0 Minifig Balloon with Thin Bar on Handle
0 Name: 35763.dat
0 !CATEGORY Minifig Accessory
0 !KEYWORDS Bricklink 35703c01, Brickowl 540713
1 16 0 0 0 1 0 0 0 1 0 0 0 1 35703.dat
1 16 0 0 -7 0 0 -1 0 1 0 1 0 0 35702.dat
1 16 0 0 -7 0 0 -1 0 1 0 -1 0 0 35702.dat
None
or should these be separate shortcuts?
the handle is always white, only the balloon changes, but BL has two different parts because of the different bloon colors.
how are the color versions handled then?
I will rotate the balloon and will use u-numbers and create a white c01
https://images.brickset.com/sets/large/71021-6.jpg?
Also is there a need to have the balloon halves at -7? Unlikely they are used elsewhere.
Do we have a correct parts ID meanwhile?
https://brickset.com/parts/design-35763
The only thing I don't know is if 35703 is a dual mould of string+half a balloon. I guess not.
IMO, 35763 is an assy of a string (35703) + 2 pcs. of 35702.
Hold for the orientation.
description:
Minifig Ballon with Thin Bar on Handle
to
This part is copyright ©
Gerald Lasser
Licensed under
CC BY 4.0
https://forums.ldraw.org/thread-27921-post-52324.html#pid52324
But I think maybe the handle should be rotated instead...
