Unofficial File parts/s/41766s01.dat
0 ~Slope Brick Curved 8 x 2 x 2 - Half
0 Name: s\41766s01.dat
0 // Outer Side
1 16 20 64 40 0 -1 0 -88 0 0 0 0 -138.5681 48\1-6chrd.dat
1 16 20 64 40 0 -1 0 -88 0 0 0 0 -138.5681 48\1-6edge.dat
4 16 20 24 -80 20 24 80 20 0 80 20 0 40
4 16 20 24 -80 20 0 40 20 -24 40 20 20 -80
0 // Flat Bottom
3 16 16 24 36 9 24 40 11 24 40
3 16 16 24 36 11 24 40 16 24 40
3 16 16 24 76 20 24 80 16 24 40
3 16 16 24 40 20 24 80 16 24 36
4 16 16 24 36 20 24 80 20 24 -80 16 24 -76
2 24 16 24 -76 16 24 36
2 24 20 24 -80 20 24 80
0 // Back Cavity
1 16 13.5 14 40 2.5 0 0 0 0 10 0 -1 0 rect2p.dat
1 16 10 14 40 1 0 0 0 0 10 0 4 0 box4-2p.dat
3 16 16 4 76 11 4 44 9 4 44
4 16 11 4 40 11 4 44 16 4 76 16 4 40
0 // Front Cavity
4 16 16 0 -40 16 24 36 16 24 -76 16 12 -60
4 16 16 -19.6 36 16 24 36 16 -14 0 16 -18 20
4 16 16 0 -40 16 -8 -20 16 -14 0 16 24 36
2 24 16 -18 20 16 -19.6 36
2 24 16 -18 20 16 -14 0
2 24 16 -8 -20 16 0 -40
2 24 16 -14 0 16 -8 -20
2 24 16 0 -40 16 12 -60
2 24 16 12 -60 16 20 -70.6667
2 24 16 24 -76 16 12 -60
0 // Thin Filler Area Front
3 16 15.8674 20 -70.6667 16 12 -60 16 20 -70.6667
4 16 16 20 -70.6667 16 24 -76 15.8674 24 -76 15.8674 20 -70.6667
2 24 16 24 -76 15.8674 24 -76
0 // Front Stud Hole
3 16 15.5434 21.2222 -72.2962 15.5434 20 -72.2962 15.8674 20 -70.6667
3 16 4.4566 20 -72.2962 4.4566 21.2222 -72.2962 4.1326 20 -70.6667
3 16 15.8674 20 -70.6667 15.5434 20 -72.2962 4.1326 20 -70.6667
3 16 15.8674 24 -76 10 24 -76 12.2962 23.6576 -75.5434
3 16 15.8674 24 -76 15.5434 21.2222 -72.2962 15.8674 20 -70.6667
3 16 15.8674 24 -76 14.2426 22.682 -74.2426 15.5434 21.2222 -72.2962
3 16 15.8674 24 -76 12.2962 23.6576 -75.5434 14.2426 22.682 -74.2426
4 16 14.2426 22.682 -74.2426 14.2426 20 -74.2426 15.5434 20 -72.2962 15.5434 21.2222 -72.2962
4 16 12.2962 23.6576 -75.5434 12.2962 20 -75.5434 14.2426 20 -74.2426 14.2426 22.682 -74.2426
4 16 10 24 -76 10 20 -76 12.2962 20 -75.5434 12.2962 23.6576 -75.5434
4 16 7.7038 23.6576 -75.5434 7.7038 20 -75.5434 10 20 -76 10 24 -76
4 16 5.7574 22.682 -74.2426 5.7574 20 -74.2426 7.7038 20 -75.5434 7.7038 23.6576 -75.5434
4 16 4.4566 21.2222 -72.2962 4.4566 20 -72.2962 5.7574 20 -74.2426 5.7574 22.682 -74.2426
4 16 4.4566 20 -72.2962 14.2426 20 -74.2426 7.7038 20 -75.5434 5.7574 20 -74.2426
4 16 14.2426 20 -74.2426 12.2962 20 -75.5434 10 20 -76 7.7038 20 -75.5434
4 16 4.1326 20 -70.6667 15.5434 20 -72.2962 14.2426 20 -74.2426 4.4566 20 -72.2962
2 24 4.1326 20 -70.6667 15.8674 20 -70.6667
2 24 4.1326 20 -70.6667 4.4566 20 -72.2962
2 24 10 20 -76 12.2962 20 -75.5434
2 24 5.7574 20 -74.2426 7.7038 20 -75.5434
2 24 15.5434 20 -72.2962 14.2426 20 -74.2426
2 24 15.8674 20 -70.6667 15.5434 21.2222 -72.2962
2 24 15.5434 20 -72.2962 15.8674 20 -70.6667
2 24 12.2962 23.6576 -75.5434 14.2426 22.682 -74.2426
2 24 5.7574 20 -74.2426 4.4566 20 -72.2962
2 24 14.2426 22.682 -74.2426 15.5434 21.2222 -72.2962
2 24 10 24 -76 12.2962 23.6576 -75.5434
2 24 12.2962 20 -75.5434 14.2426 20 -74.2426
2 24 7.7038 20 -75.5434 10 20 -76
2 24 4.4566 21.2222 -72.2962 4.1326 20 -70.6667
2 24 5.7574 22.682 -74.2426 4.4566 21.2222 -72.2962
2 24 10 24 -76 7.7038 23.6576 -75.5434
2 24 7.7038 23.6576 -75.5434 5.7574 22.682 -74.2426
2 24 15.8674 24 -76 10 24 -76
5 24 4.4566 20 -72.2962 4.4566 21.2222 -72.2962 4.1326 20 -70.6667 5.7574 22.682 -74.2426
5 24 10 24 -76 10 20 -76 7.7038 20 -75.5434 12.2962 23.6576 -75.5434
5 24 15.5434 21.2222 -72.2962 15.5434 20 -72.2962 15.8674 20 -70.6667 14.2426 20 -74.2426
5 24 14.2426 20 -74.2426 14.2426 22.682 -74.2426 15.5434 21.2222 -72.2962 12.2962 20 -75.5434
5 24 5.7574 22.682 -74.2426 5.7574 20 -74.2426 4.4566 20 -72.2962 7.7038 23.6576 -75.5434
5 24 12.2962 20 -75.5434 12.2962 23.6576 -75.5434 14.2426 22.682 -74.2426 10 20 -76
5 24 7.7038 20 -75.5434 7.7038 23.6576 -75.5434 10 24 -76 5.7574 20 -74.2426
Certified (ACCN)
Orion Pobursky [OrionP]
Willy Tschager [Holly-Wood]
2026-11-12 19:27:25
posted a vote of Certify
2026-11-13 07:39:23
2026-11-13 11:28:48
made the following comment.
2026-11-15 11:56:07
* T-junk:
2 320 16 20 -70.6667 16 24 -76
posted a vote of Admin Review
2026-11-19 04:43:58
*missing edge should be fixed by the sub-file
*not sure what's happening with the stud logos - locally in LDView it looks like on your image, last time it was mirrored on PT...
*I could not find any overlap in the area you showed - are you sure it's not something else? There is a bit of T-junc caused by these 2 polygons, that's hard to avoid. Maybe that caused a warning? Is there a way this area should be improved?
