Official File parts/3817c.dat
Minifig Leg Left
0 Minifig Leg Left 0 Name: 3817c.dat 0 Author: Max Martin Richter [MMR1988] 0 !LDRAW_ORG Part UPDATE 2023-03 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 !HELP Move down 12 units to align with hips 0 !HELP Move at z=1.25 relative to stud grid 0 !HELP 1 16 0 0 1.25 1 0 0 0 1 0 0 0 1 3817c.dat 0 !HELP 1 16 0 28 0 1 0 0 0 1 0 0 0 1 stug-1x2.dat 0 BFC CERTIFY CCW 0 !KEYWORDS BrickLink 972, Rebrickable 3817 0 !HISTORY 2023-06-24 [OrionP] Official Update 2023-03
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3817cs01.dat 0 // Rounded Front 1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\3817cs03.dat 0 // Flat Front 4 16 2 6.479 -5.75 2 8 -5.75 18.978 20 -5.75 18.518 6.479 -5.75 4 16 18.978 20 -5.75 2 8 -5.75 1.25 8 -5.75 1.25 20 -5.75 0 // Foot Front 4 16 19.25 28 -11.25 18.978 20 -11.25 1.25 20 -11.25 1.25 28 -11.25 0 // Foot Top 4 16 1.25 20 -11.25 18.978 20 -11.25 18.978 20 -5.75 1.25 20 -5.75
2022-12-30 14:20:01
New Minifig Leg with (hopefully) correct dimensions.
Orion Pobursky [OrionP]
made the following comment.
2022-12-30 14:50:01
I'd like this to be the last time we touch the geometry of this part. Any potential problem needs to be addressed. If you think there might be an issue even if it's minor, hold.
Willy Tschager [Holly-Wood]
posted a vote of Certify.
2022-12-31 17:35:01
Philippe Hurbain [Philo]
2023-01-23 09:25:01
Maybe add a position !help like suggested in 73200b-f1.dat?
2023-02-03 17:54:39
Please add the !HELP Philo wants.
edited the part header.
2023-02-05 20:06:13
posted a vote of Admin Review.
2023-02-06 03:03:34
Massimo Maso [Sirio]
posted a vote of Hold.
2023-04-27 20:10:25
There are some errors in the essentially subparts.
- Excessive use of decimals. Especially for the part that can be patternable, 4 decimal places are enough.
- Uncorrect vertex of conditional lines due to approximation at 5 or 6 decimals:
5 24 2 -8.75 0 18 -8.75 0 18.0226 -8.08413 3.34863 2 -8.08413 -3.34862
5 24 2 -8.084125 -3.348625 18.022649 -8.084125 -3.348625 2 -8.75 0 2 -6.187125 -6.187125
5 24 2 -6.187125 -6.187125 18.087173 -6.187125 -6.187125 2 -8.084125 -3.348625 2 -3.348625 -8.084125
- Some double vertices like:
18.977895 20 -5.75
18.977891 20 -5.75
2 -8.084125 3.348625
2 -8.08413 3.34863
18.022649 -8.084125 3.348625
2023-04-28 06:34:41
These are definitely NOT errors, even less worth a hold vote!!! Specs calls for a 3DP precision, any inconsistency below 0.001 should be ignored.
cancelled their vote.
2023-04-28 16:10:54
I withdraw the vote even though I am not convinced.
The rule should apply to primitives or rotated subparts, not vertices which can be made to coincide by reducing the number of decimals or putting another bit of work.
2023-04-29 07:46:04
Rounded to 3 digits
2023-04-30 14:35:40
Vincent Messenet [Cheenzo]
2023-06-12 16:12:15
2023-06-12 21:53:16
2023-06-24 02:37:22
Release 2023-03
This part is copyright © Max Martin Richter
