Unofficial File parts/s/44126s00.dat
0 ~Slope Brick Curved 6 x 2 without Top Surface
0 Name: s\44126s00.dat
0 !HISTORY 2026-10-24 [KnightOfTarenta] Sub-filed from 44126.dat by Guy Vivan [guyvivan]
0 // Main Halves
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\44126s01.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\44126s01.dat
0 // Top Studs
1 16 0 0 0 0 0 1 0 1 0 -1 0 0 stug-2x2.dat
0 // Outer Surface
1 16 0 12 0 20 0 0 0 -12 0 0 0 20 box2-7.dat
1 16 0 22 -100 20 0 0 0 0 -2 0 1 0 rect.dat
0 // Flat Bottom
4 16 20 24 20 16 24 16 -16 24 16 -20 24 20
4 16 -20 24 -100 -16 24 -96 16 24 -96 20 24 -100
2 24 -20 24 20 20 24 20
4 16 16 4 -28 7.8012 9.8125 -59 -7.8012 9.8125 -59 -16 4 -28
4 16 -7.8012 10.3262 -61 -6 10 -60 6 10 -60 7.8012 10.3262 -61
4 16 7.8012 9.8125 -59 6 10 -60 -6 10 -60 -7.8012 9.8125 -59
4 16 16 20 -90.66 -16 20 -90.66 -7.8012 10.3262 -61 7.8012 10.3262 -61
5 24 -6 10 -60 6 10 -60 -7.8012 10.3262 -61 -7.8012 9.8125 -59
0 // Inner Structure
0 // Bottom Main
1 16 0 14 16 0 0 -16 -10 0 0 0 1 0 rect.dat
4 16 4.14 22 -96 16 24 -96 -16 24 -96 -4.14 22 -96
4 16 -7.8012 4 -21 -7.8012 4 -19 7.8012 4 -19 7.8012 4 -21
4 16 4.14 22 -96 -4.14 22 -96 -4.14 20 -90.66 4.14 20 -90.66
4 16 7.8012 4 -19 -7.8012 4 -19 -16 4 16 16 4 16
4 16 7.8012 4 -21 16 4 -28 -16 4 -28 -7.8012 4 -21
5 24 16 4 -28 -16 4 -28 -7.8012 9.8125 -59 -7.8012 4 -21
2 24 16 24 -96 -16 24 -96
2 24 -4.14 22 -96 4.14 22 -96
5 24 -4.14 20 -90.66 4.14 20 -90.66 4.14 22 -96 -7.8011 10.0375 -61
5 24 -7.8012 9.8125 -59 7.8012 9.8125 -59 8 10 -61 -16 4 -28
0 // Bottom Tubes
0 // Tube 1
1 16 0 4 0 1 0 0 0 -5 0 0 0 1 stud4.dat
0 // Tube 2
1 16 0 4 -20 1 0 0 0 -5 0 0 0 1 stud4.dat
0 // Tube 3
1 16 0 7.75 -40 1 0 0 0 -4.0625 0 0 0 1 stud4a.dat
1 16 0 6.25 -40 8 0 0 0 -1 -1.5 0 0 8 4-4edge.dat
1 16 0 7.75 -40 0 0 -8 0 -1.5 0 -8 0 0 4-4cyls.dat
1 16 0 6.25 -40 6 0 0 0 -1 -1.125 0 0 6 4-4edge.dat
1 16 0 7.375 -40 0 0 -6 0 -1.125 0 -6 0 0 4-4cyls.dat
1 16 0 7.75 -40 0 0 -6 0 -.375 0 -6 0 0 4-4cyli.dat
0 // Tube 4
1 16 0 12.6093 -60 1 0 0 0 -2.84767 0 0 0 1 stud4a.dat
1 16 0 10 -60 8 0 0 0 -1 -1.5 0 0 8 2-4edge.dat
1 16 0 10 -60 6 0 0 0 -1 -1.125 0 0 6 2-4edge.dat
1 16 0 10 -60 8 0 0 0 2.6093 0 0 0 8 2-4cyli.dat
1 16 0 10 -60 6 0 0 0 2.6093 0 0 0 6 2-4cyli.dat
1 16 0 10 -60 8 0 0 0 -1 2.6093 0 0 -8 2-4edge.dat
1 16 0 10 -60 6 0 0 0 -1 1.957 0 0 -6 2-4edge.dat
1 16 0 11.957 -60 6 0 0 0 .6523 0 0 0 -6 2-4cyli.dat
0 // Tube 5
1 16 0 19.1325 -80 1 0 0 0 -1.21687 0 0 0 1 stud4a.dat
1 16 0 16.5232 -80 8 0 0 0 -1 -2.6093 0 0 8 4-4edge.dat
1 16 0 19.1325 -80 0 0 -8 0 -2.6093 0 -8 0 0 4-4cyls.dat
1 16 0 16.5232 -80 6 0 0 0 -1 -1.957 0 0 6 4-4edge.dat
1 16 0 18.4802 -80 0 0 -6 0 -1.957 0 -6 0 0 4-4cyls.dat
1 16 0 19.1325 -80 0 0 -6 0 -0.6523 0 -6 0 0 4-4cyli.dat
Awaiting Admin Review (CCN)
Willy Tschager [Holly-Wood]
Has Uncertified Subfiles
2026-10-25 20:20:49
posted a vote of Hold
2026-10-25 21:05:46
The second stud tube from front doesn't work. Unmatched surfaces and missing edge lines.
Remove this:
4 16 8 10 -59 8 10 -61 -7.8011 10.0375 -61 -7.8011 10.0144 -59
and simplify the design
Remove this:
made the following comment.
2026-10-25 21:24:44
Would it be okay to ignore the outside sloped areas (creating the edge there) and just fill in with a single angled disc?
2026-10-25 21:34:37
I see no reason for a complex inner surface. I would use two quads. Like this:
4 13 16 10 -60 -16 10 -60 -16 4 -28 16 4 -28
4 13 -16 20 -90.66 -16 10 -60 16 10 -60 16 20 -90.66
2026-10-27 21:47:45
Reworked as suggested.
2026-10-27 22:50:15
Changed 2 edges to conds.
2026-11-01 21:14:17
*Implemented suggested changes
posted a vote of Certify
2026-11-02 09:45:06
2026-11-02 18:35:42
*mirrored
