0 Click Lock Hinge Half Dual Finger 7-Position
0 Name: clh10.dat
0 !LDRAW_ORG Unofficial_Primitive
0 !HELP Requires 2 halves rotated 180 degrees apart on Z-axis.
0 !HELP Placement on side of bricks; rotate pair accordingly,
0 !HELP place 10 Ldu below top surface and 6 Ldu off side surface,
0 !HELP fill as needed - box4o4a.dat's recommended.
0 !HELP Placement off side of plates and windscreens; rotate pair accordingly,
0 !HELP place center origin 2 Ldu below top surface and 6 Ldu off side surface,
0 !HELP fill as needed.
0 !HISTORY 2008-07-03 [Philo] Rewrite from clh11 for homogeneity with other clh primitives
0 !HISTORY 2012-02-16 [Philo] Changed to CCW
0 !HISTORY 2022-10-15 [MagFors] adapted to lo-res, used new finger primitive
1 16 4 0 4 0 -1 0 4 0 0 0 0 4 4-4edge.dat
1 16 4 0 4 0 -1 0 1 0 0 0 0 1 4-4con3.dat
1 16 3 0 4 0 -1 0 3 0 0 0 0 3 4-4edge.dat
1 16 3 0 4 0 1 0 3 0 0 0 0 3 4-4disc.dat
1 16 6.25 0 0 1.125 0 0 0 1 0 0 0 1 clh-base.dat
1 16 8.5 0 4 4.5 0 0 0 1 0 0 0 1 clh-finger.dat
1 16 8.5 0 4 4.5 0 0 0 .9239 .3827 0 -.3827 .9239 clh-finger.dat
1 16 8.5 0 4 4.5 0 0 0 .7071 .7071 0 -.7071 .7071 clh-finger.dat
1 16 8.5 0 4 4.5 0 0 0 0 1 0 -1 0 clh-finger.dat
1 16 8.5 0 4 4.5 0 0 0 -.7071 .7071 0 -.7071 -.7071 clh-finger.dat
1 16 8.5 0 4 4.5 0 0 0 -.9239 .3827 0 -.3827 -.9239 clh-finger.dat
1 16 8.5 0 4 4.5 0 0 0 -1 0 0 0 -1 clh-finger.dat
2 24 8.5 1.0046 9.0503 8.5 2.0092 8.8505
2 24 4 2.0092 8.8505 4 1.0046 9.0503
4 16 8.5 2.0092 8.8505 4 2.0092 8.8505 4 1.0046 9.0503 8.5 1.0046 9.0503
5 24 8.5 2.0092 8.8505 4 2.0092 8.8505 8.5 1.0046 9.0503 8.5 2.8608 8.2815
2 24 8.5 2.0092 8.8505 8.5 2.8608 8.2815
2 24 4 2.8608 8.2815 4 2.0092 8.8505
4 16 8.5 2.8608 8.2815 4 2.8608 8.2815 4 2.0092 8.8505 8.5 2.0092 8.8505
3 16 4 2.0092 8.8505 4 2.8608 8.2815 4 1.0046 9.0503
3 16 8.5 2.8608 8.2815 8.5 2.0092 8.8505 8.5 1.0046 9.0503
2 24 4 -2.0092 8.8505 4 -2.8608 8.2815
2 24 8.5 -2.8608 8.2815 8.5 -2.0092 8.8505
4 16 4 -2.8608 8.2815 8.5 -2.8608 8.2815 8.5 -2.0092 8.8505 4 -2.0092 8.8505
5 24 8.5 -2.0092 8.8505 4 -2.0092 8.8505 8.5 -2.8608 8.2815 8.5 -1.0046 9.0503
2 24 4 -1.0046 9.0503 4 -2.0092 8.8505
2 24 8.5 -2.0092 8.8505 8.5 -1.0046 9.0503
4 16 4 -2.0092 8.8505 8.5 -2.0092 8.8505 8.5 -1.0046 9.0503 4 -1.0046 9.0503
3 16 4 -2.0092 8.8505 4 -1.0046 9.0503 4 -2.8608 8.2815
3 16 8.5 -1.0046 9.0503 8.5 -2.0092 8.8505 8.5 -2.8608 8.2815
Has Uncertified Subfiles
None
This part is copyright ©
Michael Heidemann
Licensed under
CC BY 4.0
LDraw.org Parts Tracker,
Philippe Hurbain, Magnus Forsberg
