 60 7 -60 58.069 7 -59.5 59.098 7 -59.094
4 16 -59.5 7 58.066 -59.2 8 57.794 -59.2 8 -57.794 -59.5 7 -58.066
3 16 -58.833 8 -58.833 -59.5 7 -58.066 -59.2 8 -57.794
3 16 -58.833 8 -58.833 -59.098 7 -59.094 -59.5 7 -58.066
3 16 -58.833 8 58.833 -59.2 8 57.794 -59.5 7 58.066
3 16 -58.833 8 58.833 -59.5 7 58.066 -59.098 7 59.094
4 16 58.069 7 -59.5 -58.069 7 -59.5 -57.794 8 -59.2 57.794 8 -59.2
3 16 -58.833 8 -58.833 -57.794 8 -59.2 -58.069 7 -59.5
3 16 -58.833 8 -58.833 -58.069 7 -59.5 -59.098 7 -59.094
3 16 58.069 7 -59.5 57.794 8 -59.2 58.833 8 -58.833
3 16 58.069 7 -59.5 58.833 8 -58.833 59.098 7 -59.094
3 16 58.833 8 -58.833 59.5 7 -58.066 59.098 7 -59.094
3 16 58.833 8 -58.833 59.2 8 -57.794 59.5 7 -58.066
3 16 58.833 8 58.833 59.5 7 58.066 59.2 8 57.794
3 16 58.833 8 58.833 59.098 7 59.094 59.5 7 58.066
3 16 60 7 -60 59.098 7 -59.094 59.5 7 -58.066
4 16 59.5 7 -58.066 59.5 7 58.066 60 7 60 60 7 -60
3 16 59.098 7 59.094 60 7 60 59.5 7 58.066
4 16 58.069 7 59.5 -58.069 7 59.5 -60 7 60 60 7 60
3 16 -60 7 60 -58.069 7 59.5 -59.098 7 59.094
3 16 58.069 7 59.5 60 7 60 59.098 7 59.094
3 16 -58.069 7 59.5 -58.833 8 58.833 -59.098 7 59.094
3 16 -58.069 7 59.5 -57.794 8 59.2 -58.833 8 58.833
4 16 57.794 8 59.2 -57.794 8 59.2 -58.069 7 59.5 58.069 7 59.5
3 16 58.833 8 58.833 57.794 8 59.2 58.069 7 59.5
3 16 58.833 8 58.833 58.069 7 59.5 59.098 7 59.094
4 16 -59.2 8 57.794 -56 8 56 -56 8 -56 -59.2 8 -57.794
4 16 -58.833 8 -58.833 -59.2 8 -57.794 -56 8 -56 -57.794 8 -59.2
4 16 57.794 8 -59.2 56.002 8 -56 59.2 8 -57.794 58.833 8 -58.833
4 16 -58.833 8 58.833 -57.794 8 59.2 -56 8 56 -59.2 8 57.794
4 16 59.2 8 57.794 59.2 8 -57.794 56.002 8 -56 56 8 56
4 16 57.794 8 59.2 56 8 56 -56 8 56 -57.794 8 59.2
4 16 57.794 8 59.2 58.833 8 58.833 59.2 8 57.794 56 8 56
5 24 -58.069 7 59.5 -58.833 8 58.833 -57.794 8 59.2 -59.098 7 59.094
5 24 58.833 8 58.833 59.098 7 59.094 58.069 7 59.5 59.5 7 58.066
5 24 58.833 8 58.833 59.5 7 58.066 59.2 8 57.794 59.098 7 59.094
5 24 58.069 7 -59.5 57.794 8 -59.2 58.833 8 -58.833 -58.069 7 -59.5
5 24 59.5 7 58.066 59.2 8 57.794 59.5 7 -58.066 58.833 8 58.833
2 24 59.2 8 57.794 58.833 8 58.833
2 24 59.098 7 59.094 59.5 7 58.066
2 24 57.794 8 -59.2 58.833 8 -58.833
2 24 -59.2 8 57.794 -59.2 8 -57.794
5 24 -58.833 8 58.833 -59.098 7 59.094 -59.5 7 58.066 -58.069 7 59.5
2 24 59.098 7 -59.094 59.5 7 -58.066
2 24 58.833 8 -58.833 59.2 8 -57.794
2 24 58.069 7 59.5 -58.069 7 59.5
2 24 57.794 8 59.2 -57.794 8 59.2
2 24 58.069 7 -59.5 59.098 7 -59.094
5 24 -58.069 7 59.5 -57.794 8 59.2 -58.833 8 58.833 58.069 7 59.5
2 24 -57.794 8 59.2 -58.833 8 58.833
2 24 -58.833 8 -58.833 -57.794 8 -59.2
5 24 -59.5 7 -58.066 -59.2 8 -57.794 -59.5 7 58.066 -58.833 8 -58.833
5 24 58.833 8 -58.833 59.098 7 -59.094 59.5 7 -58.066 58.069 7 -59.5
2 24 -59.098 7 59.094 -59.5 7 58.066
2 24 -59.2 8 -57.794 -58.833 8 -58.833
2 24 -58.069 7 -59.5 58.069 7 -59.5
2 24 -58.833 8 58.833 -59.2 8 57.794
2 24 -59.5 7 -58.066 -59.098 7 -59.094
5 24 -59.2 8 57.794 -59.5 7 58.066 -58.833 8 58.833 -59.2 8 -57.794
2 24 59.5 7 58.066 59.5 7 -58.066
5 24 -59.5 7 58.066 -58.833 8 58.833 -59.098 7 59.094 -59.2 8 57.794
5 24 58.833 8 -58.833 58.069 7 -59.5 57.794 8 -59.2 59.098 7 -59.094
5 24 -58.069 7 -59.5 -58.833 8 -58.833 -59.098 7 -59.094 -57.794 8 -59.2
2 24 -59.5 7 58.066 -59.5 7 -58.066
5 24 58.833 8 -58.833 59.5 7 -58.066 59.2 8 -57.794 59.098 7 -59.094
2 24 -59.098 7 -59.094 -58.069 7 -59.5
2 24 59.2 8 -57.794 59.2 8 57.794
2 24 -58.069 7 59.5 -59.098 7 59.094
2 24 59.098 7 59.094 58.069 7 59.5
5 24 -58.833 8 -58.833 -59.098 7 -59.094 -58.069 7 -59.5 -59.5 7 -58.066
2 24 -57.794 8 -59.2 57.794 8 -59.2
2 24 58.833 8 58.833 57.794 8 59.2
5 24 -57.794 8 -59.2 -58.069 7 -59.5 57.794 8 -59.2 -58.833 8 -58.833
5 24 57.794 8 59.2 58.069 7 59.5 -57.794 8 59.2 58.833 8 58.833
5 24 -58.833 8 -58.833 -59.5 7 -58.066 -59.098 7 -59.094 -59.2 8 -57.794
5 24 59.2 8 -57.794 59.5 7 -58.066 58.833 8 -58.833 59.2 8 57.794
5 24 58.069 7 59.5 58.833 8 58.833 57.794 8 59.2 59.098 7 59.094
4 16 59.5 7 58.066 59.5 7 -58.066 59.2 8 -57.794 59.2 8 57.794
4 16 -57.794 8 -59.2 -56 8 -56 56 8 -56 57.794 8 -59.2
Errors Found (HN)
| User | Vote |
| GeraldLasser | Hold |
2026-03-06 01:03:36
Rene Rechthaler [Blechtaler]
made the following comment.
2026-03-07 22:48:23
why the slightly slanted groove? would it work with vertical 1x1 LDU groove (rect2p) and p8 1-4cylo corners?
Vincent Messenet [Cheenzo]
posted a vote of Hold
2026-03-10 21:04:04
stug4-5x5 prim missing
2026-03-11 06:00:09
Ah I didn't realise it had any bottom tubes, I will add them.
I kept the slant as it was in the original model they aren't square corners they are slightly sloped.
2026-03-11 06:14:33
2026-04-13 22:17:01
could still use slightly slanted 8\1-4cylo
Gerald Lasser [GeraldLasser]
2026-04-14 09:03:08
This needs to include the description of the surface
This part is copyright ©
Peter Grass
Licensed under
CC BY 4.0
