Unofficial File parts/3024p04.dat
Part Attributes: Base Part: 3024.dat
Plate  1 x  1 with Small Black Rectangle Pattern
0 Plate 1 x 1 with Small Black Rectangle Pattern 0 Name: 3024p04.dat 0 Author: Gabriel Läufer [Dr.Bricktacular] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !CATEGORY Plate 0 !KEYWORDS BrickLink 3024pb006, Brickowl 508033, Brickset 18965, Minecraft 0 !KEYWORDS Minecraft Micro World - The Village, Rebrickable 3024pr0006 0 !KEYWORDS Set 21105, Set 21119, Set 508033, The Dungeon
0 // Pattern-Basepart 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3024s01.dat 0 // Pattern 4 0 2 1 -10 -2 1 -10 -2 3 -10 2 3 -10 4 16 -2 1 -10 -10 0 -10 -10 8 -10 -2 3 -10 4 16 10 0 -10 2 1 -10 2 3 -10 10 8 -10 4 16 -10 0 -10 -2 1 -10 2 1 -10 10 0 -10 4 16 2 3 -10 -2 3 -10 -10 8 -10 10 8 -10
Not releaseable Errors Found (HN) Errors Found (HN)
User Vote
KnightOfTarenta Hold
Part Reviewer
2026-05-16 20:09:51
Gerald Lasser [GeraldLasser]
edited the part header.
2026-05-17 09:13:25
Header Edits
description:
Plate 1 x 1 with Small Black Square Pattern
to
Comment:
posted a vote of Certify
2026-05-17 09:13:36
posted a vote of Hold
2026-05-17 18:54:31
Something is off here.
Your RB link is broken and the BL link refers to an already existing piece in LDraw (https://library.ldraw.org/parts/4228).
Please verify you mean the correct piece/pattern.
made the following comment.
2026-05-17 19:03:34
*If this is indeed meant to be ElementID 6093263 (BL 3024pb006), you might choose to make the older file a ~Moved to.
*Anyways if this is 3024pb006, then the rectangle should be Dark Green not Black
cancelled their vote.
2026-05-17 21:52:14
This part is copyright © Gabriel Läufer
