Unofficial File parts/3626bp0p.dat
Minifig Head with Skull on White Circle Pattern
0 Minifig Head with Skull on White Circle Pattern
0 Name: 3626bp0p.dat
0 !CATEGORY Minifig Head
0 !KEYWORDS Belville, Bricklink 3626pb0225, BrickOwl 88182, Brickset 51362
0 !KEYWORDS Fairy Tale, Hans Christian Andersen, Label, Mini Head No 390
0 !KEYWORDS Poison Bottle, Rebrickable 3626bpr0195, Set 5962, The Tinderbox
0 !KEYWORDS Witch
0 !CMDLINE -c34
0 // Base Part
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3626bs02.dat
1 16 0 17 0 0 0 -13 0 -13 0 13 0 0 3-8cyli.dat
1 16 0 17 0 0 0 13 0 -13 0 13 0 0 3-8cyli.dat
0 // Top Area
1 16 0 4 0 -8 0 0 0 -6.4 0 0 0 8 t04o6250.dat
1 16 0 4 0 0 0 8 0 -6.4 0 8 0 0 t04o6250.dat
1 16 0 4 0 8 0 0 0 -6.4 0 0 0 -8 t08o6250.dat
1 16 0 4 0 -8 0 0 0 -6.4 0 0 0 -8 t08o6250.dat
0 // Bottom Area
1 16 0 17 0 8 0 0 0 6.4 0 0 0 8 t04o6250.dat
1 16 0 17 0 0 0 -8 0 6.4 0 8 0 0 t04o6250.dat
1 16 0 17 0 8 0 0 0 6.4 0 0 0 -8 t08o6250.dat
1 16 0 17 0 -8 0 0 0 6.4 0 0 0 -8 t08o6250.dat
0 // Pattern
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3626bp0ps01.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\3626bp0ps01.dat
2026-07-01 22:20:49
2026-07-01 22:22:11
made the following comment.
2026-07-01 22:23:15
*is the slight distortion on the white circle too noticable?
*this is technically based on the original (Royal Knights) Minifig Skeleton Skull made from 1995-ca. 2010 and differs from the modern one
*unfortunately the entire skull print was raised noticably to make the white "label" more centered on the part; this blocks both re-usability and may cause issues with masks and other headgear when used a "real" head
*only used in 1 Belville set in 1995 and only in Transparent Green
