Unofficial File parts/53404.dat
Train Track 6 Studs Wide Switch Point Right
0 Train Track 6 Studs Wide Switch Point Right 0 Name: 53404.dat 0 Author: Jens Brühl [jb70] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS Rebrickable 53403 0 !HISTORY 2020-12-16 [jb70] end sleepers must not be mirrored, moved from subpart to part
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\53404s01.dat 0 // end sleepers 1 16 -320 0 0 1 0 0 0 1 0 0 0 1 s\53401s02.dat 1 16 320 0 0 -1 0 0 0 1 0 0 0 -1 s\53401s02.dat 1 16 333.852 0 -259.103 -.92388 0 -.38268 0 1 0 .38268 0 -.92388 s\53401s02.dat 0 // Studs 1 16 -310 0 0 0 0 1 0 1 0 -1 0 0 stug-1x4.dat 1 16 -310 0 70 0 0 1 0 1 0 -1 0 0 stud.dat 1 16 -310 0 -70 0 0 1 0 1 0 -1 0 0 stud.dat 1 16 -270 0 70 0 0 1 0 1 0 -1 0 0 stud.dat 1 16 -270 0 -120 0 0 1 0 1 0 -1 0 0 stug-1x4.dat 1 16 -270 0 -190 0 0 1 0 1 0 -1 0 0 stud.dat 1 16 -250 -8 -110 0 0 1 0 1 0 -1 0 0 stug-1x3.dat 1 16 -230 0 70 0 0 1 0 1 0 -1 0 0 stud.dat 1 16 -230 0 -120 0 0 1 0 1 0 -1 0 0 stug-1x4.dat 1 16 -230 0 -190 0 0 1 0 1 0 -1 0 0 stud.dat 1 16 -160 0 70 0 0 1 0 1 0 -1 0 0 stug-2x1.dat 1 16 -176.602 0 -84.222 -.19509 0 .98079 0 1 0 -.98079 0 -.19509 stug-2x1.dat 1 16 -80 0 70 0 0 1 0 1 0 -1 0 0 stug-2x1.dat 1 16 -105.654 0 -102.178 -.29362 0 .95593 0 1 0 -.95593 0 -.29362 stug-2x1.dat 1 16 0 0 70 0 0 1 0 1 0 -1 0 0 stug-2x1.dat 1 16 -37.113 0 -127.04 -.38752 0 .92187 0 1 0 -.92187 0 -.38752 stug-2x1.dat 1 16 80 0 70 0 0 1 0 1 0 -1 0 0 stug-2x1.dat 1 16 28.606 0 -158.616 -.47754 0 .87861 0 1 0 -.87861 0 -.47754 stug-2x1.dat 1 16 160 0 70 0 0 1 0 1 0 -1 0 0 stug-2x1.dat 1 16 160 0 20 0 0 1 0 1 0 -1 0 0 stug-2x2.dat 1 16 160 0 -20 0 0 1 0 1 0 -1 0 0 stug-2x2.dat 1 16 90.848 0 -196.59 -.56281 0 .82659 0 1 0 -.82659 0 -.56281 stug-2x1.dat 1 16 118.988 0 -155.261 -.56281 0 .82659 0 1 0 -.82659 0 -.56281 stug-2x2.dat 1 16 141.501 0 -122.197 -.56281 0 .82659 0 1 0 -.82659 0 -.56281 stug-2x2.dat 1 16 240 0 70 0 0 1 0 1 0 -1 0 0 stug-2x1.dat 1 16 240 0 20 0 0 1 0 1 0 -1 0 0 stug-2x2.dat 1 16 240 0 -20 0 0 1 0 1 0 -1 0 0 stug-2x2.dat 1 16 240 0 -70 0 0 1 0 1 0 -1 0 0 stug-2x1.dat 1 16 232.316 0 -125.553 -.55847 0 .82953 0 1 0 -.82953 0 -.55847 stug-2x1.dat 1 16 154.131 0 -241.687 -.55847 0 .82953 0 1 0 -.82953 0 -.55847 stug-2x1.dat 1 16 182.054 0 -200.211 -.55847 0 .82953 0 1 0 -.82953 0 -.55847 stug-2x2.dat 1 16 204.393 0 -167.03 -.55847 0 .82953 0 1 0 -.82953 0 -.55847 stug-2x2.dat 1 16 310 0 70 0 0 1 0 1 0 -1 0 0 stud.dat 1 16 310 0 0 0 0 1 0 1 0 -1 0 0 stug-1x4.dat 1 16 310 0 -70 0 0 1 0 1 0 -1 0 0 stud.dat 1 16 294.756 0 -163.202 -.47294 0 .8811 0 1 0 -.8811 0 -.47294 stug-2x1.dat 1 16 228.545 0 -286.555 -.47294 0 .8811 0 1 0 -.8811 0 -.47294 stug-2x1.dat 1 16 252.192 0 -242.5 -.47294 0 .8811 0 1 0 -.8811 0 -.47294 stug-2x2.dat 1 16 271.109 0 -207.256 -.47294 0 .8811 0 1 0 -.8811 0 -.47294 stug-2x2.dat 1 16 351.401 0 -190.605 -.38268 0 .92388 0 1 0 -.92388 0 -.38268 stud.dat 1 16 297.826 0 -319.948 -.38268 0 .92388 0 1 0 -.92388 0 -.38268 stud.dat 1 16 324.614 0 -255.276 -.38268 0 .92388 0 1 0 -.92388 0 -.38268 stug-1x4.dat
    Line 18: 1 16 333.852 0 -259.103 -.92388 0 -.38268 0 1 0 .38268 0 -.92388 s\53401s02.dat
    Line 36: 1 16 -176.602 0 -84.222 -.19509 0 .98079 0 1 0 -.98079 0 -.19509 stug-2x1.dat
    Line 39: 1 16 -105.654 0 -102.178 -.29362 0 .95593 0 1 0 -.95593 0 -.29362 stug-2x1.dat
    Line 42: 1 16 -37.113 0 -127.04 -.38752 0 .92187 0 1 0 -.92187 0 -.38752 stug-2x1.dat
    Line 45: 1 16 28.606 0 -158.616 -.47754 0 .87861 0 1 0 -.87861 0 -.47754 stug-2x1.dat
    Line 50: 1 16 90.848 0 -196.59 -.56281 0 .82659 0 1 0 -.82659 0 -.56281 stug-2x1.dat
    Line 51: 1 16 118.988 0 -155.261 -.56281 0 .82659 0 1 0 -.82659 0 -.56281 stug-2x2.dat
    Line 52: 1 16 141.501 0 -122.197 -.56281 0 .82659 0 1 0 -.82659 0 -.56281 stug-2x2.dat
    Line 58: 1 16 232.316 0 -125.553 -.55847 0 .82953 0 1 0 -.82953 0 -.55847 stug-2x1.dat
    Line 59: 1 16 154.131 0 -241.687 -.55847 0 .82953 0 1 0 -.82953 0 -.55847 stug-2x1.dat
    Line 60: 1 16 182.054 0 -200.211 -.55847 0 .82953 0 1 0 -.82953 0 -.55847 stug-2x2.dat
    Line 61: 1 16 204.393 0 -167.03 -.55847 0 .82953 0 1 0 -.82953 0 -.55847 stug-2x2.dat
    Line 66: 1 16 294.756 0 -163.202 -.47294 0 .8811 0 1 0 -.8811 0 -.47294 stug-2x1.dat
    Line 67: 1 16 228.545 0 -286.555 -.47294 0 .8811 0 1 0 -.8811 0 -.47294 stug-2x1.dat
    Line 68: 1 16 252.192 0 -242.5 -.47294 0 .8811 0 1 0 -.8811 0 -.47294 stug-2x2.dat
    Line 69: 1 16 271.109 0 -207.256 -.47294 0 .8811 0 1 0 -.8811 0 -.47294 stug-2x2.dat
    Line 71: 1 16 351.401 0 -190.605 -.38268 0 .92388 0 1 0 -.92388 0 -.38268 stud.dat
    Line 72: 1 16 297.826 0 -319.948 -.38268 0 .92388 0 1 0 -.92388 0 -.38268 stud.dat
    Line 73: 1 16 324.614 0 -255.276 -.38268 0 .92388 0 1 0 -.92388 0 -.38268 stug-1x4.dat
None
Jens Brühl [jb70]
Part Author
2020-12-15 22:10:02
I hope, the part numbering for the assemblies is OK. I took the numbering scheme from the last changes to the 12V switches 73697ac01.dat.
Jens Brühl [jb70]
Part Author
2020-12-16 10:55:01
posted a vote of Certify.
2024-12-11 15:00:46
Jens Brühl [jb70]
Part Author
2025-06-08 16:00:32
Changed bottom level from 4 LDU to 2.5 LDU to be compatible with the new bottom plates 2863.dat and 2939.dat.
This part is copyright © Jens Brühl
LDraw.org Parts Tracker,
