Unofficial File parts/s/3815bs02.dat
~Minifig Hips without Decorated Surface or Studs
0 ~Minifig Hips without Decorated Surface or Studs 0 Name: s\3815bs02.dat 0 Author: Philippe Hurbain [Philo] 0 !LDRAW_ORG Unofficial_Subpart 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW
2 24 18 0 -10 18 6 -10 2 24 -18 0 -10 -18 6 -10 1 16 0 3 0 -18 0 0 0 -3 0 0 0 10 box2-5.dat 0 BFC INVERTNEXT 1 16 -18 12 0 0 36 0 -6.18718 0 -6.18718 6.18718 0 -6.18718 1-4cylo.dat 1 16 18 12 0 0 -1 0 -8.75 0 0 0 0 -8.75 1-8ndis.dat 1 16 18 12 0 0 -1 0 -8.75 0 0 0 0 8.75 1-8ndis.dat 1 16 -18 12 0 0 1 0 -8.75 0 0 0 0 -8.75 1-8ndis.dat 1 16 -18 12 0 0 1 0 -8.75 0 0 0 0 8.75 1-8ndis.dat 1 16 -9.92 12 0 0 19.84 0 3 0 0 0 0 3 4-4cylc.dat 1 16 9.92 12 0 0 -1 0 3 0 0 0 0 3 4-4disc.dat 1 16 -2 12 0 0 1 0 3 0 0 0 0 3 4-4edge.dat 1 16 2 12 0 0 1 0 3 0 0 0 0 3 4-4edge.dat 1 16 0 6 -8.155 -18 0 0 0 -1 0 0 0 1.845 rect.dat 1 16 0 5.9064 -6.2486 0 0 18 -.0936 -1 0 .0614 0 0 rect2p.dat 1 16 0 6 8.155 18 0 0 0 -1 0 0 0 -1.845 rect3.dat 1 16 0 5.9064 6.2486 0 0 18 .0936 -1 0 .0614 0 0 rect2p.dat 4 16 18 3.25 -8.75 18 6 -10 18 6 -6.31 18 5.8128 -6.1872 3 16 18 3.25 -8.75 18 0 -10 18 6 -10 3 16 18 0 -10 18 3.25 -8.75 18 3.2501 0 4 16 18 0 10 18 0 -10 18 3.2501 0 18 3.25 8.75 3 16 18 6 10 18 0 10 18 3.25 8.75 4 16 18 3.25 8.75 18 5.8128 6.1872 18 6 6.31 18 6 10 4 16 -18 3.25 8.75 -18 6 10 -18 6 6.31 -18 5.8128 6.1872 3 16 -18 3.25 8.75 -18 0 10 -18 6 10 4 16 -18 0 -10 -18 0 10 -18 3.25 8.75 -18 3.2501 0 3 16 -18 3.2501 0 -18 3.25 -8.75 -18 0 -10 3 16 -18 6 -10 -18 0 -10 -18 3.25 -8.75 4 16 -18 3.25 -8.75 -18 5.8128 -6.1872 -18 6 -6.31 -18 6 -10 1 16 2 12 0 0 -1 0 8.75 0 0 0 0 8.75 4-4disc.dat 1 16 -2 12 0 0 1 0 8.75 0 0 0 0 8.75 4-4disc.dat 1 16 2 12 0 0 -1 0 8.75 0 0 0 0 8.75 4-4edge.dat 1 16 -2 12 0 0 1 0 8.75 0 0 0 0 8.75 4-4edge.dat 1 16 -2 12 0 0 4 0 8.08395 0 3.34848 -3.34848 0 8.08395 7-16cyli.dat
    Line 13: 1 16 -18 12 0 0 36 0 -6.18718 0 -6.18718 6.18718 0 -6.18718 1-4cylo.dat
    Line 43: 1 16 -2 12 0 0 4 0 8.08395 0 3.34848 -3.34848 0 8.08395 7-16cyli.dat
None
2026-03-12 09:58:20
Rene Rechthaler [Blechtaler]
made the following comment.
2026-03-12 11:10:05
should the prims get split/unrotated? (like the big 1-4 into 4 unrotated 1-8, the 7-16cyli into 1-16cyli+3-8cylo)
can I reuse it for s\18849s01.dat?
2026-03-12 12:09:46
"should the prims get split/unrotated"
Why change something that worked well for years?
"can I reuse it for s\18849s01.dat?"
Why not???
LDraw.org Parts Tracker,
