Unofficial File parts/30411.dat
0 Minifig Figure Sebulba
0 Name: 30411.dat
0 Author: Fredrik Hareide [fhareide]
0 !CATEGORY Minifig
0 !KEYWORDS Bricklink sw0980, Set 7171, Star Wars
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\30411s01.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\30411s01.dat
1 16 0 0 0 -20 0 0 0 -8 0 0 0 -10 box4-1.dat
1 16 0 0 2 -1.5 0 0 0 -4 0 0 0 -8 box4-1.dat
4 16 -16 -4 10 -20 -8 10 20 -8 10 16 -4 10
4 16 -16 0 -6 16 0 -6 20 0 -10 -20 0 -10
Needs 2 More Votes (N)
No recorded votesThis part has the following warnings
- Category: Minifig is retired, use use suitable active Minifig category
Has Uncertified Subfiles
2024-01-30 19:33:43
posted a vote of Hold
2024-02-03 14:29:11
2024-02-08 20:19:00
Renamed
made the following comment.
2024-02-10 10:24:42
There is still something wrong with this...
I think maybe the neck, and the face, is too short. Could be more streched.
https://img.bricklink.com/ItemImage/MN/0/sw0980.original.png
2024-02-10 18:52:54
I totally agree that it's far from perfect. But I'm not sure what you suggest I change?
https://www.dropbox.com/scl/fi/qfkcvvq4hnggdi85mclpn/SebulbaWire.png?rlkey=t4uxle104vmmks06lfjct43nh&dl=0
Jeff Jones [notmaster]
2025-02-14 00:36:35
hand should be clip
Orion Pobursky [OrionP]
2025-02-14 01:35:27
Can't be. It's not a standard clip shape.
2025-02-14 01:37:48
Note BrickLink number is correct but the link fail because BL classifies this as a Minifig and not a part.
Philippe Hurbain [Philo]
edited the part header.
2025-02-14 08:12:09
Header Edits
keywords:
to
Bricklink sw0980, Set 7171, Star Wars, Bricklink 30411
Addded RB kw
2025-02-14 08:13:14
Header Edits
keywords:
Bricklink 30411, Bricklink sw0980, Set 7171, Star Wars
to
Rebrickable 30411, Bricklink sw0980, Set 7171, Star Wars
2025-02-14 11:13:10
imho the hand should be able to hold clips
2025-02-14 11:13:16
*bars
2025-02-14 21:04:50
But it looks like a bar should be possible to snap into the clip.
Maybe add some cyli segments? Or some clean up inside the hand around a bar.
Where is the centre of that clip?
2025-02-15 06:13:22
New one yes. Old one not I think. https://www.flickr.com/photos/darthray/6906723249
2025-02-15 09:15:56
oh
2025-03-10 18:49:50
Just tested it on mine, the hands (or feet more likely) can definitely hold on to a 3.18 bar. It feels as firm as any other regular clip and he is even intended to hold on to his "controls" in the final build, so I guess this is very likely intentional.
2025-06-28 11:31:22
should the bar connection for the feet be at 0 -45.5 -40?
2025-06-28 12:49:13
i should build sebulba's podracer and then find out
2025-06-28 13:21:24
updated
built it
the bar holder is at Y=-46 Z=-40
built it
2026-03-24 16:54:21
bump
Missing some condlines under the chin.
https://img.bricklink.com/ItemImage/EXTN/21234.original.png
https://img.bricklink.com/ItemImage/MN/0/sw0980.png
I think some lines are missing on his "ears", and maybe some ribs on the ribcage.
Those round things on his shoulders should maybe be softer? Loose the outer edge line?
Think we could use "Minifig Figure Sebulba" as the description.
