Unofficial File parts/u9608c05.dat
Part Attributes: Base Part: u9608.dat
External site data provided by part keywords View on BrickLink
Electric Plug Triple with Cross-Cut Pin (Type 2) and Cable End (Complete)
0 Electric Plug Triple with Cross-Cut Pin (Type 2) and Cable End (Complete) 0 Name: u9608c05.dat 0 Author: Rene Rechthaler [Blechtaler] 0 !LDRAW_ORG Unofficial_Shortcut 0 !LICENSE Licensed under CC BY 4.0 : see CAreadme.txt 0 BFC CERTIFY CCW 0 !KEYWORDS Bricklink x466ac200, Peeron x466a, Set 708-1
1 16 0 0 0 1 0 0 0 1 0 0 0 1 u9608c02.dat 1 375 0 0 0 -1 0 0 0 1 0 0 0 1 s\u9609s01.dat
User Vote
RainbowDolphin Certify
2023-09-15 15:28:56
2023-09-15 15:32:09
got the position wrong
posted a vote of Hold.
2023-09-16 10:58:39
I don't mind the compact design using a very short cable, but I would prefer at least one loop of the cable, indicating it being longer IRL.
Shouldn't the length be in the description, instead of added as Help info?
Why doesn't the structure of this cable follow the other examples we already have?
You need to make a set of plugs, including a cable end, and then use those in this complete part.
The short cable stub is allways a Part, while the Cable End is a subpart. Both should use thier own unique partnumber.
2023-10-05 23:05:06
2024-01-03 14:55:18
swapped cable/plug coloring
posted a vote of Certify.
2024-05-31 15:20:40
LDraw.org Parts Tracker,
