Unofficial File parts/s/38458s01.dat
0 ~Minifig Head with Exaggerated Chimpanzee Features - Head
0 Name: s\38458s01.dat
0 !HISTORY 2025-06-07 [notmaster] subparted removed edges added what needs work
0 !HISTORY 2025-08-27 [GeraldLasser] Moved origin, removed needs work
1 16 0 0 0 0 0 1 0 1 0 -1 0 0 stug-2x2.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\38458s05.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 s\38458s05.dat
1 16 0 0 0 20.2 0 0 0 1 0 0 0 20.2 2-4edge.dat
5 24 0 0 -20.2 0 7.8785 -20.2 7.7305 5.4539 -18.6628 -7.7305 5.4539 -18.6628
Needs 2 More Votes (N)
Has Uncertified Subfiles
Gerald Lasser [GeraldLasser]
2021-09-09 10:55:02
2021-09-09 11:00:02
spelling
2021-09-09 11:15:01
condlines were missing
this is NEEDS WORK as the crumpled skin below the cheeks is not modeled
Mark Kennedy [mkennedy]
made the following comment.
2021-09-11 00:05:01
Might want to mirror it for left and right half.
Willy Tschager [Holly-Wood]
posted a vote of Hold
2025-02-25 06:37:22
* The edges are already included in s03
* I agree that it should be split in half
* Lacks documentation why it needs work.
* Since the chin is crumpled anyway you should inline:
1 16 0 -6 0 13.46667 0 0 0 12 0 0 0 -13.46667 t04o5000.dat
as it doesn't look good whit prim substitution
2025-02-25 06:45:44
As a dual mould the edge lines between both halves should be removed.
Jeff Jones [notmaster]
2025-06-07 09:33:06
2025-06-07 17:38:31
* Fits a Plate 2x2 Round:
1 16 0 -32 0 1 0 0 0 1 0 0 0 1 4032.dat
so, 1 16 0 -24 0 20.2 0 0 0 18 0 0 0 20.2 1-4cyli.dat is out of system.
* Misses edges:
1 16 0 -24 0 20 0 0 0 1 0 0 0 20 1-4edge.dat
Edge should be added to a new 1-4chrde prim
* Rounding:
5 24 14.284096869 -6 -14.284096869 14.2834 -7.2833 -14.2834 18.6635 -6 -7.7312 12.8072 -7.11 -15.27
* Misses edges:
* Rounding:
cancelled their vote.
2025-06-07 17:42:48
2025-06-07 17:43:50
* Origin!
* Has to use a stug10-2x2.dat
2025-06-07 18:33:03
look like normal studs to me
https://forums.ldraw.org/attachment.php?aid=6413
2025-06-07 21:19:04
should it be 20.00052563 or 20?
2025-06-08 11:56:30
20
2025-08-27 21:35:14
-> "so, 1 16 0 -24 0 20.2 0 0 0 18 0 0 0 20.2 1-4cyli.dat is out of system."
Check the picture here, the head is slightly larger than a 2x2 round plate
https://c.gmx.net/@327741486667930412/SABZK4-GsmBMAfXhqz4EyQ
-> "* Has to use a stug10-2x2.dat"
Check the picture here, the larger head allows for complete studs
https://c.gmx.net/@327741486667930412/PdPFgjVPSkFXQFy365yMIg
2025-08-27 22:20:25
moved orin and corrected some geometry
