Unofficial File parts/11538.dat
Minifig Helmet with Cheek Protectors and Communicator
0 Minifig Helmet with Cheek Protectors and Communicator 0 Name: 11538.dat 0 Author: Lisa Winter [LisaWinter] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !CATEGORY Minifig Headwear 0 !KEYWORDS A-wing, Rebel, Star Wars, SW
1 16 0 -6 0 1 0 0 0 -1.5 0 0 0 1 stud4o.dat 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\11538s01.dat 1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\11538s01.dat 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\11538s02.dat 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\11538s03.dat 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\11538s04.dat 1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\11538s04.dat 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\11538s05.dat 1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\11538s05.dat 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\11538s06.dat 1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\11538s06.dat 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\11538s07.dat 1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\11538s07.dat 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\11538s08.dat 1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\11538s08.dat 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\11538s09.dat 1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\11538s09.dat
Awaiting Admin Review (CCN) Awaiting Admin Review (CCN)
User Vote
Philo Certify
fwcain Certify
Bertrand Lequy [Berth]
Part Author
2021-09-08 14:25:02
Please take a look here for the subfiling :
https://rebrickable.com/parts/11538/minifig-helmet-rebel-with-check-protectors-star-wars-plain/#rel_parts
(I have 3 of them at home)
made the following comment.
2021-09-08 15:30:01
Please reconsider the subfile structure.
1.) It would be better to have the unprinted inside, and all the loose primitives (and any added edge/condlines) in a single s01 subfile.
Used as the base subfile for all the differently patterned version. If not, you will have to add the stud4 and all the edge/condlines into every printed version.
2.) If you have all edge/condlines in the top level part they will all have the colour of the main part. I guess you want to give some of the subfiles a single colour. Say red or blue.
And then the main file is used white in a model. You will have white edge/condlines on the red and blue surfaces.
Gerald Lasser [GeraldLasser]
2021-09-08 15:30:01
OMG, the next helmet subfile-mania like the Mandalorian one :-)
Part Author
2021-09-08 16:40:01
@Magnus : Indeed, I'm going to rethink this
@Gerald : there's far less print for this one :D
Part Author
2021-09-08 16:45:01
s01 reworked
Existing certification-votes were deleted.
posted a vote of Hold.
2021-10-07 15:50:01
Both edge and condlines:
2 24 2.108 10.241 20.256 2.157 9.08 19.986
2 24 2.157 9.08 19.986 2.189 8.039 19.482
2 24 2.189 8.039 19.482 2.227 6.308 17.913
5 24 2.204 8.039 19.482 2.171 9.08 19.986 0 8.883 20.282 2.416 9.02 19.385
5 24 2.171 9.08 19.986 2.123 10.241 20.256 2.463 9.915 19.46 0 10.211 20.502
5 24 2.241 6.308 17.913 2.204 8.039 19.482 0 7.665 19.742 2.586 8.303 18.244
Hold-voting for this error.
Before you start and make a lot of patterns on this, you should try to have as many "convex surfaces" as possible.
Like here:
3 12 9.391 -7.373 -5.394 12.697 -3.353 -5.208 7.52 -5.941 -10.672
3 12 7.52 -5.941 -10.672 12.697 -3.353 -5.208 10.429 -2.634 -10.767
These two make a concave surface and should be changed so that it is convex.
Generating unwanted condlines, that show up " too early"
And here's some more examples of surfaces that need fixing:
3 11 6.661 7.903 16.929 7.866 8.411 17.312 7.045 7.954 16.447
3 11 7.045 7.954 16.447 7.866 8.411 17.312 7.593 7.821 16.318
3 11 7.026 -5.107 11.969 5.674 -3.038 11.902 6.123 -2.965 11.924
3 11 5.358 -3.363 11.897 5.674 -3.038 11.902 7.026 -5.107 11.969
These are probably flat on the real part. No ditch.
Generating unwanted condlines, that show up " too early".
[PTadmin]
Part Author
edited the part header.
2022-01-14 02:35:01
Franklin W. Cain [fwcain]
Part Reviewer
2022-12-03 03:40:02
Petty complaint on my part -- it is spelled "Cheek".
So, when you re-submit after fixing the errors, please correct the spelling also.
Other than that -- Awesome work with all of those details!!
Part Reviewer
2022-12-03 03:45:02
Addendum...
Consider combining all of the "detail" printable sections into just one sub-file, and then documenting the various "areas" of the helmet with that sub-file.
This way, we reduce the number of sub-files, while still making it easier for other authors to make detailed (i.e. patterned) versions of this part.
[PTadmin]
Part Author
2022-12-03 04:55:01
Orion Pobursky [OrionP]
2024-03-09 17:24:08
Not CC_BY_4
cancelled their vote.
2024-05-11 07:18:20
Jeff Jones [notmaster]
Part Author
2025-01-14 16:24:29
maybe would fix
Rene Rechthaler [Blechtaler]
2025-11-27 16:53:01
idk why but the unpatterned helmet reminds me of the Doomguy
Part Reviewer
posted a vote of Certify.
2026-01-24 20:22:58
Philippe Hurbain [Philo]
2026-02-07 16:14:41
This part is copyright © Lisa Winter
LDraw.org Parts Tracker,
