Official File parts/3741a.dat
0 Plant Flower Stem
0 Name: 3741a.dat
0 !HELP Placing Flowers (Rotation center is at 0/0/0):
0 !HELP place flower underside at x = 0; y = 16.25 / 21.25 / 26.25; z = 0
0 !HELP rotate 15 degrees around x-axis
0 !HELP move on z-axis 10.25 LDU
0 !HELP rotate the middle / highest flower 120 / 240 degrees around y-axis
0 !KEYWORDS BrickLink 3741, Rebrickable 3741
0 !HISTORY 2013-02-24 [MMR1988] Rewritten to correct dimension errors of 3741
1 16 0 0 0 -0.866 0 -0.5 0 1 0 0.5 0 -0.866 stud.dat
1 16 0 0 0 -1.2175 0 -1.5867 0 1 0 1.5867 0 -1.2175 1-8ring3.dat
1 16 0 0 0 -1 0 1.7321 0 1 0 -1.7321 0 -1 3-16ring3.dat
1 16 0 0 0 1.9829 0 0.261 0 1 0 -0.261 0 1.9829 3-16ring3.dat
4 16 5.4157 0 -5.7248 5.1962 0 -3 3.6526 0 -4.7603 4.8701 0 -6.3468
3 16 5.1962 0 -3 5.4157 0 -5.7248 7.6657 0 -1.8277
4 16 7.9316 0 -1.0442 5.9488 0 -0.7831 5.1962 0 -3 7.6657 0 -1.8277
4 16 2.25 0 7.5224 0.7831 0 5.9488 3 0 5.1962 4 0 6.9282
4 16 -2.25 0 7.6388 -1.5529 0 5.7955 0.7831 0 5.9488 2.25 0 7.5224
4 16 -4.8701 0 6.3468 -3.6526 0 4.7603 -1.5529 0 5.7955 -2.25 0 7.6388
4 16 -4 0 -6.9282 -3 0 -5.1962 -4.7603 0 -3.6526 -5.3895 0 -5.7097
4 16 -5.3895 0 -5.7097 -4.7603 0 -3.6526 -5.7955 0 -1.5529 -7.7404 0 -1.8709
4 16 -7.7404 0 -1.8709 -5.7955 0 -1.5529 -5.9488 0 0.7831 -7.9316 0 1.0442
1 16 0 12 0 -4 0 6.9282 0 1 0 -6.9282 0 -4 4-4edge.dat
1 16 0 2.5 0 -3 0 5.1962 0 9.5 0 -5.1962 0 -3 4-4cylc.dat
1 16 0 0 0 -4 0 6.9282 0 12 0 -6.9282 0 -4 3-16cyli.dat
1 16 0 0 0 7.9316 0 1.0442 0 12 0 -1.0442 0 7.9316 3-16cyli.dat
1 16 0 0 0 -4.8701 0 -6.3468 0 12 0 6.3468 0 -4.8701 1-8cyli.dat
4 16 4.8701 12 -6.3468 5.4157 7 -5.7248 5.4157 0 -5.7248 4.8701 0 -6.3468
4 16 4.8701 12 -6.3468 6.9282 12 -4 6.9282 7 -4 5.4157 7 -5.7248
4 16 7.9316 0 -1.0442 7.6657 0 -1.8277 7.6657 7 -1.8277 7.9316 12 -1.0442
4 16 7.6657 7 -1.8277 6.9282 7 -4 6.9282 12 -4 7.9316 12 -1.0442
4 16 4 12 6.9282 2.25 7 7.5224 2.25 0 7.5224 4 0 6.9282
4 16 4 12 6.9282 1.0442 12 7.9316 1.0442 7 7.9316 2.25 7 7.5224
4 16 1.0442 12 7.9316 -2.0705 12 7.7273 -2.0705 7 7.7273 1.0442 7 7.9316
4 16 -2.0705 12 7.7273 -4.8701 12 6.3468 -2.25 7 7.6388 -2.0705 7 7.7273
4 16 -2.25 7 7.6388 -4.8701 12 6.3468 -4.8701 0 6.3468 -2.25 0 7.6388
4 16 -4 0 -6.9282 -5.3895 0 -5.7097 -5.3895 7 -5.7097 -4 12 -6.9282
4 16 -5.3895 7 -5.7097 -6.3468 7 -4.8701 -6.3468 12 -4.8701 -4 12 -6.9282
4 16 -6.3468 7 -4.8701 -7.7273 7 -2.0705 -7.7273 12 -2.0705 -6.3468 12 -4.8701
4 16 -7.7273 7 -2.0705 -7.7404 7 -1.8709 -7.9316 12 1.0442 -7.7273 12 -2.0705
4 16 -7.7404 0 -1.8709 -7.9316 0 1.0442 -7.9316 12 1.0442 -7.7404 7 -1.8709
5 24 -4 0 -6.9282 -4 12 -6.9282 -1.0442 0 -7.9316 -6.3468 0 -4.8701
5 24 4.8701 0 -6.3468 4.8701 12 -6.3468 6.9282 0 -4 2.0705 0 -7.7273
5 24 6.9282 7 -4 6.9282 12 -4 7.9316 7 -1.0442 4.8701 7 -6.3468
5 24 7.9316 0 -1.0442 7.9316 12 -1.0442 7.7273 0 2.0705 6.9282 0 -4
5 24 4 0 6.9282 4 12 6.9282 1.0442 0 7.9316 6.3468 0 4.8701
5 24 1.0442 7 7.9316 1.0442 12 7.9316 -2.0705 7 7.7273 4 7 6.9282
5 24 -2.0705 7 7.7273 -2.0705 12 7.7273 -4.8701 7 6.3468 1.0442 7 7.9316
5 24 -4.8701 0 6.3468 -4.8701 12 6.3468 -6.9282 0 4 -2.0705 0 7.7273
5 24 -7.9316 0 1.0442 -7.9316 12 1.0442 -7.7273 0 -2.0705 -6.9282 0 4
5 24 -7.7273 7 -2.0705 -7.7273 12 -2.0705 -6.3468 7 -4.8701 -7.9316 7 1.0442
5 24 -6.3468 7 -4.8701 -6.3468 12 -4.8701 -4 7 -6.9282 -7.7273 7 -2.0705
1 16 0 12 0 -1 0 -1.7321 0 -1 0 -1.7321 0 1 4-4ring3.dat
1 16 0 0 0 -4 0 6.9282 0 1 0 -6.9282 0 -4 3-16edge.dat
1 16 0 0 0 7.9316 0 1.0442 0 1 0 -1.0442 0 7.9316 3-16edge.dat
1 16 0 0 0 -4.8701 0 -6.3468 0 1 0 6.3468 0 -4.8701 1-8edge.dat
0 // Edges Brick-Stems
2 24 5.4157 0 -5.7248 4.8698 0 -6.3473
2 24 5.4157 0 -5.7248 5.4157 7 -5.7248
2 24 6.9282 7 -4 5.4157 7 -5.7248
2 24 6.9282 7 -4 7.6657 7 -1.8277
2 24 7.6657 0 -1.8277 7.6657 7 -1.8277
2 24 7.6657 0 -1.8277 7.9318 0 -1.0437
2 24 4 0 6.9282 2.25 0 7.5224
2 24 2.25 0 7.5224 2.25 7 7.5224
2 24 2.25 7 7.5224 1.0437 7 7.9318
1 16 0 7 0 1.0442 0 -7.9316 0 1 0 7.9316 0 1.0442 1-16edge.dat
2 24 -2.25 7 7.6388 -2.0707 7 7.7276
2 24 -2.25 7 7.6388 -2.25 0 7.6388
2 24 -4.8703 0 6.3469 -2.25 0 7.6388
2 24 -4 0 -6.9282 -5.3895 0 -5.7097
2 24 -5.3895 0 -5.7097 -5.3895 7 -5.7097
2 24 -5.3895 7 -5.7097 -6.3473 7 -4.8698
1 16 0 7 0 -7.7274 0 2.0705 0 1 0 -2.0705 0 -7.7274 1-16edge.dat
2 24 -7.7404 7 -1.8709 -7.7276 7 -2.0705
2 24 -7.7404 7 -1.8709 -7.7404 0 -1.8709
2 24 -7.9318 0 1.0443 -7.7404 0 -1.8709
0 // stems
1 16 0 -0.286 10.326 2.25 0 0 0 -15.4102 0.5823 0 4.1291 2.1733 4-4cyli.dat
1 16 0 -15.696 14.456 2.25 0 0 0 0.9659 0.5823 0 -0.2588 2.1733 4-4edge.dat
1 16 0 -15.696 14.456 2 0 0 0 0.9659 0.5176 0 -0.2588 1.9318 4-4edge.dat
1 16 0 -15.696 14.456 0.25 0 0 0 0.9659 0.0647 0 -0.2588 0.2415 4-4ring8.dat
1 16 0 -15.696 14.456 2 0 0 0 -5.7956 0.5176 0 1.5529 1.9318 4-4cyli.dat
1 16 0 -21.492 16.009 2 0 0 0 -1.9318 0.5176 0 0.5176 1.9318 4-8sphe.dat
1 16 -8.943 -0.286 -5.163 -1.125 -4.6967 -1.8822 0 -20.2398 0.5823 1.9486 -2.7116 -1.0867 4-4cyli.dat
1 16 -13.64 -20.526 -7.875 -1 0.2241 -1.673 0 0.9659 0.5176 1.7321 0.1294 -0.9659 4-4edge.dat
1 16 -13.64 -20.526 -7.875 -1.125 0.2241 -1.8822 0 0.9659 0.5823 1.9486 0.1294 -1.0867 4-4edge.dat
1 16 -13.64 -20.526 -7.875 -0.125 0.2241 -0.2091 0 0.9659 0.0647 0.2165 0.1294 -0.1207 4-4ring8.dat
1 16 -13.64 -20.526 -7.875 -1 -1.3449 -1.673 0 -5.7956 0.5176 1.7321 -0.7765 -0.9659 4-4cyli.dat
1 16 -14.985 -26.321 -8.651 -1 -0.4483 -1.673 0 -1.9318 0.5176 1.7321 -0.2588 -0.9659 4-8sphe.dat
1 16 8.943 -0.286 -5.163 -1.125 5.8174 1.8822 0 -25.0694 0.5823 -1.9486 -3.3587 -1.0867 4-4cyli.dat
1 16 14.761 -25.356 -8.522 -1.125 -0.2241 1.8822 0 0.9659 0.5823 -1.9486 0.1294 -1.0867 4-4edge.dat
1 16 14.761 -25.356 -8.522 -1 -0.2241 1.673 0 0.9659 0.5176 -1.7321 0.1294 -0.9659 4-4edge.dat
1 16 14.761 -25.356 -8.522 -0.125 -0.2241 0.2091 0 0.9659 0.0647 -0.2165 0.1294 -0.1207 4-4ring8.dat
1 16 14.761 -25.356 -8.522 -1 1.3449 1.673 0 -5.7956 0.5176 -1.7321 -0.7765 -0.9659 4-4cyli.dat
1 16 16.105 -31.151 -9.298 -1 0.4483 1.673 0 -1.9318 0.5176 -1.7321 -0.2588 -0.9659 4-8sphe.dat
0 // stem connectors
1 16 8.877 7 -5.125 -1.125 0 1.9486 0 -1 0 -1.9486 0 -1.125 2-4disc.dat
1 16 8.877 7 -5.125 -1.125 0 1.9486 0 1 0 -1.9486 0 -1.125 2-4edge.dat
1 16 8.877 7 -5.125 -1.125 0 1.9486 0 -6.7038 0 -1.9486 0 -1.125 2-4cyli.dat
1 16 8.877 0 -5.125 1.125 0 -2.0173 0 1 0 1.9486 0 1.1647 2-4ndis.dat
1 16 8.877 0 -5.125 1.125 0 -2.0173 0 1 0 1.9486 0 1.1647 2-4edge.dat
3 16 5.7344 0 -5.9089 7.7518 0.2962 -7.0736 7.7518 0 -7.0736
3 16 10.0018 0 -3.1764 10.0018 0.2962 -3.1764 7.9844 0 -2.0117
1 16 -8.877 7 -5.125 -1.125 0 -1.9486 0 -1 0 1.9486 0 -1.125 2-4disc.dat
1 16 -8.877 7 -5.125 -1.125 0 -1.9486 0 1 0 1.9486 0 -1.125 2-4edge.dat
1 16 -8.877 7 -5.125 -1.125 0 -1.9486 0 -6.7038 0 1.9486 0 -1.125 2-4cyli.dat
1 16 -8.877 0 -5.125 1.125 0 2.0173 0 1 0 -1.9486 0 1.1647 2-4ndis.dat
1 16 -8.877 0 -5.125 1.125 0 2.0173 0 1 0 -1.9486 0 1.1647 2-4edge.dat
3 16 -7.9844 0 -2.0117 -10.0018 0.2962 -3.1764 -10.0018 0 -3.1764
3 16 -7.7518 0 -7.0735 -7.7518 0.2962 -7.0735 -5.7344 0 -5.9089
1 16 0 7 10.25 2.25 0 0 0 -1 0 0 0 2.25 2-4disc.dat
1 16 0 7 10.25 2.25 0 0 0 1 0 0 0 2.25 2-4edge.dat
1 16 0 7 10.25 2.25 0 0 0 -6.7038 0 0 0 2.25 2-4cyli.dat
1 16 0 0 10.25 -2.25 0 0 0 1 0 0 0 -2.3294 2-4ndis.dat
1 16 0 0 10.25 -2.25 0 0 0 1 0 0 0 -2.3294 2-4edge.dat
3 16 2.25 0 7.9206 2.25 0.2962 10.25 2.25 0 10.25
3 16 -2.25 0 10.25 -2.25 0.2962 10.25 -2.25 0 7.9206
1 16 8.877 0 -5.125 1.8822 -0.1351 1.125 0.5823 0.5824 0 -1.0867 0.078 1.9486 1-4cyls2.dat
1 16 8.877 0 -5.125 1.8822 -0.1351 -1.125 0.5823 0.5824 0 -1.0867 0.078 -1.9486 1-4cyls2.dat
1 16 8.877 0 -5.125 -1.125 0 1.9486 0 1 0.2962 -1.9486 0 -1.125 2-4edge.dat
1 16 8.877 0.296 -5.125 1.9486 0 1.125 0 -0.2962 0 -1.125 0 1.9486 1-4cyls.dat
1 16 8.877 0.296 -5.125 1.9486 0 -1.125 0 -0.2962 0 -1.125 0 -1.9486 1-4cyls.dat
1 16 8.943 -0.286 -5.163 1.8822 -0.0664 1.125 0.5823 0.2861 0 -1.0867 0.0383 1.9486 1-4cyls.dat
1 16 8.943 -0.286 -5.163 1.8822 -0.0664 -1.125 0.5823 0.2861 0 -1.0867 0.0383 -1.9486 1-4cyls.dat
1 16 8.943 -0.286 -5.163 -1.125 -0.0664 -1.8822 0 0.2862 -0.5823 -1.9486 0.0383 1.0867 2-4cyli.dat
1 16 -8.877 0 -5.125 -1.8822 0.1351 1.125 0.5823 0.5824 0 -1.0867 0.078 -1.9486 1-4cyls2.dat
1 16 -8.877 0 -5.125 -1.8822 0.1351 -1.125 0.5823 0.5824 0 -1.0867 0.078 1.9486 1-4cyls2.dat
1 16 -8.877 0 -5.125 -1.125 0 -1.9486 0 1 0.2962 1.9486 0 -1.125 2-4edge.dat
1 16 -8.877 0.296 -5.125 -1.9486 0 1.125 0 -0.2962 0 -1.125 0 -1.9486 1-4cyls.dat
1 16 -8.877 0.296 -5.125 -1.9486 0 -1.125 0 -0.2962 0 -1.125 0 1.9486 1-4cyls.dat
1 16 -8.943 -0.286 -5.163 -1.8822 0.0664 1.125 0.5823 0.2861 0 -1.0867 0.0383 -1.9486 1-4cyls.dat
1 16 -8.943 -0.286 -5.163 -1.8822 0.0664 -1.125 0.5823 0.2861 0 -1.0867 0.0383 1.9486 1-4cyls.dat
1 16 -8.943 -0.286 -5.163 -1.125 0.0664 1.8822 0 0.2862 -0.5823 1.9486 0.0383 1.0867 2-4cyli.dat
1 16 0 0 10.25 0 0 -2.25 0.5823 0.5824 0 2.1733 -0.156 0 1-4cyls2.dat
1 16 0 0 10.25 0 0 2.25 0.5823 0.5824 0 2.1733 -0.156 0 1-4cyls2.dat
1 16 0 0 10.25 2.25 0 0 0 1 0.2962 0 0 2.25 2-4edge.dat
1 16 0 0.296 10.25 0 0 -2.25 0 -0.2962 0 2.25 0 0 1-4cyls.dat
1 16 0 0.296 10.25 0 0 2.25 0 -0.2962 0 2.25 0 0 1-4cyls.dat
1 16 0 -0.286 10.326 0 0 -2.25 0.5823 0.2861 0 2.1733 -0.0766 0 1-4cyls.dat
1 16 0 -0.286 10.326 0 0 2.25 0.5823 0.2861 0 2.1733 -0.0766 0 1-4cyls.dat
1 16 0 -0.286 10.326 2.25 0 0 0 0.2862 -0.5823 0 -0.0767 -2.1733 2-4cyli.dat
4 16 7.7518 7 -7.0736 5.4157 7 -5.7248 6.9282 7 -4 8.8768 7 -5.125
4 16 8.8768 7 -5.125 6.9282 7 -4 7.6657 7 -1.8277 10.0018 7 -3.1764
4 16 7.9844 0 -2.0117 10.0018 0.2962 -3.1764 10.0018 7 -3.1764 7.6657 7 -1.8277
3 16 7.6657 7 -1.8277 7.6657 0 -1.8277 7.9844 0 -2.0117
4 16 5.4157 7 -5.7248 7.7518 7 -7.0736 7.7518 0.2962 -7.0736 5.7344 0 -5.9089
3 16 5.7344 0 -5.9089 5.4157 0 -5.7248 5.4157 7 -5.7248
4 16 7.6657 0 -1.8277 5.4157 0 -5.7248 6.8594 0 -3.9603 7.9844 0 -2.0117
3 16 5.4157 0 -5.7248 5.7344 0 -5.9089 6.8594 0 -3.9603
2 24 7.6657 7 -1.8277 10.0018 7 -3.1764
2 24 5.4157 7 -5.7248 7.7518 7 -7.0736
2 24 7.6657 0 -1.8277 10.0018 0 -3.1764
2 24 5.4157 0 -5.7248 7.7518 0 -7.0736
3 16 2.25 7 7.5224 1.0437 7 7.9318 2.25 7 10.25
4 16 1.0437 7 7.9318 -2.0707 7 7.7276 -2.25 7 10.25 2.25 7 10.25
3 16 -2.25 7 10.25 -2.0707 7 7.7276 -2.25 7 7.6388
4 16 -2.25 7 10.25 -2.25 7 7.6388 -2.25 0 7.9206 -2.25 0.2962 10.25
3 16 -2.25 7 7.6388 -2.25 0 7.6388 -2.25 0 7.9206
4 16 2.25 7 7.5224 2.25 7 10.25 2.25 0.2962 10.25 2.25 0 7.9206
3 16 2.25 0 7.9206 2.25 0 7.5224 2.25 7 7.5224
4 16 2.25 0 7.5224 0 0 7.9206 -2.25 0 7.9206 -2.25 0 7.6388
3 16 0 0 7.9206 2.25 0 7.5224 2.25 0 7.9206
2 24 -2.25 7 10.25 -2.25 7 7.6388
2 24 -2.25 0 10.25 -2.25 0 7.6388
2 24 2.25 7 7.5224 2.25 7 10.25
2 24 2.25 0 7.5224 2.25 0 10.25
3 16 -7.7518 7 -7.0736 -6.3473 7 -4.8698 -5.3895 7 -5.7097
4 16 -7.7518 7 -7.0736 -10.0018 7 -3.1764 -7.7276 7 -2.0705 -6.3473 7 -4.8698
3 16 -7.7404 7 -1.8709 -7.7276 7 -2.0705 -10.0018 7 -3.1764
4 16 -10.0018 0.2962 -3.1764 -7.9844 0 -2.0117 -7.7404 7 -1.8709 -10.0018 7 -3.1764
3 16 -7.9844 0 -2.0117 -7.7404 0 -1.8709 -7.7404 7 -1.8709
4 16 -5.7344 0 -5.9089 -7.7518 0.2962 -7.0736 -7.7518 7 -7.0736 -5.3895 7 -5.7097
3 16 -5.3895 7 -5.7097 -5.3895 0 -5.7097 -5.7344 0 -5.9089
4 16 -7.7404 0 -1.8709 -7.9844 0 -2.0117 -6.8594 0 -3.9603 -5.3895 0 -5.7097
3 16 -5.7344 0 -5.9089 -5.3895 0 -5.7097 -6.8594 0 -3.9603
2 24 -10.0018 7 -3.1764 -7.7404 7 -1.8709
2 24 -10.0018 0 -3.1764 -7.7404 0 -1.8709
2 24 -5.3895 7 -5.7097 -7.7518 7 -7.0736
2 24 -5.3895 0 -5.7097 -7.7518 0 -7.0736
Official
