Official File parts/4254.dat
~Technic Shock Absorber  6.5L Piston Rod
0 ~Technic Shock Absorber  6.5L Piston Rod
0 Name: 4254.dat
0 Author: Jeff Boen [onyx]
0 !LDRAW_ORG Part UPDATE 2012-01
0 !HISTORY 1998-03-23 [PTadmin] Official Update 1998-03
0 !HISTORY 2000-09-30 [PTadmin] Official Update 2000-02
0 !HISTORY 2007-07-21 [PTadmin] Header formatted for Contributor Agreement
0 !HISTORY 2008-07-07 [sbliss] moved spring to separate part file; changed to dynamic colors; bfc'ed; used more primitives (2004-11-22)
0 !HISTORY 2008-07-08 [guyvivan] Fixed BFC and quad error and use more primitives (2004-12-19)
0 !HISTORY 2010-04-05 [PTadmin] Renamed from 731
0 !HISTORY 2011-03-09 [Brickaneer] Matched edges exactly, replaced/added prims, designed stopper more realistic.
0 !HISTORY 2011-03-14 [Brickaneer] Revised.
0 // Lower Peghole
1 16 0 0 -8 6 0 0 0 0 -6 0 16 0 4-4cyli.dat
1 16 0 0 -10 1 0 0 0 0 -1 0 1 0 peghole.dat
1 16 0 0 10 -1 0 0 0 0 -1 0 -1 0 peghole.dat
1 16 0 0 -10 2 0 0 0 0 -2 0 1 0 4-4ring4.dat
1 16 0 0 10 -2 0 0 0 0 -2 0 -1 0 4-4ring4.dat
1 16 0 0 -10 10 0 0 0 0 -10 0 1 0 4-4edge.dat
1 16 0 0 10 10 0 0 0 0 -10 0 1 0 4-4edge.dat
1 16 0 0 -10 10 0 0 0 0 -10 0 20 0 4-4cyli.dat
0 // Edges of Lower Peghole base
2 24 9 -4.1846 0 8.315 -5.2096 3.444
2 24 8.315 -5.2096 3.444 7.071 -7.071 5.3059
2 24 7.071 -7.071 5.3059 6.364 -7.5435 6.364
2 24 3.827 -9.239 8.0591 6.364 -7.5435 6.364
2 24 3.444 -9.3152 8.315 3.827 -9.239 8.0591
2 24 0 -10 9 3.444 -9.3152 8.315
2 24 -3.444 -9.3152 8.315 0 -10 9
2 24 -3.827 -9.239 8.0591 -3.444 -9.3152 8.315
2 24 -6.364 -7.5435 6.364 -3.827 -9.239 8.0591
2 24 -7.071 -7.071 5.3059 -6.364 -7.5435 6.364
2 24 -8.315 -5.2096 3.444 -7.071 -7.071 5.3059
2 24 -9 -4.1846 0 -8.315 -5.2096 3.444
2 24 -8.315 -5.2096 -3.444 -9 -4.1846 0
2 24 -7.071 -7.071 -5.3059 -8.315 -5.2096 -3.444
2 24 -6.364 -7.5435 -6.364 -7.071 -7.071 -5.3059
2 24 -6.364 -7.5435 -6.364 -3.827 -9.239 -8.0591
2 24 -3.827 -9.239 -8.0591 -3.444 -9.3152 -8.315
2 24 -3.444 -9.3152 -8.315 0 -10 -9
2 24 0 -10 -9 3.444 -9.3152 -8.315
2 24 3.444 -9.3152 -8.315 3.827 -9.239 -8.0591
2 24 3.827 -9.239 -8.0591 6.364 -7.5435 -6.364
2 24 6.364 -7.5435 -6.364 7.071 -7.071 -5.3059
2 24 7.071 -7.071 -5.3059 8.315 -5.2096 -3.444
2 24 8.315 -5.2096 -3.444 9 -4.1846 0
0 // Lower Peghole base surfaces
1 16 0 -10 0 -9 0 0 0 5.82 0 0 0 -9 1-4cyls2.dat
1 16 0 -10 0 9 0 0 0 5.82 0 0 0 -9 1-4cyls2.dat
1 16 0 -10 0 9 0 0 0 5.82 0 0 0 9 1-4cyls2.dat
1 16 0 -10 0 -9 0 0 0 5.82 0 0 0 9 1-4cyls2.dat
1 16 0 -10 0 9 0 0 0 1 0 0 0 9 4-4edge.dat
0 // Axle shaft
1 16 0 -10 0 3 0 0 0 1 0 0 0 3 4-4ring2.dat
1 16 0 -10 0 1 0 0 0 1 0 0 0 1 4-4ring5.dat
1 16 0 -11 0 5 0 0 0 1 0 0 0 5 4-4cylo.dat
1 16 0 -11 0 1 0 0 0 -1 0 0 0 -1 4-4ring5.dat
1 16 0 -11 0 1 0 0 0 -1 0 0 0 -1 4-4ring6.dat
1 16 0 -15 0 7 0 0 0 4 0 0 0 7 4-4cylo.dat
1 16 0 -15 0 7 0 0 0 4 0 0 0 7 4-4disc.dat
1 16 0 -15 0 1 0 0 0 1 0 0 0 1 axlehol2.dat
1 16 0 -15 0 1 0 0 0 1 0 0 0 1 axlehol9.dat
1 16 0 -60 0 1 0 0 0 45 0 0 0 1 axlehol8.dat
1 16 0 -60 0 1 0 0 0 1 0 0 0 1 axlehol2.dat
2 24 -2 -60 -2 -2 -60 -1
2 24 -5.602 -60 -2 -2 -60 -2
2 24 -2 -60 2 -2 -60 1
2 24 -5.602 -60 2 -2 -60 2
2 24 2 -60 2 2 -60 1
2 24 5.602 -60 2 2 -60 2
2 24 2 -60 -2 2 -60 -1
2 24 5.602 -60 -2 2 -60 -2
0 // Stopper block
3 16 0 -60 -6 2 -60 -5.602 -2 -60 -5.602
1 16 0 -60 0 -2 0 0 0 1 0 0 0 -1 rect2p.dat
3 16 -2 -60 5.602 2 -60 5.602 0 -60 6
4 16 -5.602 -60 -2 -2 -60 -2 -2 -60 -1 -6 -60 0
3 16 -6 -60 0 -2 -60 -1 -2 -60 1
4 16 -6 -60 0 -2 -60 1 -2 -60 2 -5.602 -60 2
4 16 5.602 -60 2 2 -60 2 2 -60 1 6 -60 0
3 16 6 -60 0 2 -60 1 2 -60 -1
4 16 6 -60 0 2 -60 -1 2 -60 -2 5.602 -60 -2
1 16 0 -66 5.602 2 0 0 0 0 6 0 -1 0 rect3.dat
4 16 -2 -60 2 -2 -72 1 -2 -72 5.602 -2 -60 5.602
3 16 -2 -60 2 -2 -60 1 -2 -72 1
4 16 2 -60 5.602 2 -72 5.602 2 -72 1 2 -60 2
3 16 2 -72 1 2 -60 1 2 -60 2
1 16 0 -66 1 0 0 -2 -6 0 0 0 1 0 rect2p.dat
1 16 0 -66 -1 0 0 2 -6 0 0 0 -1 0 rect2p.dat
3 16 -2 -72 -1 -2 -60 -1 -2 -60 -2
4 16 -2 -60 -5.602 -2 -72 -5.602 -2 -72 -1 -2 -60 -2
3 16 2 -60 -2 2 -60 -1 2 -72 -1
4 16 2 -60 -2 2 -72 -1 2 -72 -5.602 2 -60 -5.602
1 16 0 -66 -5.602 -2 0 0 0 0 6 0 1 0 rect3.dat
1 16 0 -73.5 -7.301 2 0 0 0 0 1.5 0 -1.699 0 box2-5.dat
1 16 0 -73.5 7.301 -2 0 0 0 0 1.5 0 1.699 0 box2-5.dat
4 16 -2 -72 5.602 -2 -72 1 -2 -80 3 -2 -80 4
4 16 -2 -80 4 -2 -75 9 -2 -72 9 -2 -72 5.602
1 16 0 -77.5 6.5 -2 0 0 0 1 -2.5 0 -1 -2.5 rect3.dat
1 16 0 -80 3.5 -2 0 0 0 1 0 0 0 -0.5 rect3.dat
1 16 0 -76 2 -2 0 0 0 1 4 0 4 -1 rect3.dat
4 16 2 -80 4 2 -80 3 2 -72 1 2 -72 5.602
4 16 2 -72 5.602 2 -72 9 2 -75 9 2 -80 4
4 16 -2 -80 -4 -2 -80 -3 -2 -72 -1 -2 -72 -5.602
4 16 -2 -72 -5.602 -2 -72 -9 -2 -75 -9 -2 -80 -4
1 16 0 -77.5 -6.5 2 0 0 0 1 -2.5 0 1 2.5 rect3.dat
1 16 0 -80 -3.5 2 0 0 0 1 0 0 0 0.5 rect3.dat
1 16 0 -76 -2 2 0 0 0 1 4 0 -4 1 rect3.dat
4 16 2 -72 -5.602 2 -72 -1 2 -80 -3 2 -80 -4
4 16 2 -80 -4 2 -75 -9 2 -72 -9 2 -72 -5.602
