Unofficial File parts/6124.dat
View official version of part
~Minifig Magic Wand (Obsolete)
0 ~Minifig Magic Wand (Obsolete) 0 Name: 6124.dat 0 Author: Jaco van der Molen [Jaco] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !CATEGORY Obsolete 0 !KEYWORDS Belville, Castle, Dragon Masters, fairy, Fairy Tale, Fright Knights 0 !KEYWORDS Majisto, Millimy, Time Cruisers, Time Twisters, Willa, Witch, Wizard 0 !HISTORY 1998-01-12 [PTadmin] Official Update 1998-01 0 !HISTORY 2003-09-15 [westrate] Filled gap between star and shaft; BFC'd; 0 !HISTORY 2004-03-02 [PTadmin] Official Update 2004-01 0 !HISTORY 2007-07-16 [PTadmin] Header formatted for Contributor Agreement 0 !HISTORY 2008-07-01 [PTadmin] Official Update 2008-01 0 !HISTORY 2024-06-22 [Philo] Corrected wrong length, rebuilt using BIs mesh 0 !HISTORY 2025-05-20 [KnightOfTarenta] Obsoleted due to bad geometry
1 16 0 0 0 4 0 0 0 1 0 0 0 4 4-4edge.dat 1 16 0 0 0 4 0 0 0 -1 0 0 0 4 4-4disc.dat 1 16 0 -18 0 4 0 0 0 18 0 0 0 4 4-4cyli.dat 1 16 0 -18 0 4 0 0 0 1 0 0 0 4 4-4edge.dat 1 16 0 -18 0 4 0 0 0 -2 0 0 0 4 4-8sphe.dat 1 16 0 -19.75 0 2 0 0 0 1 0 0 0 2 4-4edge.dat 1 16 0 -59.6 0 2 0 0 0 39.85 0 0 0 2 4-4cyli.dat 1 16 0 -59.6 0 2 0 0 0 -1.54 0 0 0 2 1-4cyls.dat 1 16 0 -59.6 0 2 0 0 0 -1.54 0 0 0 -2 1-4cyls.dat 1 16 0 -59.6 0 -2 0 0 0 -1.54 0 0 0 2 1-4cyls.dat 1 16 0 -59.6 0 -2 0 0 0 -1.54 0 0 0 -2 1-4cyls.dat 1 16 0 -61.14 0 0 0 2 0 1 1.54 2 0 0 2-4edge.dat 1 16 0 -61.14 0 0 0 -2 0 1 1.54 2 0 0 2-4edge.dat 4 16 0 -81 -2 -3.07 -71.07 -2 -2.12 -69.62 -2 0 -76.5 -2 4 16 -3.07 -71.07 -2 -13 -71.07 -2 -9 -69.62 -2 -2.12 -69.62 -2 4 16 -13 -71.07 -2 -4.97 -64.93 -2 -3.44 -65.38 -2 -9 -69.62 -2 4 16 -4.97 -64.93 -2 -8.03 -55 -2 -5.56 -58.5 -2 -3.44 -65.38 -2 4 16 -8.03 -55 -2 0 -61.14 -2 0 -62.75 -2 -5.56 -58.5 -2 4 16 0 -61.14 -2 8.03 -55 -2 5.56 -58.5 -2 0 -62.75 -2 4 16 8.03 -55 -2 4.97 -64.93 -2 3.44 -65.38 -2 5.56 -58.5 -2 4 16 4.97 -64.93 -2 13 -71.07 -2 9 -69.62 -2 3.44 -65.38 -2 4 16 13 -71.07 -2 3.07 -71.07 -2 2.12 -69.62 -2 9 -69.62 -2 4 16 3.07 -71.07 -2 0 -81 -2 0 -76.5 -2 2.12 -69.62 -2 4 16 -2.12 -69.62 2 -3.07 -71.07 2 0 -81 2 0 -76.5 2 4 16 -9 -69.62 2 -13 -71.07 2 -3.07 -71.07 2 -2.12 -69.62 2 4 16 -3.44 -65.38 2 -4.97 -64.93 2 -13 -71.07 2 -9 -69.62 2 4 16 -5.56 -58.5 2 -8.03 -55 2 -4.97 -64.93 2 -3.44 -65.38 2 4 16 0 -62.75 2 0 -61.14 2 -8.03 -55 2 -5.56 -58.5 2 4 16 5.56 -58.5 2 8.03 -55 2 0 -61.14 2 0 -62.75 2 4 16 3.44 -65.38 2 4.97 -64.93 2 8.03 -55 2 5.56 -58.5 2 4 16 9 -69.62 2 13 -71.07 2 4.97 -64.93 2 3.44 -65.38 2 4 16 2.12 -69.62 2 3.07 -71.07 2 13 -71.07 2 9 -69.62 2 4 16 0 -76.5 2 0 -81 2 3.07 -71.07 2 2.12 -69.62 2 0 // Outer star 1 16 -1.535 -76.035 0 1.535 0 0 -4.965 1 0 0 0 2 rect.dat 1 16 1.535 -76.035 0 1.535 0 0 4.965 1 0 0 0 2 rect.dat 1 16 -8.035 -71.07 0 4.965 0 0 0 1 0 0 0 2 rect.dat 1 16 8.035 -71.07 0 4.965 0 0 0 1 0 0 0 2 rect.dat 1 16 -8.985 -68 0 -4.015 0 0 -3.07 -1 0 0 0 2 rect.dat 1 16 8.985 -68 0 -4.015 0 0 3.07 -1 0 0 0 2 rect.dat 1 16 -6.5 -59.965 0 1.53 0 0 -4.965 1 0 0 0 2 rect.dat 1 16 6.5 -59.965 0 1.53 0 0 4.965 1 0 0 0 2 rect.dat 1 16 -4.015 -58.07 0 -4.015 0 0 3.07 -1 0 0 0 2 rect.dat 1 16 4.015 -58.07 0 -4.015 0 0 -3.07 -1 0 0 0 2 rect.dat 0 // Back inner star 1 16 -1.06 -73.06 1.5 1.06 0 0 -3.44 -1 0 0 0 0.5 rect.dat 1 16 -5.56 -69.62 1.5 3.44 0 0 0 -1 0 0 0 0.5 rect.dat 1 16 -6.22 -67.5 1.5 -2.78 0 0 -2.12 1 0 0 0 0.5 rect.dat 1 16 -4.5 -61.94 1.5 1.06 0 0 -3.44 -1 0 0 0 0.5 rect.dat 1 16 -2.78 -60.625 1.5 -2.78 0 0 2.125 1 0 0 0 0.5 rect.dat 1 16 2.78 -60.625 1.5 -2.78 0 0 -2.125 1 0 0 0 0.5 rect.dat 1 16 4.5 -61.94 1.5 1.06 0 0 3.44 -1 0 0 0 0.5 rect.dat 1 16 6.22 -67.5 1.5 -2.78 0 0 2.12 1 0 0 0 0.5 rect.dat 1 16 5.56 -69.62 1.5 3.44 0 0 0 -1 0 0 0 0.5 rect.dat 1 16 1.06 -73.06 1.5 1.06 0 0 3.44 -1 0 0 0 0.5 rect.dat 3 16 2.12 -69.62 1 -2.12 -69.62 1 0 -76.5 1 3 16 -3.44 -65.38 1 -9 -69.62 1 -2.12 -69.62 1 3 16 0 -62.75 1 -5.56 -58.5 1 -3.44 -65.38 1 3 16 3.44 -65.38 1 5.56 -58.5 1 0 -62.75 1 3 16 2.12 -69.62 1 9 -69.62 1 3.44 -65.38 1 3 16 2.12 -69.62 1 0 -62.75 1 -2.12 -69.62 1 3 16 -2.12 -69.62 1 0 -62.75 1 -3.44 -65.38 1 3 16 0 -62.75 1 2.12 -69.62 1 3.44 -65.38 1 0 // Front inner star 1 16 -1.06 -73.06 -1.5 1.06 0 0 -3.44 -1 0 0 0 0.5 rect.dat 1 16 -5.56 -69.62 -1.5 3.44 0 0 0 -1 0 0 0 0.5 rect.dat 1 16 -6.22 -67.5 -1.5 -2.78 0 0 -2.12 1 0 0 0 0.5 rect.dat 1 16 -4.5 -61.94 -1.5 1.06 0 0 -3.44 -1 0 0 0 0.5 rect.dat 1 16 -2.78 -60.625 -1.5 -2.78 0 0 2.125 1 0 0 0 0.5 rect.dat 1 16 2.78 -60.625 -1.5 -2.78 0 0 -2.125 1 0 0 0 0.5 rect.dat 1 16 4.5 -61.94 -1.5 1.06 0 0 3.44 -1 0 0 0 0.5 rect.dat 1 16 6.22 -67.5 -1.5 -2.78 0 0 2.12 1 0 0 0 0.5 rect.dat 1 16 5.56 -69.62 -1.5 3.44 0 0 0 -1 0 0 0 0.5 rect.dat 1 16 1.06 -73.06 -1.5 1.06 0 0 3.44 -1 0 0 0 0.5 rect.dat 3 16 0 -76.5 -1 -2.12 -69.62 -1 2.12 -69.62 -1 3 16 -2.12 -69.62 -1 -9 -69.62 -1 -3.44 -65.38 -1 3 16 -3.44 -65.38 -1 -5.56 -58.5 -1 0 -62.75 -1 3 16 0 -62.75 -1 5.56 -58.5 -1 3.44 -65.38 -1 3 16 3.44 -65.38 -1 9 -69.62 -1 2.12 -69.62 -1 3 16 -2.12 -69.62 -1 0 -62.75 -1 2.12 -69.62 -1 3 16 -3.44 -65.38 -1 0 -62.75 -1 -2.12 -69.62 -1 3 16 3.44 -65.38 -1 2.12 -69.62 -1 0 -62.75 -1 0
Not releaseable Needs More Votes (F) Needs More Votes (F)
None
None
Philippe Hurbain [Philo]
2024-06-22 12:25:12
Current model was too long (3.6mm). Rebuilt using BIs data.
made the following comment.
2024-06-22 13:02:00
Any risk of breaking models with this change? The handle is now shorter and perhaps misplased in a hand or clip.
2024-06-22 13:32:01
I wondered that. Yes, could be slightly misplaced in hand, but even if the grip on the old version was placed high, it still holds the new version. So I don't think this is a problem.
1 11 0 0 .1 1 0 0 0 1 0 0 0 1 6124old.dat
1 16 0 0 1 0 0 0 1 0 0 0 1 61240.dat
1 71 0 -20 20 1 0 0 0 1 0 0 0 1 60897.dat
2024-06-25 03:36:21
Did you take into consideration that there are 2 versions of this part with varying handle length? The new (shorter) one was released somewhere mid-2010, not exactly sure when.
For some reason Bricklink has yet not acknowledged the difference. If you want, I can look if I have both versions to make a photo.
2024-06-25 07:01:22
And indeed it seems from the photos that the shorter version is used in Notre-Dame. Same part number? so a and b versions I guess?
2024-06-25 09:03:22
...or 6124/28681
https://brickset.com/parts/design-6124 and https://brickset.com/parts/design-28681
6124 is the older version, but according to the thumbnails (albeit of low significance) the length of the bar section is not related to the version!
2024-06-25 15:05:25
Unfortunately, neither the old one nor the new one has a number marking (new one has only a (c) Lego).
2024-06-25 15:21:09
It seems the thumbnails at Brickset (taken from Lego's server) got replaced at some time with the newer model. Rebrickable has still a few of the older thumbnails with longer handle:
https://rebrickable.com/parts/6124/equipment-magic-wand/19/
posted a vote of Hold.
2025-05-20 21:47:43
I think this should be obsoleted.
Star is thinner and wider, overall length changed.
2025-05-21 11:19:35
Only added the obsolete line.
I guess this should be reverted to the official one to make sense?
Shall the History remain as is?
2025-05-21 11:20:35
See above.
2025-08-22 14:50:58
This should now be the correct Obsolete File:
*file context (geometry) restored to the old version by Jaco van der Molen
*Header adapted to reflect the changes made/added Obsolete category
Still kept backup for the old version just in case.
This part is copyright © Jaco van der Molen
LDraw.org Parts Tracker, Andy Westrate, Philippe Hurbain, Chris Böhnke,
