Unofficial File parts/u9584.dat
~Minifig Ballon with Thin Bar on Handle - Balloon Half
0 ~Minifig Ballon with Thin Bar on Handle - Balloon Half 0 Name: u9584.dat 0 Author: Gerald Lasser [GeraldLasser] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !CATEGORY Minifig Accessory
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\u9584s01.dat 1 16 0 0 0 1 0 0 0 1 0 0 0 -1 s\u9584s01.dat 5 24 -16.1683 -83.1887 0 -15.155 -79.875 0 -14.6386 -79.875 -3.9224 -14.6386 -79.875 3.9224 5 24 -12.3743 -106.7278 0 -14.51975 -103.9792 0 -14.025 -103.9792 -3.758 -14.025 -103.9792 3.758 5 24 -2.2838 -111.8452 0 -4.529 -111.3862 0 -4.3747 -111.3862 -1.1722 -4.3747 -111.3862 1.1722 5 24 -10.654 -71.5865 0 -8.75 -69.5355 0 -8.4519 -69.5355 -2.2647 -8.4519 -69.5355 2.2647 5 24 -4.426 -63.637 0 -5.2 -63.5 0 -4.8043 -63.5 -1.99 -4.8043 -63.5 1.99 5 24 -15.155 -79.875 0 -13.8845 -76.8014 0 -13.4114 -76.8014 -3.5936 -13.4114 -76.8014 3.5936 5 24 -16.9033 -86.6889 0 -16.1683 -83.1887 0 -15.6174 -83.1887 -4.1847 -15.6174 -83.1887 4.1847 5 24 -17.3495 -90.3134 0 -16.9033 -86.6889 0 -16.3273 -86.6889 4.3749 -16.3273 -86.6889 -4.3749 5 24 -4.4775 -66.6996 0 -3.9394 -66.3607 0 -3.8051 -66.3607 -1.0195 -3.8051 -66.3607 1.0195 5 24 -8.75 -69.5355 0 -6.6973 -67.8998 0 -6.4691 -67.8998 -1.7334 -6.4691 -67.8998 1.7334 5 24 -1.7334 -67.8998 -6.4691 -.6929 -68.71 -7.6602 -2.2647 -69.5355 -8.4519 -.5303 -68.5425 -7.4637 5 24 -6.6973 -110.6302 0 -9.702 -108.9346 0 -9.37145 -108.9346 -2.5111 -9.37145 -108.9346 2.5111 5 24 -6.6973 -67.8998 0 -4.4775 -66.6996 0 -4.3249 -66.6996 -1.1588 -4.3249 -66.6996 1.1588 5 24 -.6929 -68.71 -7.6602 -2.2647 -69.5355 -8.4519 -.75 -68.9018 -7.9022 -1.7334 -67.8998 -6.4691 5 24 -9.702 -108.9346 0 -12.3743 -106.7278 0 -11.9527 -106.7278 -3.2027 -11.9527 -106.7278 3.2027 5 24 -3.6142 -65.8741 0 -3.5 -65.3 0 -3.491 -65.8741 -.9354 -3.491 -65.8741 .9354 5 24 -14.51975 -103.9792 0 -16.1683 -100.8886 0 -15.6174 -100.8886 -4.1847 -15.6174 -100.8886 4.1847 5 24 -12.3743 -74.0244 0 -10.654 -71.5865 0 -10.291 -71.5865 -2.7575 -10.291 -71.5865 2.7575 5 24 -.75 -111.9492 0 -2.2838 -111.8452 0 -2.11 -111.8452 .874 -2.11 -111.8452 -.874 5 24 -1.7334 -67.8998 6.4691 -.6929 -68.71 7.6602 -2.2647 -69.5355 8.4519 -.5303 -68.5425 7.4637 5 24 -4 -68.8 0 -5.9319 -69.5167 0 -3.6956 -68.8 -1.5308 -3.6956 -68.8 1.5308 5 24 -13.8845 -76.8014 0 -12.3743 -74.0244 0 -11.9527 -74.0244 -3.2027 -11.9527 -74.0244 3.2027 5 24 -5.9319 -109.2444 0 -.75 -110.3412 0 -.75 -109.2828 -5 -.75 -109.2828 5 5 24 -3.6142 -64.6111 0 -3.9394 -64.0272 0 -3.6395 -64.0272 1.5076 -3.6395 -64.0272 -1.5076 5 24 -16.1683 -100.8886 0 -17.1264 -97.5037 0 -16.54285 -97.5037 -4.43265 -16.54285 -97.5037 4.43265 5 24 -4.529 -111.3862 0 -6.6973 -110.6302 0 -6.4691 -110.6302 -1.7334 -6.4691 -110.6302 1.7334 5 24 -3.5 -65.3 0 -3.6142 -64.6111 0 -3.3391 -64.6111 1.3831 -3.3391 -64.6111 -1.3831 5 24 -3.9394 -66.3607 0 -3.6142 -65.8741 0 -3.491 -65.8741 -.9354 -3.491 -65.8741 .9354 5 24 -.6929 -68.71 7.6602 -2.2647 -69.5355 8.4519 -.75 -68.9018 7.9022 -1.7334 -67.8998 6.4691 5 24 -17.5 -94 0 -17.3495 -90.3134 0 -16.7584 -90.3134 4.4904 -16.7584 -90.3134 -4.4904 5 24 -17.1264 -97.5037 0 -17.5 -94 0 -16.9037 -94 4.5293 -16.9037 -94 -4.5293
    Line 15: 5 24 -12.3743 -106.7278 0 -14.51975 -103.9792 0 -14.025 -103.9792 -3.758 -14.025 -103.9792 3.758
    Line 25: 5 24 -6.6973 -110.6302 0 -9.702 -108.9346 0 -9.37145 -108.9346 -2.5111 -9.37145 -108.9346 2.5111
    Line 30: 5 24 -14.51975 -103.9792 0 -16.1683 -100.8886 0 -15.6174 -100.8886 -4.1847 -15.6174 -100.8886 4.1847
    Line 38: 5 24 -16.1683 -100.8886 0 -17.1264 -97.5037 0 -16.54285 -97.5037 -4.43265 -16.54285 -97.5037 4.43265
None
2024-01-03 22:04:07
made the following comment.
2024-01-03 22:07:21
The inside is guesswork... But It has thoese gaps, so I needed to close it...
Orion Pobursky [OrionP]
renamed the part.
2024-01-04 23:09:39
"parts/s/35703s02.dat" to "parts/s/u9584.dat"
renamed the part.
2024-01-04 23:09:51
"parts/s/u9584.dat" to "parts/u9584.dat"
2024-01-04 23:33:31
rotated
2024-01-04 23:57:33
reduced resolution of the surface
edited the part header.
2024-01-06 17:18:48
Header Edits
category:
Minifig
to
Minifig Accessory
Comment:
Updated category
LDraw.org Parts Tracker,
