Unofficial File parts/821435j.dat
Sticker  1.1 x  1.7 with Black Number "2" and Green Laurels on Transparent Background
0 Sticker 1.1 x 1.7 with Black Number "2" and Green Laurels on Transparent Background 0 Name: 821435j.dat 0 Author: Takeshi Takahashi [RainbowDolphin] 0 !LDRAW_ORG Unofficial_Part 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS Bricklink 6539stk01, BrickOwl 428181, Racing, Rebrickable 821435 0 !KEYWORDS Set 6539, Victory cup racers
1 16 0 -0.25 0 17 0 0 0 0.25 0 0 0 11 box5-12.dat 0 BFC NOCLIP 1 16 0 -0.25 0 1 0 0 0 1 0 0 0 1 s\821435js01.dat 1 16 0 -0.25 0 -1 0 0 0 1 0 0 0 1 s\821435js01.dat 1 16 0 -0.25 1.5 8 0 0 0 1 0 0 0 8 type-swiss721bt-bold-n2.dat 0 BFC CLIP 1 16 0 -0.25 0 1 0 0 0 1 0 0 0 1 s\821435js02.dat 1 16 0 -0.25 0 -1 0 0 0 1 0 0 0 1 s\821435js02.dat 1 16 0 -0.25 0 1 0 0 0 1 0 0 0 1 s\821435js03.dat
Not releaseable Errors Found (CHN) Errors Found (CHN)
User Vote
Holly-Wood Certify
MagFors Hold
2024-09-29 15:06:35
posted a vote of Hold.
2025-03-21 00:00:41
Subfile this for reuse in set 6327?
edited the part header.
2025-06-28 19:14:44
Header Edits
description:
Sticker 1.1 x 1.7 with Black Number Two and Green Laurels
to
Max Seidenstücker [MaxSeidenstuecker]
Part Author
made the following comment.
2025-09-17 20:44:43
Please subfile this for reuse in 170877c
Part Author
2025-09-22 21:33:52
Can you please subfile this for reuse in 170877c.
The following is the same file without T-Junction reports:
1 16 0 -.25 0 1 0 0 0 1 0 0 0 1 s\821435js01.dat
1 16 0 -.25 0 -1 0 0 0 1 0 0 0 1 s\821435js01.dat
1 16 0 -.25 1.5 8 0 0 0 1 0 0 0 8 type-swiss721bt-bold-n2.dat
4 16 -17 -.25 11 -3.1 -.25 8 3.1 -.25 8 17 -.25 11
3 16 3.2 -.25 7 2.84 -.25 5.5 3.7 -.25 5.1
3 16 2.84 -.25 5.5 3.9 -.25 4.5 3.7 -.25 5.1
4 16 4.4 -.25 3.1 3.9 -.25 4.5 2.84 -.25 5.5 4.7 -.25 1.4
4 16 4.8 -.25 .7 4.7 -.25 1.4 2.84 -.25 5.5 4.6 -.25 -.2
4 16 4.5 -.25 -.9 4.6 -.25 -.2 2.84 -.25 5.5 4.1 -.25 -1.8
3 16 2.7 -.25 -3.3 -2.7 -.25 -3.3 0 -.25 -6.4
4 16 -4.5 -.25 -.9 -4.1 -.25 -1.8 -2.84 -.25 -2.5 -2.84 -.25 5.5
3 16 -2.84 -.25 5.5 -4.6 -.25 -.2 -4.5 -.25 -.9
4 16 -4.8 -.25 .7 -4.6 -.25 -.2 -2.84 -.25 5.5 -4.7 -.25 1.4
4 16 -4.4 -.25 3.1 -4.7 -.25 1.4 -2.84 -.25 5.5 -3.9 -.25 4.5
3 16 -2.84 -.25 5.5 -3.7 -.25 5.1 -3.9 -.25 4.5
3 16 -3.2 -.25 7 -3.7 -.25 5.1 -2.84 -.25 5.5
3 16 0 -.25 -7 -2 -.25 -7.5 2 -.25 -7.5
4 16 -17 -.25 -11 2 -.25 -7.5 -2 -.25 -7.5 -4.4 -.25 -7.9
3 16 -2 -.25 -7.5 -2.5 -.25 -7.5 -4.4 -.25 -7.9
4 16 2 -.25 -7.5 -17 -.25 -11 17 -.25 -11 4.4 -.25 -7.9
3 16 2.5 -.25 -7.5 2 -.25 -7.5 4.4 -.25 -7.9
4 16 2.752 -.25 -2.5 2.7 -.25 -3.3 3.9 -.25 -3 2.84 -.25 -2.5
4 16 -2.84 -.25 -2.5 -2.7 -.25 -3.3 2.7 -.25 -3.3 2.752 -.25 -2.5
4 16 -4.1 -.25 -1.8 -3.9 -.25 -3 -2.7 -.25 -3.3 -2.84 -.25 -2.5
4 16 3.1 -.25 8 -3.1 -.25 8 -3.2 -.25 7 .128 -.25 7
3 16 3.1 -.25 8 .128 -.25 7 3.2 -.25 7
4 16 3.2 -.25 7 .128 -.25 7 .128 -.25 5.5 2.84 -.25 5.5
4 16 -3.2 -.25 7 -2.84 -.25 5.5 .128 -.25 5.5 .128 -.25 7
4 16 2.84 -.25 3.036 2.84 -.25 -2.5 3.9 -.25 -3 4.1 -.25 -1.8
3 16 2.84 -.25 3.036 4.1 -.25 -1.8 2.84 -.25 5.5
2025-09-22 23:56:42
Rearranged subfiles for reusability
T-junctions due to primitives should be accepted.
Part Author
2025-09-23 09:42:53
Thank you!
Maybe align to "" instead of word of number for the three stickers to be in line with the others.
Rene Rechthaler [Blechtaler]
2025-09-23 10:44:23
the bad thing about these number prims is that they are either fully or not NOCLIP...
(should the number be inlined?)
Willy Tschager [Holly-Wood]
posted a vote of Certify.
2025-09-23 11:08:00
2025-09-23 13:28:52
Header Edits
description:
to
2025-09-23 15:38:42
I see no reason for having 3 subfiles. 1 is enough.
The laurel is always green. It could be inlined in the mirrored background file. Use that file either coloured white or uncoloured.
And the third subfile, adding the middle, should be inlined on the top level, adapting to the number prim size.
But I would prefer to have the number prim inlined too.
