Unofficial File parts/2860b.dat
~Train Track 6 Studs Wide Switch Blade Right
0 ~Train Track 6 Studs Wide Switch Blade Right 0 Name: 2860b.dat 0 Author: Jens Brühl [jb70] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !HISTORY 2012-09-10 [KROACH] Added missing lines in bottom channel 0 !HISTORY 2016-03-26 [MMR1988] Added missing condlines due to primitive change 0 !HISTORY 2020-12-17 [jb70] New part 2860b.dat for plastic train tracks based on the previous 9V-part 2860.dat from [KROACH] 0 !HISTORY 2020-12-17 [jb70] Redesigned rail to be solid plastic which is different to the 9V part 0 !HISTORY 2025-06-08 [jb70] Using Subfile 2860s01.dat
0 // Curved Track as reference for the rail geometry 0 // 1 16 6.073 0 -52.372 .98079 0 .19509 0 1 0 -.19509 0 .98079 53400.dat 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\2860s01.dat 2 24 -50.010403 -16 10.375 -40.595895 -16 9.198189 2 24 -7.460199 -16 4.172096 3.538021 -16 2.208064 2 24 2.444608 -16 -3.691466 -8.476296 -16 -1.74124 2 24 -41.379052 -16 3.24952 -52.387056 -16 4.625517 2 24 -19.421791 -16 .065869 -30.39 -16 1.72955 2 24 -29.529047 -16 7.667459 -18.483184 -16 5.991999 2 24 -18.483184 -16 5.991999 -7.460199 -16 4.172096 2 24 -41.379052 -16 3.24952 -30.39 -16 1.72955 2 24 -19.421791 -16 .065869 -8.476296 -16 -1.74124 2 24 -40.595895 -16 9.198189 -29.529047 -16 7.667459 4 16 -41.379052 -16 3.24952 -52.387056 -16 4.625517 -52.387056 -8 4.625517 -41.379052 -8 3.24952 4 16 -30.39 -8 1.72955 -30.39 -16 1.72955 -41.379052 -16 3.24952 -41.379052 -8 3.24952 4 16 -19.421791 -8 .065869 -19.421791 -16 .065869 -30.39 -16 1.72955 -30.39 -8 1.72955 4 16 -19.421791 -16 .065869 -19.421791 -8 .065869 -8.476296 -8 -1.74124 -8.476296 -16 -1.74124 4 16 -8.476296 -16 -1.74124 -8.476296 -8 -1.74124 2.444608 -8 -3.691466 2.444608 -16 -3.691466 4 16 -7.460199 -16 4.172096 3.538021 -16 2.208064 3.538021 -8 2.208064 -7.460199 -8 4.172096 4 16 -18.483184 -16 5.991999 -7.460199 -16 4.172096 -7.460199 -8 4.172096 -18.483184 -8 5.991999 4 16 -29.529047 -16 7.667459 -18.483184 -16 5.991999 -18.483184 -8 5.991999 -29.529047 -8 7.667459 4 16 -40.595895 -16 9.198189 -29.529047 -16 7.667459 -29.529047 -8 7.667459 -40.595895 -8 9.198189 4 16 -50.010403 -16 10.375 -40.595895 -16 9.198189 -40.595895 -8 9.198189 -50.010403 -8 10.375 4 16 2.444608 -16 -3.691466 3.538021 -16 2.208064 -7.460199 -16 4.172096 -8.476296 -16 -1.74124 4 16 -8.476296 -16 -1.74124 -7.460199 -16 4.172096 -18.483184 -16 5.991999 -19.421791 -16 .065869 4 16 -19.421791 -16 .065869 -18.483184 -16 5.991999 -29.529047 -16 7.667459 -30.39 -16 1.72955 4 16 -30.39 -16 1.72955 -29.529047 -16 7.667459 -40.595895 -16 9.198189 -41.379052 -16 3.24952 4 16 -41.379052 -16 3.24952 -40.595895 -16 9.198189 -50.010403 -16 10.375 -52.387056 -16 4.625517 5 24 -7.460199 -16 4.172096 -7.460199 -8 4.172096 3.538021 -16 2.208064 -18.483184 -8 5.991999 5 24 -41.379052 -8 3.24952 -41.379052 -16 3.24952 -52.387056 -16 4.625517 -30.39 -8 1.72955 5 24 -18.483184 -8 5.991999 -18.483184 -16 5.991999 -29.529047 -8 7.667459 -7.460199 -16 4.172096 5 24 -29.529047 -8 7.667459 -29.529047 -16 7.667459 -40.595895 -8 9.198189 -18.483184 -16 5.991999 5 24 -8.476296 -16 -1.74124 -8.476296 -8 -1.74124 2.444608 -8 -3.691466 -19.421791 -16 .065869 5 24 -19.421791 -8 .065869 -19.421791 -16 .065869 -30.39 -16 1.72955 -8.476296 -8 -1.74124 5 24 -30.39 -16 1.72955 -30.39 -8 1.72955 -41.379052 -16 3.24952 -19.421791 -8 .065869 5 24 -40.595895 -8 9.198189 -40.595895 -16 9.198189 -50.010403 -8 10.375 -29.529047 -16 7.667459 4 16 -16.037151 -7.5 3.561125 -16.362934 -7.5 1.587881 -31.215573 -7.5 3.862738 -30.941555 -7.5 5.843834 4 16 -31.215573 -7.5 3.862738 -16.362934 -7.5 1.587881 -16.362934 -5.5 1.587881 -31.215573 -5.5 3.862738 4 16 -16.362934 -5.5 1.587881 -19.421791 -5.5 .065869 -30.39 -5.5 1.72955 -31.215573 -5.5 3.862738 3 16 -16.362934 -5.5 1.587881 -16.688719 -5.5 -.385363 -19.421791 -5.5 .065869 3 16 -30.39 -5.5 1.72955 -31.489592 -5.5 1.881642 -31.215573 -5.5 3.862738 4 16 -16.037151 -5.5 3.561125 -16.037151 -7.5 3.561125 -30.941555 -7.5 5.843834 -30.941555 -5.5 5.843834 4 16 -29.529047 -5.5 7.667459 -18.483184 -5.5 5.991999 -16.037151 -5.5 3.561125 -30.941555 -5.5 5.843834 3 16 -15.711367 -5.5 5.53437 -16.037151 -5.5 3.561125 -18.483184 -5.5 5.991999 3 16 -30.667536 -5.5 7.824931 -29.529047 -5.5 7.667459 -30.941555 -5.5 5.843834 2 24 -31.215573 -7.5 3.862738 -16.362934 -7.5 1.587881 2 24 -16.037151 -7.5 3.561125 -30.941555 -7.5 5.843834 2 24 -16.362934 -5.5 1.587881 -31.215573 -5.5 3.862738 2 24 -30.941555 -5.5 5.843834 -16.037151 -5.5 3.561125 5 24 -16.037151 -7.5 3.561125 -16.037151 -5.5 3.561125 -7.798898 -5.5 2.200984 -30.941555 -5.5 5.843834 5 24 -30.941555 -7.5 5.843834 -30.941555 -5.5 5.843834 -16.037151 -5.5 3.561125 -40.856947 -5.5 7.215299 5 24 -16.362934 -7.5 1.587881 -16.362934 -5.5 1.587881 -8.137597 -5.5 .229872 -31.215573 -5.5 3.862738 5 24 -31.215573 -7.5 3.862738 -31.215573 -5.5 3.862738 -16.362934 -5.5 1.587881 -41.118 -5.5 5.23241
    Line 20: 2 24 -50.010403 -16 10.375 -40.595895 -16 9.198189
    Line 21: 2 24 -7.460199 -16 4.172096 3.538021 -16 2.208064
    Line 22: 2 24 2.444608 -16 -3.691466 -8.476296 -16 -1.74124
    Line 23: 2 24 -41.379052 -16 3.24952 -52.387056 -16 4.625517
    Line 24: 2 24 -19.421791 -16 .065869 -30.39 -16 1.72955
    Line 25: 2 24 -29.529047 -16 7.667459 -18.483184 -16 5.991999
    Line 26: 2 24 -18.483184 -16 5.991999 -7.460199 -16 4.172096
    Line 27: 2 24 -41.379052 -16 3.24952 -30.39 -16 1.72955
    Line 28: 2 24 -19.421791 -16 .065869 -8.476296 -16 -1.74124
    Line 29: 2 24 -40.595895 -16 9.198189 -29.529047 -16 7.667459
    Line 31: 4 16 -41.379052 -16 3.24952 -52.387056 -16 4.625517 -52.387056 -8 4.625517 -41.379052 -8 3.24952
    Line 33: 4 16 -19.421791 -8 .065869 -19.421791 -16 .065869 -30.39 -16 1.72955 -30.39 -8 1.72955
    Line 34: 4 16 -19.421791 -16 .065869 -19.421791 -8 .065869 -8.476296 -8 -1.74124 -8.476296 -16 -1.74124
    Line 35: 4 16 -8.476296 -16 -1.74124 -8.476296 -8 -1.74124 2.444608 -8 -3.691466 2.444608 -16 -3.691466
    Line 36: 4 16 -7.460199 -16 4.172096 3.538021 -16 2.208064 3.538021 -8 2.208064 -7.460199 -8 4.172096
    Line 37: 4 16 -18.483184 -16 5.991999 -7.460199 -16 4.172096 -7.460199 -8 4.172096 -18.483184 -8 5.991999
    Line 38: 4 16 -29.529047 -16 7.667459 -18.483184 -16 5.991999 -18.483184 -8 5.991999 -29.529047 -8 7.667459
    Line 39: 4 16 -40.595895 -16 9.198189 -29.529047 -16 7.667459 -29.529047 -8 7.667459 -40.595895 -8 9.198189
    Line 40: 4 16 -50.010403 -16 10.375 -40.595895 -16 9.198189 -40.595895 -8 9.198189 -50.010403 -8 10.375
    Line 41: 4 16 2.444608 -16 -3.691466 3.538021 -16 2.208064 -7.460199 -16 4.172096 -8.476296 -16 -1.74124
    Line 42: 4 16 -8.476296 -16 -1.74124 -7.460199 -16 4.172096 -18.483184 -16 5.991999 -19.421791 -16 .065869
    Line 43: 4 16 -19.421791 -16 .065869 -18.483184 -16 5.991999 -29.529047 -16 7.667459 -30.39 -16 1.72955
    Line 45: 4 16 -41.379052 -16 3.24952 -40.595895 -16 9.198189 -50.010403 -16 10.375 -52.387056 -16 4.625517
    Line 47: 5 24 -7.460199 -16 4.172096 -7.460199 -8 4.172096 3.538021 -16 2.208064 -18.483184 -8 5.991999
    Line 48: 5 24 -41.379052 -8 3.24952 -41.379052 -16 3.24952 -52.387056 -16 4.625517 -30.39 -8 1.72955
    Line 49: 5 24 -18.483184 -8 5.991999 -18.483184 -16 5.991999 -29.529047 -8 7.667459 -7.460199 -16 4.172096
    Line 50: 5 24 -29.529047 -8 7.667459 -29.529047 -16 7.667459 -40.595895 -8 9.198189 -18.483184 -16 5.991999
    Line 51: 5 24 -8.476296 -16 -1.74124 -8.476296 -8 -1.74124 2.444608 -8 -3.691466 -19.421791 -16 .065869
    Line 52: 5 24 -19.421791 -8 .065869 -19.421791 -16 .065869 -30.39 -16 1.72955 -8.476296 -8 -1.74124
    Line 54: 5 24 -40.595895 -8 9.198189 -40.595895 -16 9.198189 -50.010403 -8 10.375 -29.529047 -16 7.667459
    Line 56: 4 16 -16.037151 -7.5 3.561125 -16.362934 -7.5 1.587881 -31.215573 -7.5 3.862738 -30.941555 -7.5 5.843834
    Line 57: 4 16 -31.215573 -7.5 3.862738 -16.362934 -7.5 1.587881 -16.362934 -5.5 1.587881 -31.215573 -5.5 3.862738
    Line 58: 4 16 -16.362934 -5.5 1.587881 -19.421791 -5.5 .065869 -30.39 -5.5 1.72955 -31.215573 -5.5 3.862738
    Line 59: 3 16 -16.362934 -5.5 1.587881 -16.688719 -5.5 -.385363 -19.421791 -5.5 .065869
    Line 61: 4 16 -16.037151 -5.5 3.561125 -16.037151 -7.5 3.561125 -30.941555 -7.5 5.843834 -30.941555 -5.5 5.843834
    Line 62: 4 16 -29.529047 -5.5 7.667459 -18.483184 -5.5 5.991999 -16.037151 -5.5 3.561125 -30.941555 -5.5 5.843834
    Line 63: 3 16 -15.711367 -5.5 5.53437 -16.037151 -5.5 3.561125 -18.483184 -5.5 5.991999
    Line 64: 3 16 -30.667536 -5.5 7.824931 -29.529047 -5.5 7.667459 -30.941555 -5.5 5.843834
    Line 65: 2 24 -31.215573 -7.5 3.862738 -16.362934 -7.5 1.587881
    Line 66: 2 24 -16.037151 -7.5 3.561125 -30.941555 -7.5 5.843834
    Line 67: 2 24 -16.362934 -5.5 1.587881 -31.215573 -5.5 3.862738
    Line 68: 2 24 -30.941555 -5.5 5.843834 -16.037151 -5.5 3.561125
    Line 69: 5 24 -16.037151 -7.5 3.561125 -16.037151 -5.5 3.561125 -7.798898 -5.5 2.200984 -30.941555 -5.5 5.843834
    Line 70: 5 24 -30.941555 -7.5 5.843834 -30.941555 -5.5 5.843834 -16.037151 -5.5 3.561125 -40.856947 -5.5 7.215299
    Line 71: 5 24 -16.362934 -7.5 1.587881 -16.362934 -5.5 1.587881 -8.137597 -5.5 .229872 -31.215573 -5.5 3.862738
    Line 72: 5 24 -31.215573 -7.5 3.862738 -31.215573 -5.5 3.862738 -16.362934 -5.5 1.587881 -41.118 -5.5 5.23241
    Line 32: 4 16 -30.39 -8 1.72955 -30.39 -16 1.72955 -41.379052 -16 3.24952 -41.379052 -8 3.24952
    Line 44: 4 16 -30.39 -16 1.72955 -29.529047 -16 7.667459 -40.595895 -16 9.198189 -41.379052 -16 3.24952
    Line 53: 5 24 -30.39 -16 1.72955 -30.39 -8 1.72955 -41.379052 -16 3.24952 -19.421791 -8 .065869
    Line 60: 3 16 -30.39 -5.5 1.72955 -31.489592 -5.5 1.881642 -31.215573 -5.5 3.862738
None
Jens Brühl [jb70]
Part Author
2020-12-17 16:40:02
I think, 2860 and 2862 will be the right real part numbers for the solid parts for the new plastic train tracks, since this number is moulded in the real parts.
The Train Track 9V Point Tongue Right for sure has a different design, very close to the existing version of 2860.dat on the parts tracker from [KROACH] with the gap underneath the metal rail. See Photo on bricklink: https://img.bricklink.com/ItemImage/EXTN/18897.png
Chris Dee wrote me, that Design IDs 2860 and 2862 will be the correct numbers for the 9V track as well.
And he wrote me, that , since I am sure that the all-plastic tracks also uses 2860 and 2862, then maybe the mould was updated to remove the recess. In that case the LDraw convention would be to use 2860a for the version with a recess that accepts the metal and 2860b for the all-plastic version.
So these are the new part submits for the b-parts.
Orion Pobursky [OrionP]
2024-03-23 00:59:37
Update ring primitives via script. This will not reset the vote status of the part.
Max Martin Richter [MMR1988]
posted a vote of Hold.
2024-03-28 20:30:00
I got the "new" switch and must admit, that this part uses the old mold but the metal rail is missing.
I will rework (or deep check) this switch as well, when I finished the 9V version.
Jens Brühl [jb70]
Part Author
2025-06-08 15:35:32
Using common Subfile 2860s01.dat
Jens Brühl [jb70]
Part Author
made the following comment.
2025-06-08 15:52:32
@Max, for the new 9V Tracks you have used a slightly wider track width (101 LDU) compared to the Plastic Tracks (100 LDU) measured from the center of each rail. Was that by intention? - Because it leads to incompatibility between both worlds. By using this common subfile here there is a small collision between the Switch Blade and the rail. See 53404c02.dat.
2025-06-09 06:43:49
I have to rework the PF-Tracks as well.
I did the measuring for the 9V and PF tracks and got 101 LDU for both.
But as written before, I will continue work, as soon as I find some free hours for.
This part is copyright © Jens Brühl
LDraw.org Parts Tracker, Kevin Roach, Max Martin Richter,
