Unofficial File parts/2335dx1.dat
0 Flag 2 x 2 with Blue and Yellow Rectangle Sticker
0 Name: 2335dx1.dat
0 Author: Eugen [app4soft]
0 !CATEGORY Sticker Shortcut
0 !KEYWORDS K (Kilo), Krusty Krab, Set 3833, SpongeBob, Ukraine
1 16 0 0 0 1 0 0 0 1 0 0 0 1 2335.dat
1 16 2 20 30 0 -1 0 0 0 -1 1 0 0 4538725d.dat
Errors Found (HHN)
Willy Tschager [Holly-Wood]
Has Uncertified Subfiles
Eugen [app4soft]
2024-10-08 21:46:34
Eugen [app4soft]
2024-10-08 21:55:55
Fix previously uploaded files
renamed the part.
2024-10-09 15:05:34
"parts/2335pb024s2.dat" to "parts/2335dx1.dat"
edited the part header.
2024-10-09 15:18:12
Header Edits
description:
=Flag 2 x 2 with Blue and Yellow Rectangle Pattern (Sticker)
to
posted a vote of Hold
2024-10-09 15:26:58
Why are you using Flag 11055? Is that the correct part used in this set?
If so, then this needs to be renumberd again to 11055dx1.
Two parts can't have the same description. They need to be different.
Any suggestion to how to tell these apart?
This can't be an alias part, if it is using a different sticker. And "Unofficial_Shortcut Alias" doesn't exist.
So how do we handle this duplication?
made the following comment.
2024-10-09 15:32:19
Or is "Unofficial_Shortcut Alias" a valid parttype?
Eugen [app4soft]
2024-10-09 21:29:27
Anyway, lets for now it will use 2335.dat
2024-10-09 21:38:58
I think this duplicate file should be unified into 2335dx0, with two set-number described in keywords line.
It would be far more useful to allocate 2335dx1-dx3 for three other flag sticker shortcuts in these sets.
Please see:
https://library.ldraw.org/official/4777
Please see:
Gerald Lasser [GeraldLasser]
2024-10-09 22:40:15
I agree with Takeshi, I would even add the sticker sheet number in the keywords
Eugen [app4soft]
2024-10-09 22:48:47
"I would even add the sticker sheet number in the keywords", if two flags would be combined into one, there should be two stickers numbers in keywords too, I guess.
And what about two stickers? Both look the same, but they really printed on different paper sheets.
Eugen [app4soft]
2024-10-09 22:52:20
"Please see: https://library.ldraw.org/official/4777",— should be "!KEYWORDS Bricklink 2335pb024" added to this part too?
2024-10-10 03:18:22
Yes, external reference should be included if available. This change can be done by admin edit, you don't need to resubmit.
Eugen [app4soft]
2024-10-15 17:09:54
Anything need to edit for this part?
2024-10-15 17:48:05
This is just bloat.
Jeff Jones [notmaster]
2025-01-20 18:49:24
maybe merge this and the other one
2026-05-27 16:43:20
Pretty sure this doesn't exist at all. Lego.com lists 11055 as base part; also the two sticker sheets seem to be slightly different - the older set has sharp corners, the newer one round corners.
I'm releasing it under CC0 (Public Domain), but due to PT actually not implemented it yet, set license to CC BY 4.0, which should be switched to CC0 once PT would implemented it.
