0 Tyre 8/ 75 x 8 Offset Tread
0 Name: 4084.dat
0 Author: James Jessiman
0 !KEYWORDS Brickowl 850402
0 !HISTORY 2007-07-01 [PTadmin] Header formatted for Contributor Agreement
0 !HISTORY 2008-10-18 [tchang] Add BFC
0 !HISTORY 2020-03-01 [MagFors] used primitives, added inner ridge, removed T-junctions
0 !HISTORY 2026-05-29 [Blechtaler] corrected diameter, added rear ridge, used tread subpart
0 // Nomenclature: width_(mm)/profile_as_%age_of_width x rim_diameter_(mm)
0 // center
1 16 0 0 -12 0 0 14 14 0 0 0 1 0 4-4edge.dat
1 16 0 0 -12 0 0 2 2 0 0 0 2 0 4-4con6.dat
1 16 0 0 -10 0 0 2 2 0 0 0 2 0 4-4con5.dat
1 16 0 0 -8 0 0 10 10 0 0 0 4 0 4-4cylo.dat
1 16 0 0 -4 0 0 2 2 0 0 0 2 0 4-4con4.dat
1 16 0 0 -2 0 0 8 8 0 0 0 4 0 4-4cylo.dat
1 16 0 0 4 0 0 2 2 0 0 0 -2 0 4-4con4.dat
1 16 0 0 4 0 0 10 10 0 0 0 4 0 4-4cylo.dat
1 16 0 0 8 0 0 1 1 0 0 0 -1 0 4-4ring10.dat
1 16 0 0 8 0 0 11 11 0 0 0 1 0 4-4cylo.dat
1 16 0 0 9 0 0 1 1 0 0 0 -1 0 4-4ring11.dat
1 16 0 0 8 0 0 12 12 0 0 0 1 0 4-4cylo.dat
1 16 0 0 8 0 0 2 2 0 0 0 -1 0 4-4ring6.dat
0 // tread
1 16 0 0 -2 1 0 0 0 1 0 0 0 1 s\4084s01.dat
1 16 0 0 -2 0 -1 0 -1 0 0 0 0 1 s\4084s01.dat
1 16 0 0 -2 0 1 0 -1 0 0 0 0 -1 s\4084s01.dat
1 16 0 0 -2 -1 0 0 0 1 0 0 0 -1 s\4084s01.dat
1 16 0 0 -2 -1 0 0 0 -1 0 0 0 1 s\4084s01.dat
1 16 0 0 -2 0 1 0 1 0 0 0 0 1 s\4084s01.dat
1 16 0 0 -2 0 -1 0 1 0 0 0 0 -1 s\4084s01.dat
1 16 0 0 -2 1 0 0 0 -1 0 0 0 -1 s\4084s01.dat
Has Uncertified Subfiles
| User | Vote |
| MagFors | Hold |
This change will brake every model using this part.
This part is copyright ©
James Jessiman
Licensed under
CC BY 4.0
LDraw.org Parts Tracker,
J.C. Tchang, Magnus Forsberg, Rene Rechthaler
