Unofficial File parts/s/35189s01.dat
0 ~Technic Steering Wheel Hub with Brake Disc and 3 Pegholes 1/6
0 Name: s\35189s01.dat
0 !HISTORY 2026-07-21 [jb70] subfiled to 35189s02.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\35189s02.dat
1 16 0 -40.5 -3 0 0 2.5 -2.5 0 0 0 -1 0 2-4disc.dat
1 16 0 -40.5 -2 0 0 0.83333 -0.83333 0 0 0 -1 0 2-4con3.dat
1 16 0 -40.5 -2 0 0 3.33333 -3.33333 0 0 0 -1 0 2-4ndis.dat
1 16 35.074 -20.25 -3 2.16506 0 -1.25 -1.25 0 -2.16506 0 -1 0 2-4disc.dat
1 16 35.074 -20.25 -2 0.72169 0 -0.41667 -0.41667 0 -0.72169 0 -1 0 2-4con3.dat
1 16 35.074 -20.25 -2 2.88675 0 -1.66667 -1.66667 0 -2.88675 0 -1 0 2-4ndis.dat
1 16 17.5 -30.3109 -3 1.25 0 2.16506 -2.16506 0 1.25 0 -1 0 4-4disc.dat
1 16 17.5 -30.3109 -2 0.41667 0 0.72169 -0.72169 0 0.41667 0 -1 0 4-4con3.dat
1 16 17.5 -30.3109 -2 1.66667 0 2.88675 -2.88675 0 1.66667 0 -1 0 4-4ndis.dat
1 16 23 -39.8372 -3 1.25 0 2.16506 -2.16506 0 1.25 0 -1 0 4-4disc.dat
1 16 23 -39.8372 -2 0.41667 0 0.72169 -0.72169 0 0.41667 0 -1 0 4-4con3.dat
1 16 23 -39.8372 -2 1.66667 0 2.88675 -2.88675 0 1.66667 0 -1 0 4-4ndis.dat
1 16 0 -40.5 -3 0 0 2.5 -2.5 0 0 0 -1 0 2-4edge.dat
1 16 0 -40.5 -2 0 0 3.33333 -3.33333 0 0 0 -1 0 2-4edge.dat
1 16 35.074 -20.25 -3 2.16506 0 -1.25 -1.25 0 -2.16506 0 -1 0 2-4edge.dat
1 16 35.074 -20.25 -2 2.88675 0 -1.66667 -1.66667 0 -2.88675 0 -1 0 2-4edge.dat
1 16 17.5 -30.3109 -3 1.25 0 2.16506 -2.16506 0 1.25 0 -1 0 4-4edge.dat
1 16 17.5 -30.3109 -2 1.66667 0 2.88675 -2.88675 0 1.66667 0 -1 0 4-4edge.dat
1 16 23 -39.8372 -3 1.25 0 2.16506 -2.16506 0 1.25 0 -1 0 4-4edge.dat
1 16 23 -39.8372 -2 1.66667 0 2.88675 -2.88675 0 1.66667 0 -1 0 4-4edge.dat
3 16 21.7799 -44.3906 -2 26.5 -45.8993 -2 27.5534 -41.0573 -2
3 16 27.5534 -41.0573 -2 26.5 -45.8993 -2 45.898 -26.5 -2
4 16 37.9608 -21.9167 -2 36.2941 -24.8034 -2 27.5534 -41.0573 -2 45.898 -26.5 -2
3 16 26.5 -45.8993 -2 21.7799 -44.3906 -2 0 -53 -2
4 16 3.3333 -43.8333 -2 0 -43.8333 -2 0 -53 -2 21.7799 -44.3906 -2
4 16 3.3333 -43.8333 -2 21.7799 -44.3906 -2 18.4466 -38.6171 -2 3.3333 -37.1667 -2
4 16 24.2201 -35.2838 -2 27.5534 -41.0573 -2 36.2941 -24.8034 -2 30.5206 -21.4701 -2
4 16 18.4466 -38.6171 -2 24.2201 -35.2838 -2 22.0534 -31.531 -2 16.2799 -34.8643 -2
3 16 24.2201 -35.2838 -2 30.5206 -21.4701 -2 22.0534 -31.531 -2
3 16 18.4466 -38.6171 -2 16.2799 -34.8643 -2 3.3333 -37.1667 -2
4 16 0 -37.1667 -2 3.3333 -37.1667 -2 16.2799 -34.8643 -2 12.9466 -29.0908 -2
4 16 18.7201 -25.7575 -2 22.0534 -31.531 -2 30.5206 -21.4701 -2 32.1873 -18.5833 -2
4 16 6 -26 -2 0 -26 -2 0 -37.1667 -2 12.9466 -29.0908 -2
4 16 6 -14 -2 6 -26 -2 12.9466 -29.0908 -2 18.7201 -25.7575 -2
3 16 18.7201 -25.7575 -2 32.1873 -18.5833 -2 6 -14 -2
1 16 20.25 -35.074 -5 1.25 0 2.16506 -2.16506 0 1.25 0 1 0 4-4disc.dat
1 16 20.25 -35.074 -6 0.41667 0 0.72169 -0.72169 0 0.41667 0 1 0 4-4con3.dat
1 16 20.25 -35.074 -6 1.66667 0 2.88675 -2.88675 0 1.66667 0 1 0 4-4ndis.dat
1 16 20.25 -35.074 -5 1.25 0 2.16506 -2.16506 0 1.25 0 1 0 4-4edge.dat
1 16 20.25 -35.074 -6 1.66667 0 2.88675 -2.88675 0 1.66667 0 1 0 4-4edge.dat
1 16 0 0 -6 0 0 53 -53 0 0 0 1 0 48\1-6chrd.dat
4 16 0 -53 -6 19.0299 -39.6274 -6 24.8034 -36.2941 -6 45.898 -26.5 -6
4 16 31.531 -22.0534 -6 35.2838 -24.2201 -6 24.8034 -36.2941 -6 21.4701 -30.5206 -6
4 16 3.3333 -42.6667 -6 3.3333 -38.3333 -6 15.6966 -33.8539 -6 19.0299 -39.6274 -6
4 16 21.4701 -30.5206 -6 15.6966 -33.8539 -6 3.3333 -38.3333 -6 31.531 -22.0534 -6
4 16 25.7575 -18.7201 -6 31.531 -22.0534 -6 3.3333 -38.3333 -6 3.3333 -31.6667 -6
3 16 0 -53 -6 3.3333 -49.3333 -6 19.0299 -39.6274 -6
3 16 19.0299 -39.6274 -6 3.3333 -49.3333 -6 3.3333 -42.6667 -6
3 16 24.8034 -36.2941 -6 35.2838 -24.2201 -6 41.0573 -27.5534 -6
3 16 24.8034 -36.2941 -6 41.0573 -27.5534 -6 45.898 -26.5 -6
1 16 0 -35 -5 0 0 2.5 -2.5 0 0 0 1 0 2-4disc.dat
1 16 0 -35 -5 0 0 2.5 -2.5 0 0 0 1 0 2-4edge.dat
1 16 0 -35 -6 0 0 .83333 -.83333 0 0 0 1 0 2-4con3.dat
1 16 0 -35 -6 0 0 3.33333 -3.33333 0 0 0 1 0 2-4ndis.dat
1 16 0 -46 -5 0 0 2.5 -2.5 0 0 0 1 0 2-4disc.dat
1 16 0 -46 -6 0 0 .83333 -.83333 0 0 0 1 0 2-4con3.dat
1 16 0 -46 -6 0 0 3.33333 -3.33333 0 0 0 1 0 2-4ndis.dat
1 16 30.3109 -17.5 -5 2.16506 0 -1.25 -1.25 0 -2.16506 0 1 0 2-4disc.dat
1 16 30.3109 -17.5 -6 .72169 0 -.41667 -.41667 0 -.72169 0 1 0 2-4con3.dat
1 16 30.3109 -17.5 -6 2.88675 0 -1.66667 -1.66667 0 -2.88675 0 1 0 2-4edge.dat
1 16 30.3109 -17.5 -6 2.88675 0 -1.66667 -1.66667 0 -2.88675 0 1 0 2-4ndis.dat
1 16 39.8372 -23 -5 2.16506 0 -1.25 -1.25 0 -2.16506 0 1 0 2-4disc.dat
1 16 39.8372 -23 -6 .72169 0 -.41667 -.41667 0 -.72169 0 1 0 2-4con3.dat
1 16 39.8372 -23 -6 2.88675 0 -1.66667 -1.66667 0 -2.88675 0 1 0 2-4ndis.dat
1 16 0 -35 -6 0 0 3.33333 -3.33333 0 0 0 1 0 2-4edge.dat
1 16 0 -46 -5 0 0 2.5 -2.5 0 0 0 1 0 2-4edge.dat
1 16 0 -46 -6 0 0 3.33333 -3.33333 0 0 0 1 0 2-4edge.dat
1 16 30.3109 -17.5 -5 2.16506 0 -1.25 -1.25 0 -2.16506 0 1 0 2-4edge.dat
1 16 39.8372 -23 -5 2.16506 0 -1.25 -1.25 0 -2.16506 0 1 0 2-4edge.dat
1 16 39.8372 -23 -6 2.88675 0 -1.66667 -1.66667 0 -2.88675 0 1 0 2-4edge.dat
3 16 0 -53 -6 0 -49.3333 -6 3.3333 -49.3333 -6
3 16 41.0573 -27.5534 -6 42.7239 -24.6667 -6 45.898 -26.5 -6
4 16 33.1976 -19.1667 -6 36.9504 -21.3333 -6 35.2838 -24.2201 -6 31.531 -22.0534 -6
4 16 3.3333 -38.3333 -6 3.3333 -42.6667 -6 0 -42.6667 -6 0 -38.3333 -6
3 16 0 -31.6667 -6 0 -30 -6 3.3333 -31.6667 -6
3 16 27.4241 -15.8333 -6 25.7575 -18.7201 -6 25.98 -15 -6
4 16 25.7575 -18.7201 -6 3.3333 -31.6667 -6 0 -30 -6 25.98 -15 -6
Needs 2 More Votes (F)
Has Uncertified Subfiles
Jens Brühl [jb70]
2026-07-22 01:03:22
Subfiled to be reused with new parts
Jens Brühl [jb70]
2026-07-29 19:55:26
The small punch holes on the surface of the brake disc are smaller for part 7168. So I removed them from the common subfile.
