Unofficial File parts/s/stickerback015x035.dat
0 ~Sticker Back 1.5 x 3.5
0 Name: s\stickerback015x035.dat
0 // Bottom
1 16 33.5 0 -13.5 0 0 1.5 0 -1 0 -1.5 0 0 1-4chrd.dat
1 16 -33.5 0 13.5 0 0 -1.5 0 -1 0 1.5 0 0 1-4chrd.dat
1 16 -33.5 0 -13.5 0 0 -1.5 0 -1 0 -1.5 0 0 1-4chrd.dat
1 16 33.5 0 13.5 0 0 1.5 0 -1 0 1.5 0 0 1-4chrd.dat
4 16 35 0 -13.5 33.5 0 -15 33.5 0 15 35 0 13.5
4 16 33.5 0 15 33.5 0 -15 -33.5 0 -15 -33.5 0 15
4 16 -35 0 13.5 -33.5 0 15 -33.5 0 -15 -35 0 -13.5
0 // Circumference
1 16 33.5 0 -13.5 0 0 1.5 0 -.25 0 -1.5 0 0 1-4cyli.dat
1 16 -33.5 0 13.5 0 0 -1.5 0 -.25 0 1.5 0 0 1-4cyli.dat
1 16 -33.5 0 -13.5 0 0 -1.5 0 -.25 0 -1.5 0 0 1-4cyli.dat
1 16 33.5 0 13.5 0 0 1.5 0 -.25 0 1.5 0 0 1-4cyli.dat
4 16 33.5 -.25 -15 -33.5 -.25 -15 -33.5 0 -15 33.5 0 -15
4 16 35 0 13.5 35 -.25 13.5 35 -.25 -13.5 35 0 -13.5
4 16 -33.5 0 15 -33.5 -.25 15 33.5 -.25 15 33.5 0 15
4 16 -35 -.25 13.5 -35 0 13.5 -35 0 -13.5 -35 -.25 -13.5
Needs 2 More Votes (N)
2026-10-10 23:45:55
*there seems to be a bit of an offset between print and cut in some real ones. I tried making an ideally centered one, so this might differ a bit from the BL image
*if you look close, there are rounded corners on this, although a bit early for that in 1998/1999
*the length of the line interrupts seems to intentionally differ depending on direction
