Unofficial File parts/74948p01.dat
Minifig Compass with Fleur de Lis Pattern
0 Minifig Compass with Fleur de Lis Pattern
0 Name: 74948p01.dat
0 !CATEGORY Minifig Accessory
0 !KEYWORDS 24-point, Armada, BrickLink 70001c01pb02, Brickowl 129133
0 !KEYWORDS Brickset 74948, Pirates, Rebrickable 70001pr0002, Set 3143, windrose
1 494 0 0 0 1 0 0 0 1 0 0 0 1 70926.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 6094.dat
1 15 0 0 0 1 0 0 0 1 0 0 0 1 u9349p01.dat
0 BFC NOCLIP
1 47 0 0 0 1 0 0 0 1 0 0 0 1 6095.dat
Not releaseable Errors Found (HF) Errors Found (HF)
Hold
Orion Pobursky [OrionP]
Peter Grass [Evilspyre]
Part Author
2026-11-27 18:22:46
Needed a Noclip adding so that it works properly in Studio (works OK in the part designer without it since I guess that doesn't respect BFC properly)
made the following comment.
2026-11-27 19:32:53
What, exactly is the issue? Since it renders correctly with LDview and the WebGL viewer, I'm not sure that we need to cater to a program specific bug (although there is precedence with MLCad and the fast draw studs)
Part Author
2026-11-27 19:40:19
In studio the official ldraw part looks like this:
https://i.postimg.cc/nhpqTtZs/Screenshot-2026-11-27-193807.png
With the Noclip added it looks like this:
https://i.postimg.cc/5N3X4Qdf/Screenshot-2026-11-27-193934.png
2026-11-27 19:58:38
The NOCLIP should probably be on u9349p01.dat
Part Author
2026-11-27 20:09:36
It doesn't seem to work if I add it to u9349p01.dat, it goes back to being invisible in studio.
2026-11-27 20:41:33
The onyl transparent part here is the top cover. So NOCLIP seems strange?
2026-11-27 20:45:38
Is it even allowed on shortcut? Feels even stranger.
On a sidenote, the center piece being Brown seems a bit off too.
And there's a second print btw.
2026-11-27 22:02:08
Has this reported this on the Studio forums? Again, I'm reluctant to issue this update since the de-facto reference renderer (LDView) renders this fine and so does the WebGL renderer.
2026-11-27 22:13:34
Just to be clear, I'm not opposed to fixing the issue, especially since Studio has widespread use, but I want to make sure the Studio team is aware of the issue. If they decline to fix, then this fix is fine.
2026-11-27 23:14:35
That issue has been there since at least 2022.
Fully agree that this is something Studio should fix.
Sylvain Sauvage [SLS]
Part Author
2026-11-27 23:16:52
I don’t have anything in my Studio forum bugs archive about that part, or about the need for NOCLIP.
We had some threads about weird things happening with (LDraw) patterns, like their not showing, when behind some transparent part (or bit of part), but we generally went with “Studio is cutting som corners.”  But, at the same time, some of these things are not happening anymore, especially since the changes made in Studio during the last year or two (changes that didn’t all make it into PartDesigner, notably because in PD, you work on a few parts and many changes were about performance).
One part I think I remember having problems is 44375bpb07 (Big Ben clock) but 1. it’s working correctly now, 2. Studio is not directly using the LDraw file (it could be it but flattened by PartDesigner… and the LDraw part is using NOCLIP).
Also, I don’t really get the issue here.  Is it because surfaces are on top of each others and Studio needs the NOCLIP to act correctly while that NOCLIP shouldn’t be necessary?
If someone can explain the issue so that it can be brought up to the Studio team, I can defend it, or at least try to get an answer.
posted a vote of Hold
2026-11-27 23:35:39
Ok. I'm not going to delete this fix but I'm not going to approve it until we get an answer from Studio
2026-11-27 23:40:51
Btw, just did a test:
For the photo-realistic renderer in Studio this works pefectly fine IMO. It's just the work window where both compasses look bugged.
Seems to be related to the overall bugged appearance of multi-colour parts in Studio? All printed an assembly parts have off-colour prints or shader issues there (just compare black/white boat hulls). Most of those seem gone when fully rendered.
Part Author
2026-11-28 02:18:56
I would have reported it on the studio forum but those are down at the moment with the whole hacking thing. Agreed that it looks ok when rendered, it's just when placing the parts it doesn't show up. It does seem to be some studio optimisation that broke the display of these particular parts since the part designer shows it properly. Not sure if it affects anything else Since it's rare to have something with a pattern behind tranparency within the same part.
