Unofficial File parts/3068bp72.dat
Tile  2 x  2 with Green Monitor Screen, Black Button and Window Pattern
0 Tile  2 x  2 with Green Monitor Screen, Black Button and Window Pattern
0 Name: 3068bp72.dat
0 !CATEGORY Tile
0 !KEYWORDS BrickLink 3068pb0062, Brickowl 918388, Brickset 47369
0 !KEYWORDS Rebrickable 3068bpr0137, Set 20205
0 !HISTORY 2026-06-19 [Cheenzo] Subfiled for new pattern, corrected some colours
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3068bs01.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3068bp72s01.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3068bp72s02.dat
1 72 0 0 0 1 0 0 0 1 0 0 0 1 s\3068bp72s03.dat
1 0 0 0 0 1 0 0 0 1 0 0 0 1 s\3068bp72s04.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3068bp72s05.dat
Vincent Messenet [Cheenzo]
2026-06-19 20:37:41
posted a vote of Hold
2026-06-22 19:44:28
If this is indeed meant to be BL 3068pb0062 (the second of 3 versions for the white variant of this print), then the colours are off.
Window in 16 should be 71 or 72 (I'd prefer 72, but not sure) and all the grey should be colour 16 (except for the power button, which is correct in grey).
I'm counting 3 of 5 variants thus far. Are going to do the missing 2 as well?
made the following comment.
2026-06-22 20:00:12
Actually I did this update just because I needed to create 3068bp7e as I worked on the set 910009 for OMR.
If you want to work on them all feel free to do it :-)
2026-06-22 20:20:54
I will consider it :D
2026-06-25 13:05:21
Just checked my real ones - unless there are even more variants of this, all the greys on this should be Dark Bluish Grey (which also means the name should change).
2026-07-02 19:35:35
Corrected colors according to photo from BL
