Unofficial File parts/47988.dat
Boat Bow 12 x 14 x  4 with Reeling
0 Boat Bow 12 x 14 x 4 with Reeling 0 Name: 47988.dat 0 Author: Gerald Lasser [GeraldLasser] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\47988s01.dat 1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\47988s01.dat 1 16 -10 0 -130 0 0 -1 0 1 0 1 0 0 stug-1x11.dat 1 16 10 0 -130 0 0 -1 0 1 0 1 0 0 stug-1x11.dat 1 16 50 0 -30 0 0 -1 0 1 0 1 0 0 stug-3x1.dat 1 16 -50 0 -30 0 0 -1 0 1 0 1 0 0 stug-3x1.dat 1 16 -60 0 0 0 0 -1 0 1 0 1 0 0 stug-2x2.dat 1 16 60 0 0 0 0 -1 0 1 0 1 0 0 stug-2x2.dat 1 16 0 -64 -250 0 0 -1 0 1 0 1 0 0 stug2-2x1.dat 1 16 -30 -40 -250 0 0 -1 0 1 0 1 0 0 stud2.dat 1 16 30 -40 -250 0 0 -1 0 1 0 1 0 0 stud2.dat 1 16 -110 -40 -30 0 0 -1 0 1 0 1 0 0 stud2.dat 1 16 110 -40 -30 0 0 -1 0 1 0 1 0 0 stud2.dat 1 16 0 4 -20 -40 0 0 0 0 -4 0 -1 0 rect2p.dat 4 16 -40 8 -24 -40 8 -20 40 8 -20 40 8 -24 0 BFC INVERTNEXT 1 16 0 6 -28.5 0 0 40 2 0 0 0 4.5 0 box3u2p.dat 4 16 8.5 4 -40 8.5 8 -40 -8.5 8 -40 -8.5 4 -40 1 16 0 4 -30 1 0 0 0 -1 0 0 0 1 stug3-1x3.dat 4 16 40 4 -24 40 4 -40 -40 4 -40 -40 4 -24 2 24 -40 4 -40 40 4 -40 2 24 8.5 8 -40 -8.5 8 -40 4 16 -8.5 8 -40 8.5 8 -40 20 8 -44 -20 8 -44 4 16 32 0 -52 40 0 -20 -40 0 -20 -32 0 -52 4 16 32 0 -52 -32 0 -52 -32 0 -60 32 0 -60 4 16 32 0 -68 32 0 -60 -32 0 -60 -32 0 -68 4 16 32 0 -68 -32 0 -68 -32 0 -92 32 0 -92 4 16 32 0 -100 32 0 -92 -32 0 -92 -32 0 -100 4 16 -32 0 -100 -32 0 -108 32 0 -108 32 0 -100 4 16 -32 0 -108 -24.5 0 -120 24.5 0 -120 32 0 -108 4 16 24.5 0 -120 -24.5 0 -120 -20 0 -124.5 20 0 -124.5 4 16 20 0 -128 20 0 -124.5 -20 0 -124.5 -20 0 -128 4 16 20 0 -128 -20 0 -128 -20 0 -132 20 0 -132 4 16 20 0 -148 20 0 -132 -20 0 -132 -20 0 -148 4 16 -20 0 -148 -20 0 -152 20 0 -152 20 0 -148 4 16 20 0 -168 20 0 -152 -20 0 -152 -20 0 -168 4 16 -20 0 -168 -20 0 -172 20 0 -172 20 0 -168 4 16 -20 0 -188 20 0 -188 20 0 -172 -20 0 -172 4 16 -20 0 -188 -20 0 -192 20 0 -192 20 0 -188 4 16 20 0 -208 20 0 -192 -20 0 -192 -20 0 -208 4 16 20 0 -208 -20 0 -208 -20 0 -212 20 0 -212 4 16 20 0 -228 20 0 -212 -20 0 -212 -20 0 -228 4 16 20 0 -228 -20 0 -228 -20 0 -232 20 0 -232 4 16 20 0 -240 20 0 -232 -20 0 -232 -20 0 -240 4 16 20 2 -240 20 0 -240 -20 0 -240 -20 2 -240 2 24 -20 0 -240 20 0 -240 4 16 -24 24 -124 24 24 -124 16 8 -124 -16 8 -124 4 16 -24 24 -124 -20 24 -120 20 24 -120 24 24 -124 2 24 20 24 -120 -20 24 -120 2 24 -24 24 -124 24 24 -124 0 // Centre Bottom 0 BFC INVERTNEXT 1 16 0 8 -71 20 0 0 0 -4 0 0 0 -27 box3u2p.dat 0 BFC INVERTNEXT 1 16 0 8 -111 5 0 0 0 -4 0 0 0 9 box5-1.dat 4 16 -5 8 -120 5 8 -120 20 24 -120 -20 24 -120 4 16 5 8 -102 -5 8 -102 -20 8 -98 20 8 -98 0 BFC INVERTNEXT 1 16 0 8 -132 5 0 0 0 -4 0 0 0 -8 box5-4a.dat 4 16 5 8 -140 1.5 8 -144 -1.5 8 -144 -5 8 -140 2 24 5 8 -140 -5 8 -140 0 BFC INVERTNEXT 1 16 0 8 -192 1.5 0 0 0 -4 0 0 0 48 box5.dat 4 16 -16 8 -244 -1.5 8 -240 1.5 8 -240 16 8 -244 3 16 16 8 -244 0 2 -244 -16 8 -244 2 24 16 8 -244 -16 8 -244 1 16 0 -6 -256 8 0 0 0 0 8 0 12 0 2-4cylo.dat 1 16 0 -6 -256 -8 0 0 0 0 8 0 -1 0 2-4ndis.dat 1 16 0 -6 -244 -8 0 0 0 0 8 0 1 0 2-4ndis.dat 3 16 0 2 -256 16 8 -256 -16 8 -256 2 24 16 8 -256 -16 8 -256 2 24 0 2 -257 0 3 -256 4 16 -35.7837 8 -260 -16 8 -256 16 8 -256 35.7837 8 -260 2 24 35.7837 8 -260 -35.7837 8 -260 0 // Pinholes Front 1 16 0 -6 -260 8 0 0 0 0 8 0 1 0 2-4ndis.dat 0 BFC INVERTNEXT 1 16 0 -6 -242 6 0 0 0 0 6 0 -16 0 4-4cyli.dat 1 16 0 -46 -242 6 0 0 0 0 -6 0 -1 0 4-4ndis.dat 1 16 0 -46 -260 1 0 0 0 0 1 0 1 0 peghole.dat 0 BFC INVERTNEXT 1 16 0 -46 -242 6 0 0 0 0 6 0 -16 0 4-4cyli.dat 1 16 0 -46 -242 6 0 0 0 0 6 0 -1 0 4-4edge.dat 1 16 0 2 -250 1 0 0 0 -1.5 0 0 0 1 stud3a.dat 1 16 0 2 -250 1 0 0 0 1 0 0 0 1 cylj4x8.dat 1 16 0 -6 -260 1 0 0 0 0 1 0 1 0 peghole.dat 1 16 0 -6 -242 6 0 0 0 0 6 0 -1 0 4-4edge.dat 1 16 0 -6 -242 6 0 0 0 0 -6 0 -1 0 2-4ndis.dat 1 16 0 -6 -242 2 0 0 0 0 2 0 -1 0 2-4ring3.dat 0 BFC INVERTNEXT 1 16 0 -6 -240 8 0 0 0 0 8 0 -2 0 2-4cylo.dat 1 16 0 -6 -240 8 0 0 0 0 8 0 -1 0 2-4ndis.dat 3 16 -1.7559 -14.8273 -260 0 -14 -260 1.7559 -14.8273 -260 3 16 0 -38 -260 -1.7558 -37.1729 -260 1.7558 -37.1729 -260 4 16 1.7558 -37.1729 -260 -1.7558 -37.1729 -260 -1.7559 -14.8273 -260 1.7559 -14.8273 -260 4 16 -1.7559 -54.8273 -260 1.7559 -54.8273 -260 1.7559 -60 -260 -1.7559 -60 -260 4 16 -1.756 -60 -260 1.7559 -60 -260 20 -64 -260 -20 -64 -260 2 24 -20 -64 -260 20 -64 -260 3 16 -8 -64 -242 8 -64 -242 0 -52 -242 4 16 20 -64 -260 8 -64 -242 -8 -64 -242 -20 -64 -260 1 16 0 -35 -242 -8 0 0 0 0 -29 0 -1 0 recte3.dat 3 16 35.7837 8 -260 0 2 -260 -35.7837 8 -260 3 16 1.7559 -54.8273 -260 -1.7559 -54.8273 -260 0 -54 -260
None
2023-02-12 11:24:45
made the following comment.
2023-02-12 11:31:24
WHile doing this, I noticed, that the 8 x 8 Grille plates have severe overlaps in them...
posted a vote of Certify.
2024-07-21 12:41:57
Rene Rechthaler [Blechtaler]
2024-07-21 12:53:49
Orion Pobursky [OrionP]
edited the part header.
2024-07-28 02:09:34
Header Edits
description:
to
Boat Bow 12 x 14 x 4 with Railing
posted a vote of Hold.
2024-07-28 02:11:06
What up with the origin?
2024-07-28 19:00:38
Putting it on the deck level between the two 2x2 extensions?
2024-07-28 19:31:40
Origin is "correct", at top stud level, but ...
2024-07-28 19:46:19
My holds are to bring attention. If the origin is fine, I'll cert.
2024-11-17 10:49:07
moved origin away from the top of studs to a more logical point
Willy Tschager [Holly-Wood]
2025-06-06 07:24:07
* Check the X origin in s01.
2025-06-22 09:37:13
huh, what happened there?!!?
Jeff Jones [notmaster]
Part Author
2025-06-22 09:38:57
geometry overlap
2025-06-22 21:58:14
@willy, corrected in s01
cancelled their vote.
2025-06-23 15:25:50
LDraw.org Parts Tracker,
