Unofficial File parts/40145.dat
0 Plate 2 x 2 Round with Rotation Stem
0 Name: 40145.dat
0 !HELP Position Tire at 0 19 0 0 -1 0 0 0 1 -1 0 0
0 !CATEGORY Plate
0 !HISTORY 2021-04-28 {LEGO/Unity Microgame} Original part shape
0 !HISTORY 2023-05-22 [ejboer] File preparation for LDraw Parts Tracker
1 16 10 0 10 1 0 0 0 1 0 0 0 1 stud6.dat
1 16 -10 0 -10 -1 0 0 0 1 0 0 0 -1 stud6.dat
1 16 10 0 -10 0 0 1 0 1 0 -1 0 0 stud6.dat
1 16 -10 0 10 0 0 -1 0 1 0 1 0 0 stud6.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\40145s01.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 -1 s\40145s01.dat
1 16 0 0 0 0 0 1 0 1 0 -1 0 0 s\40145s01.dat
1 16 0 0 0 0 0 -1 0 1 0 1 0 0 s\40145s01.dat
1 16 0 3.75 0 6.25 0 0 0 8.75 0 0 0 6.25 4-4cylo.dat
1 16 0 12.5 0 6.25 0 0 0 1 0 0 0 6.25 4-4ndis.dat
1 16 0 12.5 0 8.48528 0 8.48528 0 1 0 -8.48528 0 8.48528 1-4chrd.dat
1 16 0 12.5 0 -8.48528 0 -8.48528 0 1 0 8.48528 0 -8.48528 1-4chrd.dat
1 16 0 12.5 0 -8.48528 0 8.48528 0 1 0 -8.48528 0 -8.48528 1-4chrd.dat
1 16 0 12.5 0 8.48528 0 -8.48528 0 1 0 8.48528 0 8.48528 1-4chrd.dat
4 16 6.25 12.5 6.25 8.4852 12.5 8.4852 -8.48528 12.5 8.48528 0 12.5 6.25
3 16 0 12.5 6.25 -8.48528 12.5 8.48528 -6.25 12.5 6.25
4 16 -8.48528 12.5 -8.48528 -6.25 12.5 0 -6.25 12.5 6.25 -8.48528 12.5 8.48528
3 16 -6.25 12.5 0 -8.48528 12.5 -8.48528 -6.25 12.5 -6.25
4 16 -6.25 12.5 -6.25 -8.48528 12.5 -8.48528 8.4852 12.5 -8.4852 0 12.5 -6.25
3 16 0 12.5 -6.25 8.4852 12.5 -8.4852 6.25 12.5 -6.25
4 16 8.4852 12.5 8.4852 6.25 12.5 0 6.25 12.5 -6.25 8.4852 12.5 -8.4852
3 16 6.25 12.5 0 8.4852 12.5 8.4852 6.25 12.5 6.25
1 16 0 3.75 0 4 0 0 0 20.25 0 0 0 4 4-4cylo.dat
1 16 0 12.5 0 12 0 0 0 1.5 0 0 0 12 4-4cylo.dat
1 16 0 14 0 2 0 0 0 -1 0 0 0 2 4-4ring5.dat
1 16 0 14 0 10 0 0 0 1 0 0 0 10 4-4cylo.dat
1 16 0 15 0 -.625 0 0 0 .33333 0 0 0 .625 4-4con15.dat
1 16 0 15.333 0 -3.125 0 0 0 1.66667 0 0 0 3.125 4-4con2.dat
1 16 0 17 0 6.25 0 0 0 4 0 0 0 6.25 4-4cylo.dat
1 16 0 23 0 -.625 0 0 0 -.33333 0 0 0 -.625 4-4con15.dat
1 16 0 22.667 0 -3.125 0 0 0 -1.66667 0 0 0 -3.125 4-4con2.dat
1 16 0 23 0 10 0 0 0 1 0 0 0 10 4-4cylo.dat
1 16 0 24 0 4 0 0 0 -1 0 0 0 4 4-4ring1.dat
1 16 0 24 0 2 0 0 0 -1 0 0 0 2 4-4ring4.dat
Awaiting Admin Review (CCN)
Willy Tschager [Holly-Wood]
Has Uncertified Subfiles
Evert-Jan Boer [ejboer]
2023-05-22 10:43:16
Gerald Lasser [GeraldLasser]
posted a vote of Hold
2023-06-02 20:05:22
2023-06-04 10:31:16
Several changes. Looked at parts like 2655 and 4032a for the bleeding, seems to happen in other parts as well. Decided to inline the prims to avoid this issue.
2023-06-11 21:17:35
Missing edge lines:
2 5 6.012 6.5 1.195 6.25 6.5 0
2 5 6.25 6.5 0 5.774 6.5 -2.392
2 5 -5.774 6.5 2.392 -6.25 6.5 0
2 5 -6.25 6.5 0 -6.012 6.5 -1.195
Javier Orquera [kuramapika1]
made the following comment.
2023-06-12 17:44:00
Is this part missing the "Lego" logo inside the studs?
Rene Rechthaler [Blechtaler]
2023-06-12 17:54:37
yes the logo is missing, but it would have to be added manually because the studs are rotated...
2023-06-12 20:06:51
I made a stud primitive, with logo info, but for the solid 2x2-studs, stug15-2x2.
That file contain logo info, if a user wants to activate it.
How many round 2x2-parts with hollow studs could benefit from a similar prim?
2023-06-18 19:17:07
modified subpart, removed some double lines
posted a vote of Certify
2025-08-25 11:22:43
2025-08-25 11:46:03
1 256 0 19 0 0 -1 0 0 0 1 -1 0 0 59895.dat
this disc might bleed through
1 16 0 0 0 20 0 0 0 1 0 0 0 20 4-4disc.dat
there should be no edge line where these surfaces meet the large cyli
4 16 -1.273 3.75 -19.747 -1.273 4.6 -19.747 0 6.5 -20 0 3.75 -20
4 16 1.273 6.5 -19.747 1.273 3.75 -19.747 0 3.75 -20 0 6.5 -20
This cyli is slightly too large, it intersects with a side grove of the tyre (should be R= 12)
1 16 0 12.5 0 12.25 0 0 0 1.5 0 0 0 12.25 4-4cylo.dat
To fill this area
1 16 0 12.5 0 .25 0 0 0 1 0 0 0 .25 4-4rin25.dat
1 16 0 12.5 0 .5 0 0 0 1 0 0 0 .5 4-4rin13.dat
1 16 0 12.5 0 3.5 0 0 0 1 0 0 0 3.5 4-4ring2.dat
1 16 0 12.5 0 1.75 0 0 0 1 0 0 0 1.75 4-4ring6.dat
usa a NDIS/CHRD combo this will use less surfaces
