0 Click Lock Hinge Half Dual Finger - 4.5LDU
0 Name: clh4.dat
0 Author: Donald Sutter [technog]
0 !LDRAW_ORG Unofficial_Primitive
0 !HELP Requires 2 halves rotated 180 degrees apart on Z-axis.
0 !HELP Placement on side of bricks; rotate pair accordingly,
0 !HELP place 10 Ldu below top surface and 6 Ldu off side surface,
0 !HELP fill as needed - box4o4a.dat's recommended.
0 !HELP Placement off side of plates and windscreens; rotate pair accordingly,
0 !HELP place center origin 2 Ldu below top surface and 6 Ldu off side surface,
0 !HELP fill as needed.
0 !HISTORY 2003-08-01 [PTadmin] Official Update 2003-02
0 !HISTORY 2003-12-29 [technog] Corrected width
0 !HISTORY 2004-03-02 [PTadmin] Official Update 2004-01
0 !HISTORY 2007-06-24 [PTadmin] Header formatted for Contributor Agreement
0 !HISTORY 2012-02-16 [Philo] Changed to CCW
0 !HISTORY 2026-07-12 [MagFors] adapted to lo-res, used finger primitive
1 16 4 0 4 0 -1 0 4 0 0 0 0 4 4-4edge.dat
1 16 4 0 4 0 -1 0 1 0 0 0 0 1 4-4con3.dat
1 16 3 0 4 0 -1 0 3 0 0 0 0 3 4-4edge.dat
1 16 3 0 4 0 1 0 3 0 0 0 0 3 4-4disc.dat
1 16 6.25 0 0 1.125 0 0 0 1 0 0 0 1 clh-base.dat
1 16 8.5 0 4 4.5 0 0 0 1 0 0 0 1 clh-finger.dat
1 16 8.5 0 4 4.5 0 0 0 .9239 .3827 0 -.3827 .9239 clh-finger.dat
1 16 8.5 0 4 4.5 0 0 0 .7071 .7071 0 -.7071 .7071 clh-finger.dat
1 16 8.5 0 4 4.5 0 0 0 .3827 .9239 0 -.9239 .3827 clh-finger.dat
1 16 8.5 0 4 4.5 0 0 0 0 1 0 -1 0 clh-finger.dat
1 16 8.5 0 4 4.5 0 0 0 -.3827 .9239 0 -.9239 -.3827 clh-finger.dat
1 16 8.5 0 4 4.5 0 0 0 -.7071 .7071 0 -.7071 -.7071 clh-finger.dat
1 16 8.5 0 4 4.5 0 0 0 -.9239 .3827 0 -.3827 -.9239 clh-finger.dat
1 16 8.5 0 4 4.5 0 0 0 -1 0 0 0 -1 clh-finger.dat
Has Uncertified Subfiles
None
This part is copyright ©
Donald Sutter
Licensed under
CC BY 4.0
LDraw.org Parts Tracker,
Philippe Hurbain, Magnus Forsberg
