Unofficial File parts/24201.dat
Slope Brick Curved  2 x  1 x  0.667 Inverted
0 Slope Brick Curved  2 x  1 x  0.667 Inverted
0 Name: 24201.dat
0 !CATEGORY Slope
0 !KEYWORDS Brickowl 716921
0 !HISTORY 2016-03-15 {LEGO Digital Designer} Original part shape
0 !HISTORY 2016-03-18 [Philo] File preparation for LDraw Parts Tracker
0 !HISTORY 2026-06-15 [Sirio] Changed description; subparted; changed shape of rounded face; move edges to 16 and 2
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\24201s01.dat
1 16 10 -24.9719 30 0 -20 0 26.9719 0 30.9717 -40 0 40 48\1-8cyli.dat
Massimo Maso [Sirio]
2026-06-16 17:40:00
Rene Rechthaler [Blechtaler]
posted a vote of Hold
2026-06-16 21:07:23
while it is back on the tracker, it should get subfiled without the "main" surface (because it is now printed)
https://rebrickable.com/parts/24201pr0002/slope-curved-2-x-1-inverted-with-goat-face-print/
Gerald Lasser [GeraldLasser]
made the following comment.
2026-06-17 13:09:38
Why was the curve changed?
Was there an issue that it did not fit to some other part.
2026-06-17 16:37:03
Subparted
2026-06-17 16:44:00
Gerald: I have modified the part to make it equal to 11477 and 15068.
As I wrote in the HISTORY the initial and final edges instead of being at Y 4 and 16, as we usually do in this parts, were at Y 3.95 and 15.95 and in any case different between curved face and vertical flat face.
This solution significantly reduces errors (less of 4 decimals).
Since there were no pattern versions yet and the stickers still had to be modified for the new size rules, it seemed like the right time to make the change.
edited the part header.
2026-06-17 19:45:11
Header Edits
description:
Slope Brick Curved 2 x 1 x 0. 667 Inverted
to
Comment:
Removed an extra space
2026-06-18 05:46:28
The curve is different, the original was also incorrect if it was shifted just. 05 LDU. The lip is smaller, around 1.5 LDU. I will link a picture of the real parts later
2026-06-18 06:44:52
Please keep in mind that lip is "incorrect" on all of our slopes. We have it at 4ldu but on a real part it is at 5. The question here is if the inverted slope is a true mirror of the regular part.
2026-06-18 14:14:54
Indeed, we have a gap of 1 LDU to the real world.
However the bottom and top curved ones here are not mirrored, the bottom one has a lip that is roughly 1.5 LDU shorter, see: http://heartlake.city/Pics/CurvedSLopes.jpeg
2026-06-20 06:13:01
Ok, sorry...
I will try to fix the curve so that the edge is at 1.5 LDU.
2026-06-20 10:08:21
This is the surface from the BI-.Mesh scaled together with the BI surface of 11477 in a way that 11477 ends up with a 4 LDU lip.
4 16 -10 -.91422513 9.38 -10 0 20 10 .04799961 20 10 -.86622552 9.462
4 16 -10 -3.63680766 -.988 -10 -.91422513 9.38 10 -.86622552 9.462 10 -3.58880805 -.988
4 16 -10 -8.10188766 -10.859 -10 -3.63680766 -.988 10 -3.58880805 -.988 10 -8.05388805 -10.777
4 16 10 -8.05388805 -10.777 10 -14.20453575 -20 -10 -14.20453575 -20 -10 -8.10188766 -10.859
I find this a bit small as the lip is then only 1.8 LDU
may me it should be around 2 to 2.2 LDU
2026-06-21 12:38:10
Moved front lip to Y = 2.
If you like this solution, I will update 24201b01, 32803b01 and so on.
